missing at high rpm
Old Apr 7, 2009 | 02:02 PM
drmac's Avatar
missing at high rpm
hello to all.guys i have a problem and need help.i have a 03 rx8,AT.it hesitates once or twice on the way to redline.ihave replaced plugs,plug wires and original mazda coils(100b).as a set and have driven it about 100km on the new set.i have also put in a new air filter,change oil and filter after 2500km. the car is driven48000km.i do not know what else to do .pls help.
Old Apr 7, 2009 | 02:12 PM
alienRX8's Avatar
Boosted!!!
did you check the Catalytic converter?
Old Apr 7, 2009 | 02:24 PM
drmac's Avatar
no.what should i do with it.the place where i live does not have any mechanics servicing mazda vehicles.in fact i think there is no mazda dealer in our country.the plugs,wires and coils i got from the states through a cousin.
Old Apr 7, 2009 | 02:31 PM
drmac's Avatar
sorry forgot to add the in the old set the exhaust tip would be black after a good run but after putting in the new set there is a brownish residue in the exhaust.the acceleration is better and it will pull to the redline.this problem is an on and off thing.
thanks
Old Apr 7, 2009 | 08:43 PM
Clean the MAF.
You will retain the Cel code unless you re-set it.
Res-set the ECU
Old Apr 7, 2009 | 09:43 PM
teknics's Avatar
Certified Mazda Tech
and resets the NVRAM since youve been driving with the misfires they may be "learned" to be expected by the e-shaft sensor.
kevin.
Old Apr 13, 2009 | 01:28 PM
drmac's Avatar
i think this' learned' thing is was the problem b/c after driving it for a couple of 100km the missing has gone.its fine now.thanks for taking the to
WranglerFan
May 31, 2022 07:51 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
WranglerFan
Nov 5, 2017 09:35 AM
05rx8mazda
Nov 28, 2015 09:42 AM
