hot air out of vents
Old Mar 27, 2009 | 07:39 PM
rx8revin's Avatar
I'm getting hot air blowing out of the vents even with the temp. **** turned to cold. Even with a/c on the temp. does not change. If I turn the temp. **** up the temperature gets extremely hot. Any ideas???
Old Mar 27, 2009 | 07:42 PM
DOMINION's Avatar
I don't buy Kool-Aid
The Rotary runs hot so its bound to be hot air. Plus its just hot out so its just letting in out side air.
Old Mar 27, 2009 | 08:05 PM
rx8revin's Avatar
It just started happening a few days ago. It's almost unbearable to drive the car with the vents on. It's alot hotter than the outside air even when set to cold. I'm thinking maybe something is stuck open.
Old Mar 27, 2009 | 08:49 PM
Juice's Avatar
I made some poos
HVAC Controls are broken, here is the fix:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-no-heat-repair-heater-control-158200/
Old Mar 27, 2009 | 09:00 PM
rx8revin's Avatar
I did that a few months ago and it worked great until now all off a sudden no cool air, just hot and gets hotter as I turn the temp. ****. The digital diagnostic on the display reads from 0-16 correctly as well so I'm stumped.
Old Mar 27, 2009 | 11:19 PM
AC Amp no good ?
or
a rock took your AC condenser with it ?
or
No Freon ??
or
The **** is broken again ?
Old Mar 27, 2009 | 11:48 PM
DOMINION's Avatar
OG poster oh ok well post 5 tells us a lot. You have had this issue in the past. Might have been a quick fix.
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
Aug 21, 2022 01:29 PM
RXFEVER
Aug 29, 2018 10:14 AM
Vedivan1
Sep 20, 2015 04:39 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
