Power Steering keeps going out
Old Mar 27, 2009 | 06:57 AM
johnrvw's Avatar
TX Power Steering keeps going out
The car's power steering light will come on occasionally & when it does, the steering is *very* difficult to turn. Sometimes the problem "corrects itself" after the car sits turned off for a while.
Any one had this happen to them or know how to fix without taking the car to the dealer.
Thanks,
J
Old Mar 27, 2009 | 07:42 AM
bse50's Avatar
#50
Fix the connectors by either replacing\tightening them or weld them in place.
This is a common problem, you should have searched
Old Mar 27, 2009 | 12:58 PM
Nubo's Avatar
Lubricious
Check this thread.
https://www.rx8club.com/showthread.p...hlight=covered
Old Mar 27, 2009 | 01:00 PM
dozer's Avatar
on his 3rd rx8
John, right under your airbox and right above your radiator is the PS connector, pull it apart and clean it with electronic duster/cleaner, youll see metal prongs on the inside just clean em up a lil and you should be fine
Old Mar 27, 2009 | 01:52 PM
jmc23200's Avatar
Might be time to change the power steering fluid
Old Mar 27, 2009 | 01:56 PM
2tone's Avatar
The RX-8 is missed
do all of the above, but i had this issue, under warrantly luckily, and they said my ps unit (i forget the exact term) was shot and they replaced it for free. i think it's kinda pricey, but that may be the end result for you if the above cleanings don't work...
Old Mar 28, 2009 | 12:31 PM
johnrvw's Avatar
Thanks for your help!!!
Thanks for all the help guys!!!!! I did do a search but couldn't find what I was looking for, but did copy my question from another website.
**Big help with the link to a past thread -- Thanks for that!!!!
I work the weekends but either Monday or Tuesday I will look at this and try to clean the connectors. I will let you know how it goes.
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
Fickert
Sep 9, 2015 01:21 PM
Tsurugi
Sep 7, 2015 08:27 PM
