Help me solve the mystery of the rear spring install
Old Mar 29, 2009 | 02:54 AM
416to212's Avatar
Utopia Taco Bell
I'd like to finally get down to the solution for the installation of a lowering spring on the rear of our cars. I have read that the service manual says that the spring can be replaced without the lower control arm being removed. Is this true?
Can anyone say that they have done a swap this way? I don't have a service manual or link to it either. I just want to make the lowering process as easy as possible for the rears.
EDITTED: 3/31/09
Old Mar 29, 2009 | 03:18 AM
Originally Posted by 416to212
I'd like to finally get down to the solution for the installation of a lowering spring on the rear of our cars. I have read that the service manual says that the spring can be replaced without the strut being removed. Is this true?
not true.
it cant be done. how hard is that.
google. or check the diy section here.
Old Mar 29, 2009 | 03:45 AM
DOMINION's Avatar
I don't buy Kool-Aid
I want some of what your smoking
Old Mar 29, 2009 | 12:31 PM
Charles R. Hill's Avatar
Owner of BHR
Are you saying that you have read somebody else's account of what the FSM indicates or that you read the FSM, yourself, and this is what you are understanding it to say?
The fact is that the entire damper assembly needs to be removed from the car in order to swap springs out but the factory damper, itself, does not necessarily need to be replaced in the process. Most people hold the opinion that the factory dampers go bad around 50K miles but I am not so sure about that, myself.
Old Mar 29, 2009 | 01:15 PM
laythor's Avatar
I zoom therefore I am.
This is one of those cases where "if it sounds too good to be true it probably is"...
Old Mar 29, 2009 | 07:28 PM
DOMINION's Avatar
^O Rly?
Old Mar 31, 2009 | 09:35 AM
416to212's Avatar
Utopia Taco Bell
I just realized where I FAIL'd. I said strut when I meant to have said Lower Control Arm.
So I'll ask again...
Can the rear spring be replaced without removing the lower control arm? I'm trying to see if I can get around taking out the alignment bolt, unneccessarily.
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
WingleBeast
22
May 23, 2016 09:22 PM
AussieGray
Jul 16, 2015 03:58 AM
