Cobb AP
Old Apr 6, 2009 | 05:28 PM
MazdaRx8449's Avatar
Cobb AP
Will using the cobb ap make me fail state emission inspection. Also how much hp can you expect to gain by using it?
Old Apr 6, 2009 | 07:28 PM
Jon316G's Avatar
Grasshopper
I'm curious about this too.
With certain DTC codes being masked, would the inspector's reader give a fault error because of this?
Like when you clear the PCM before inspection and they read your car, only to say that not enough info has been collected and to drive around for 15 minutes and come back.
I encountered this when I swapped out batteries just before e-check.
Old Apr 6, 2009 | 07:36 PM
636's Avatar
636
Rice Police
^ i just slip a couple of greens in his pocket and call it a day....
Old Apr 6, 2009 | 08:12 PM
mscamp02's Avatar
Blue Bullet?
hp is all dependent on what kind of mods you have on your car
Old Apr 7, 2009 | 06:38 PM
You should be fine. The car runs leaner, thus cleaner.
Old Apr 7, 2009 | 06:57 PM
the cobb should not make you fail. If anything it'll help by blocking certain CEL's
Sheldon24
Sep 19, 2015 02:37 PM
RenzoRx-8
Sep 9, 2015 02:38 PM
BigBadChris
Sep 7, 2015 01:49 PM
