Diff Fluid=75w90NS or regular 75w90
Old Mar 31, 2009 | 10:31 PM
AE92's Avatar
im about to perform my 30k mile service. which includes tranny and diff fluid change. trans im using Redline MTL and for the diff ( '04 GT= LSD correct?) i wanted to use Redline also, but i saw NS and regular. which one is for use in the stock LSD diff?
Old Mar 31, 2009 | 10:35 PM
Jon316G's Avatar
Grasshopper
I use Redline 75w90 in my diff.
Old Mar 31, 2009 | 10:46 PM
Charles R. Hill's Avatar
Owner of BHR
Since the factory diff is a vicous coupled type, there is no need for the limited-slip friction modifiers. Like Jon said, standard 75W90 is fine.
Old Mar 31, 2009 | 10:50 PM
rx8cited's Avatar
Senior Member
DIY thread. I used Red Line 75W90 in the diff 2. And yes to ( '04 GT= LSD correct?)
Old Mar 31, 2009 | 10:59 PM
AE92's Avatar
keh thanks guys for evryones help. looks like im gettin the standard 75w90.
Old Mar 31, 2009 | 11:02 PM
Owner of BHR
Yes, it is an LSD but it uses heat-sensitive fluid instead of clutches for the engagement.
Old Mar 31, 2009 | 11:36 PM
rx8cited's Avatar
Senior Member
Heat-sensitive fluid - I did not know that. What's the advantage of this design vs using clutches? How often would you recommend changing the diff fluid?
Old Apr 1, 2009 | 12:28 AM
Unless you want to rebuild/buy a new transmission, stop using MTL, its too light, and oh yes it will mess it up. Use MT-90 for Tranny. or Any Tranny Fluid meets GL-4 spec thats 75w90 weight.
For Rear diff, use 75w90. Or anything that meets GL-5 at the same weight or something higher like 75w140.
the NS one is NOT for use in LSD, NS means it does NOT contain the fiction modifiers required for Limited-Slip Differential to function.
Old Apr 1, 2009 | 02:49 AM
AE92's Avatar
whoops i actually have MT90 not MTL haha i read all about that MTL stuff before i switched it when i first bouhgt it last Oct. my bad. but im staying with MT90 hahaha.
Old Apr 1, 2009 | 03:39 AM
Brettus's Avatar
Boosted Kiwi
NS works well in the gear box - true story ...
Old Apr 1, 2009 | 01:38 PM
AE92's Avatar
so then i have to ask whats the difference in the MT90 and 75w90-NS, in thE gear box?
Old Apr 1, 2009 | 01:52 PM
Icemark's Avatar
Think you are mixing up cars... the factory LSD is a Torsen type on the RX-8. I have pulled a couple apart now (the differential fits perfect in the 87-91 Turbo RX-7 differential case) and they all have been Torsen types, not Viscous LSDs.
The Nissan's use a viscous, but Mazda hasn't for 10+ years.
Old Apr 1, 2009 | 02:24 PM
Owner of BHR
Yes, you are correct! I did get things confused but even the Torsen is a clutchless design, isn't it? My point is the same but for the wrong reason.
Old Apr 1, 2009 | 02:30 PM
It does work.
NS is just a GL-5 fluid without the stuff for LSD, which is good for Synchos in the gear box.
Old Apr 1, 2009 | 02:48 PM
Owner of BHR
If you guys saw the various fluids I have run in my trans and diff you would think I was an idiot. Well, you may already think that, but.............
Anyway, all the fluids we have been told NOT to use I have used without incident.
Old Apr 1, 2009 | 02:55 PM
Icemark's Avatar
Yes, you are correct in that the Torsen (like the Viscous) is a clutchless design and regular GL-5 gear oil can be used (although I don't know if I would use a GL-4 like MT-90 in any Torsen type diff, just because of the higher percentage of gear/tooth contact).
Brettus's Avatar
Boosted Kiwi
/\ i'm a bit the same (except for the idiot part )
I've run stock , MT90, LWshockproof and now NS in the g/box . The best so far has been the NS
Old Apr 1, 2009 | 06:56 PM
delhi's Avatar
Grand Chancellor
Castrol sells the Hypoy-C 80w90.... also compatible with rear LSD per manual.
Old Apr 1, 2009 | 07:55 PM
Aseras's Avatar
not as bad as a friend who put 2 quarts of atf in a old datsun during a oil change. when we changed the oil it was freaking weird looking. car ran fine though. he was a pack rat and still had the bottles in the box. finally put it together after looking.
Old Apr 1, 2009 | 08:02 PM
NS = no slip modifiers
the only reason to run NS in a diff is if it's a clutch type and you're trying to induce more lockup, so there's no advantage/reason to use it in the RX-8 OE differential
slip modifiers can cause synchro engagement issues though, so running NS in the trans is a good idea, my preference is still Redline 75W-140NS
I have Kaaz 80W90 oil in the diff because I had it around at the time, not cheap ...
Old Apr 2, 2009 | 03:25 AM
DOMINION's Avatar
I don't buy Kool-Aid
Cool thanks for the info Jon!
Old Apr 2, 2009 | 06:57 PM
HWK11's Avatar
Lighting Yellow
you guys are confusing me... so using NS is okay?
Old Apr 2, 2009 | 06:58 PM
Spinning Sushi's Avatar
I <3 Sushi
Don't use NS, it doesn't have the modifiers needed for your car.
Old Apr 2, 2009 | 07:00 PM
Brettus's Avatar
Boosted Kiwi
not OK for diff - but OK for gearbox ...
AE92's Avatar
75w90 NS =Tranny
regular 75w90 = Diff
