FS 4.77 09 Complete Rear Diff
Old Mar 29, 2009 | 11:36 PM
mrmazda7's Avatar
Like the title says, I have a complete 09 4.77 rear diff pulled from wrecked car with 500 miles on it.
1200.00
Old Mar 29, 2009 | 11:56 PM
VS8's Avatar
VS8
4 Cylinder Rotary
would u sell the 4.77 final drive gear alone
Old Mar 29, 2009 | 11:58 PM
mrmazda7's Avatar
TX Gears
Sorry, cannot seperate
Old Mar 29, 2009 | 11:59 PM
VS8's Avatar
VS8
4 Cylinder Rotary
man i want this sooo bad
Old Mar 30, 2009 | 12:01 AM
mrmazda7's Avatar
I am in Dallas, Tx.
This is a direct swap.
Old Mar 30, 2009 | 12:06 AM
WhiteSnowflake8's Avatar
Diego
It prob be easier to just swap diffs than the gears alone. plus 4.77 could be for racing, and stock for street use... If i had money id be on this.
Old Mar 30, 2009 | 12:08 AM
VS8's Avatar
VS8
4 Cylinder Rotary
well im guessin he wouldnt want my 4.44 gears
Old Mar 30, 2009 | 07:34 AM
rx8shift's Avatar
Would this fit on a 2004 AT rx8? I assume it would
Old Mar 30, 2009 | 08:57 AM
myriadshalaks's Avatar
rot8ing
i'm confused now. i'm finding a new one from mazda for a grand.
Old Mar 30, 2009 | 09:13 AM
mrmazda7's Avatar
Gears
I think that may be for just the ring and pinion?
Old Mar 30, 2009 | 09:14 AM
mrmazda7's Avatar
Gears
Yes, it is a direct swap
Old Mar 30, 2009 | 09:21 AM
rot8ing
hmm. interested. i got a quote to put it in. mazda says 6.5 hours, but it won't take that long. i figure i can get it put in for around 350.
what sort of gains should i expect?
Old Mar 30, 2009 | 02:04 PM
PhantomRX-8's Avatar
Bad Ass
Youre not going to gain anything. The car will rev up faster in gear so your top mph for each gear will be lower but it will get you up and moving faster.
Old Mar 30, 2009 | 02:10 PM
mrmazda7's Avatar
Yes, there will be no power gain. You will just have a little faster 0 to 60 time.
Old Mar 30, 2009 | 02:12 PM
Mazdaspeed RX8 ver2's Avatar
+1 no HP gain if thats what you're asking, its all about the gearing of your car. this would be an awesome upgrade.. so tempted....
Old Mar 30, 2009 | 05:49 PM
rot8ing
that counts as a gain. i wasn't thinking hp gains. i meant what exactly was the overall benefit. and this was answered nicely. i had sort of a vague idea about why this would be good. now I know exactly why. so thanks.
and i'm still interested in this.
Old Mar 30, 2009 | 10:11 PM
PhotoMunkey's Avatar
On a stock tire RX-8, the difference at the top of 2nd gear at 9k rpm is 68.84 mph versus 64.07 mph with the 4.77 gearing.
Mechanical leverage (torque) goes up by a little over 100 ft/lbs at the rear tires.
Yes, I am **** enough to have built an entire spread sheet which calculates this, taking into account everything down to exact tire circumference.
Old Mar 30, 2009 | 11:58 PM
Bad Ass
Or you can just use an RPM calculator online and save you some trouble! Lol!!
Old Apr 1, 2009 | 11:40 AM
rot8ing
is this sold or what? i asked for more pics -- closer, underside-- to assure me that it wasn't damaged in the wreck, but nothing.
Old Apr 1, 2009 | 11:49 AM
mrmazda7's Avatar
I will post pics this evening
Old Apr 1, 2009 | 12:17 PM
c41250n's Avatar
im sorry, but what ration is our stock diff?
Old Apr 1, 2009 | 12:38 PM
rot8ing
4.44
Old Apr 1, 2009 | 12:46 PM
c41250n's Avatar
thanks, so will the speedo or odometer reads not correctly?
Old Apr 1, 2009 | 01:21 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
no it has nothing to do with the speedometer
Old Apr 1, 2009 | 01:29 PM
Rpm calculator doesn't account for tire size does it? Or calculate ft/lbs of torque in each gear?
