15A Engine fuse Power supply?
Old Mar 28, 2009 | 06:57 PM
Derex'8's Avatar
ReDuX
Hey does anyone know what runs off the 15A engine fuse located in the engine Bay?
Need to know this ASAP!!!!
I keep blowing this fuse and have checked every possible damn thing!!!!
Old Mar 28, 2009 | 08:54 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
It goes to quite a few things. I know you just put in a new ignition system, had problems, then solved them.....and now it's back. If you keep blowing this fuse, then you must have a problem in that wiring. One of the places it does go is to the coil system. I think I would really start with that ground and make sure it's really very solid. Then you need to makes sure nothing in that "new" wiring is shorting at all.
If you wanna PM me your regular E-mail address, I will send you the "electrical" portion showing the fuses and where they go. If you can't read a schematic, it won't do you much good though.
Among the places it appears to go............but not limited to are:
Power steering
ABS
Airbags
DSC
Immobilizer
And of course the Engine Control System.
mr. GrandGame
Sep 9, 2025 10:41 PM
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
delicious_dallan
Jan 17, 2020 09:17 AM
Crazy.8
Apr 18, 2017 03:17 PM
