View Full Version : Will 19x8.5 ... 35mm offset rub?
matticakes
12-21-2003, 03:26 PM
Im looking to put 19x8.5 with 35mm offset rims with 235/35ZR19 tires... do you think these will rub?
slavearm
12-22-2003, 01:44 PM
You will need to roll the fenders and even that might not be enough. I would go for a +40-50 range for the offset, and if you get the +40 you will run SLIGHTLY under extremely hard cornering. Anything above +40 though and you should be fine.
RX8on19s
12-22-2003, 07:52 PM
Here's my 8 with 245/35/19 in the front and 275/30/19 in the rear. The rims are 19"x8.5 in the front and 19"x9.5 in the rear with 35mm offset
RX8on19s
Here's my 8
RX8on19s
12-22-2003, 07:54 PM
These are the m-sports rims by ADR
mikeb
12-22-2003, 08:08 PM
that grill looks sweet
Ned M
12-23-2003, 05:39 PM
So do you get any rubbing of sidewalls against fender lip under hard cornering with this setup, or not?
Thx
RX8on19s
12-24-2003, 03:57 PM
It rubs a bit when you have 4 people on the back fender. I'm going to a performance shop on Monday to roll the fender with a special tool. I'll let you guys know how it turns out.
shepepp
12-25-2003, 08:09 PM
Hey RX8on19s,
I put new aftermarket rims on my RX8, but the sensors kept leaking air, so I couldn't use them. Did you have that problem?
If so, what did you do and is there an adapter available for them tha you know of?
Shepepp
RX8on19s
12-25-2003, 10:36 PM
I don't use the sansor, I live with the light in the car.....
mikeb
12-26-2003, 11:49 AM
please find out what special tool they use to roll fenders?
Hopefully not a baseball bat
EXA4DRIVER
01-05-2004, 11:38 PM
http://www.robsaudiworld.com/fender.htm
This is the tool they use.
