Pics of my spark plugs at 40k.....
Old Apr 8, 2009 | 01:12 AM
byez's Avatar
I believe that two of them were supposedely replaced by the dealership during a de-flooding procedure.
One of the trailing plugs was completely black while the other trailing plug was black but also had some corrosion. Could this discrepancy between the two be cause for any concern?
Old Apr 8, 2009 | 01:13 AM
byez's Avatar
Trailing, Trailing, Leading, Leading
Old Apr 8, 2009 | 01:36 PM
savedsol's Avatar
Carbonormous
Hopefully you're talking kilometers since 35K miles is the change point in the manual.
Old Apr 8, 2009 | 01:39 PM
dozer's Avatar
on his 3rd rx8
^dude you be surprised, mine lasted just as long....
Old Apr 8, 2009 | 01:42 PM
byez's Avatar
nope they are at around 64,000 kilometers/5 years old and were running fine
what kind of wear does a worn spark plug produce? i can't imagine any wear if the plugs are still firing fine
Old Apr 8, 2009 | 02:22 PM
Try to push them, u will know how bad they're
Old Apr 8, 2009 | 05:22 PM
Nubo's Avatar
Lubricious
None that you'd be able to see in that picture without sending it to NASA.
Too dark and small to see any detail, sorry. But that's usually the case when people submit pictures of their plugs.
The wear occurs on the electrodes, as each spark erodes a tiny bit of metal. Since the center electrode is Iridium, and about the toughest metal there is, the side electrode is usually the one to wear away.
The "corrosion" you see is likely to be just ash deposits from oil burnoff and usually its not in a location that causes problems.
There are other problems that can develop over time such as glazing, carbon-tracks, cracks, etc.. You've got your money's worth from these plugs. Don't be greedy
Old Apr 9, 2009 | 02:32 AM
note to all.
really..
20k miles is pushing it unless you track often..
Old Apr 9, 2009 | 04:27 AM
AndrewE's Avatar
Yellow Fever
I do mine at roughly 30 000mi/45 000kms, along with coils and wires, they looked like that to
Old Apr 9, 2009 | 11:09 AM
byez's Avatar
Update:
My idle has improved significantly. It used to fluctuate quite a bit but is now steady and very smooth.
Have to move onto the coils and plug wires next. BHR or LS2 Coils?
RevMeHarder
Jun 1, 2026 02:30 PM
TeslaMSI
Dec 10, 2015 01:10 AM
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
DVerdeyen
Sep 13, 2015 11:19 AM
