View Full Version : Idles, but no throttle response.... HELP!!!
LittleJohn 04-07-2009, 03:05 AM Hi Guys,
Wondering if someone could point me in the right direction.
Just came back from being overseas for 4 weeks, and went to start her up. All good except for the fact that I have absolutely no throttle response whatsoever.
I have a CEL, and DSC light that won't go off. Everything else looks normal.
A bit of history..
1. About a year ago I had had a faulty coil which caused her to misfire badly, since then, I keep hearing metal bits rattling in the muffler and or exhaust pipe every now and then.
2. I did replace my coils and plugs at that time and she's been running OK.
3. I also installed a HKS Twin Power thingy at the same time.. not sure if it did anything, other than make me think I was burning fuel more completely.
4. Prior to my coil/s failing, I did experience occasional random stalling, even at speeds of 60+kms _ not sure if this was a sign or just a red herring
Any thoughts on what could be causing this??
TIA
Cheers,
LJ
auzoom 04-07-2009, 04:15 AM Whats the CEL? The rattling sounds like the substrate in the CAT has dropped.
LittleJohn 04-07-2009, 06:33 AM Whats the CEL? The rattling sounds like the substrate in the CAT has dropped.
hmm.. yes, I don't know as I don't own any tools that can talk to the ECU.. eg scanalyser etc..
I was hoping some of the gurus around here could sort of point me in the right direction before I star buying things or pulling things apart.
cheers
StealthTL 04-07-2009, 07:12 AM Code readers are the '8s best friend!
Hard to tell without you pulling that code, I would reset the ECU, disconnect the battery for a while, it's probably screwed up from a long period of low voltage.
Buy a reader that can access the CANBus protocol - very cheap.
Cromax 04-07-2009, 09:45 AM Do what Stealth said and keep us posted ...
LittleJohn 04-07-2009, 04:40 PM Code readers are the '8s best friend!
Ok.. thanks for this. I did do all this prior to your reply, but thought I should give it another go. Only this time I let her idle until she reached operating temp, then I noticed I was getting some throttle response back. Not much, only able to rev to about 2000rpm with about a 1+ sec lag. This led to me believe that the mechanical side of the engine was ok and it was the ECU that was playing silly buggers.
So this is what I decided to do.
1. Pull the Batt and let her sit. - about 3mins. also had foot on brake for this period
2. Reconnected the batt
3. Did the NVRAM reset - ie pump brake a zillion times just after flicking the key
4. Calibrate DSC - turn wheel full left then full right.
And viola!! actually the CEL went off at step 3.. and TCS wen off after a quick spin around the block
Not 100% sure if she's 100%, but took her for a drive and she felt OK.... well as good as she was before I left her.
Oh well.. I'm glad i got it sorted out and thanks for the ideas guys.. much appreciated.. She's a temperamental, jealous one eh??
Cheers
LJ
Revolver 04-14-2009, 01:59 AM Glad to hear you got it sorted LJ.
Hey, are you coming to the Nationals this year?
Gomez 04-14-2009, 06:30 AM Four week holiday?
Voltage drop hiccup.
LittleJohn 04-14-2009, 04:44 PM Glad to hear you got it sorted LJ.
Thanks Rev... No unfortunately I can't. This is turning out to be a fairly big year for me bot work and personal. Plus I've just taken 4 weeks leave to travel around Europe, so funding is a little tight too.. :(
LittleJohn 04-14-2009, 04:46 PM Four week holiday?
Yes... who would've known... pretty ghay if you ask me. Never had a car do this to me before.
Revolver 04-14-2009, 05:57 PM Thanks Rev... No unfortunately I can't. This is turning out to be a fairly big year for me bot work and personal. Plus I've just taken 4 weeks leave to travel around Europe, so funding is a little tight too.. :(
I hear you brother. I'm going to Italy in June and have already had to tell my travel agent a few times I want to stay in the hotel, not buy the bloody thing! :uhh: :)
