Temp Monitor on Radio Broken
Old Mar 30, 2009 | 08:06 AM
SilverHokie's Avatar
I'm Delaware Fast
I went to start up the car early yesterday morning to find that my temp. monitor was off.
I tried turning on and off the key switch but that is a no go. I guess I could try pulling that battery cable.
I just want to know if this is happened to anybody else and if this is a quick fix. It's not big deal considering I'm still under warranty. It's just annoying.
05 RX-8 Sport model, standard radio w/o Bose.
Old Mar 30, 2009 | 10:54 AM
greg985's Avatar
The 337
Hold down the radio power button and the seek up button (to the right of the radio power) for a second and you will get a reading. It will say A/C and then 0-16. 0 is when the A/C dial is as cold as it can go and it the number should go up by 1 each time you turn the A/C **** toward the heat. 16 should be full heat. If its F'ed bring it to the dealer to replace it. Common problem
Old Mar 30, 2009 | 11:41 AM
ken-x8's Avatar
Push the display button...it's toward the right side of the radio, labeled "Disp".
Old Mar 30, 2009 | 01:20 PM
I'm Delaware Fast
Omg...I have officially disqualified myself from life for a couple of days, as I reflect on my past experiences with cars.
I would pretend this thread did not happen, to assist in any posts I make after this thread, as a valuable opinion. Thank you for you time.
Old Mar 30, 2009 | 10:13 PM
ken-x8's Avatar
You get credit for figuring out that "Amb" is the actual on/off switch, and not "Disp" like I said .
Ken
RX8mzda
Oct 1, 2015 10:17 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Vedivan1
Sep 20, 2015 04:39 PM
mattymack
Sep 6, 2015 10:33 PM
