best way to launch sotck rx8 at drag strip
Old Mar 26, 2009 | 08:19 PM
italianman1987's Avatar
hey guys, im taking the car to the strip with some buddies,
considering all the rubber that is layed down at the start, what you guys reccommend is the best rpm to launch the car at.
its obviously very different than the street, will the *** hop around or be smooth or still get wheel spin
on the street i usually do between 5-6k rpm, for the track what you say 4-5?
Old Mar 26, 2009 | 08:21 PM
tubingchamp's Avatar
What mawd bug?
9250 rpm.
Old Mar 26, 2009 | 09:29 PM
YaXMaNGTO's Avatar
It's a Cavalier
I would imagine if you go to the track and just drop the clutch at 4K RPM, you'll bog big time, but it depends on track prep. It could be ultra sticky, or it could be like launching on the street. You won't know until you try a few times. Try different things, and see what your 60ft looks like.
Old Mar 26, 2009 | 09:34 PM
jones75254's Avatar
Dont forget to post the slip info..
Old Mar 26, 2009 | 10:07 PM
wassup_nuthin's Avatar
I would say test the track out and try a few different rpms. when i go i usually go around 6.5 and feather the clutch a little bit. that was when i was stock, i need wider tires now seems my mods have made it a little harder to launch. wheel hop you most like still will get it now and then, just remember feather the clutch.
Old Mar 26, 2009 | 11:56 PM
YaXMaNGTO's Avatar
It's a Cavalier
Hey what was your time and trapspeed? 55 shot?
Old Mar 27, 2009 | 05:45 AM
wow,
drop the rear tires to 24 psi. and feather the clutch at ~ 4.5k rpm.. a quick feather..
now if you dont have the stock suspension you can up the stuff up a bit..
btw, with the stock suspension. any clutch drop is going to get you wheel hop. which is bad in so many ways. and time is not the most important..
Old Mar 27, 2009 | 10:07 AM
kersh4w's Avatar
Hit & Run Magnet
ok, so maybe my advice is going against what everyone just said here. but this is what works for me.
32psi
more than half a tank of gas (helps with traction)
4500 rpm
feather the clutch out
KICK THE MOTHERFUCKING CLUTCH IN AND SHIFT
shifting as fast as possible is key. remember to put the clutch in first then let off the gas, otherwise you will bog down the engine. if you want to see this in action, drive around in gear and let off the gas. what happens? even if its minute, for a fraction of a second, it stil matters in racing.
i am hoping if i ever get drag radials that i can run with an 1/8 tank of gas and launch at 7000rpm.
Old Mar 27, 2009 | 11:37 AM
Roaddemon's Avatar
I launch at 5k, make sure you turn off all traction control. Your launch will be much smoother and faster. You can gain several tenths just by following my advise. Guys are getting 14.5 -14.7 ave. quarter times with healthy stock rx8s.
Old Mar 27, 2009 | 11:46 AM
zoom44's Avatar
thanks to those actually trying to answer. the others i deleted
Old Mar 27, 2009 | 11:50 AM
CyberPitz's Avatar
Huge hole is huge
*Has never been to the drag strip*
*Is taking notes*
Old Mar 27, 2009 | 02:02 PM
kersh4w's Avatar
Hit & Run Magnet
ah of course, thank you roaddemon, ALWAYS turn off ALL traction control.
personally it is a half second difference for me.
i can run 14.5 no sweat with tc off, but that goes to 15.0 with tc on.
my 2.0 60 foots go to 2.2+ with traction control on.
Old Mar 27, 2009 | 02:15 PM
J03K1LLARX8's Avatar
ジョーイ
dude 5 1/2-6 is good. on street i do about 5 or just a little under. and i still get a tiny bit of spin. DO NOT 7 LAUNCH!! you will kill your LSD.
Old Mar 27, 2009 | 02:16 PM
dozer's Avatar
on his 3rd rx8
hold it at 8.5k and slowly feather the clutch out...thats the best launch possible
Old Mar 27, 2009 | 02:24 PM
ジョーイ
yes feather the clutch, that is the key. dont stright dump the clutch you will do some major damage to the LSD. sock LSD is only good rolling. now dead stop launch not so go for it.
Old Mar 27, 2009 | 04:01 PM
shazy's Avatar
*taking notes***
Old Mar 28, 2009 | 12:34 AM
wow,
this is so full of stupid i had to make note..
you let me know where i am wrong skippy...
btw, you need to have a good answer. or i am going to go to your post, and that is not going to be good..
Old Mar 28, 2009 | 08:20 PM
kersh4w's Avatar
Hit & Run Magnet
agreed. i know ranked autocrossers sidestep the clutch for the quickest launch possible, but.... they launch on r-comps. with street tires, you just get wheelspin.
i would sidestep the clutch, if i had drag radials.
Old Mar 28, 2009 | 08:23 PM
PSTNLSS's Avatar
The Former PSNTLSS
hmmmm. Feather clutch, as in just getting friction?
Old Mar 28, 2009 | 08:28 PM
kersh4w's Avatar
Hit & Run Magnet
no, its riding the clutch out.
like, you are giving quite a lot of gas, maybe 70-80%, maybe even 100%. it happens so quickly, im not quite sure what i do. i maybe giving it full gas. anyway..
and then you let the clutch out as quickly as smoothly possible. so basically, you have the clutch in for most of first gear. i probably finish letting the clutch out around 8,000 rpm.
Old Mar 29, 2009 | 08:35 AM
Roaddemon's Avatar
That is what I do to get the most power without breaking the tires loose too much. You have to go by feel. The car can really fly off launch if you know how to do it. I have a natural feel for it from motorcycles. Most owners do not know how to launch the 8. I see so many bad launches on You tube. Most don't even turn off the traction contol causing wheel hop all the way through 1st gear. That will cost ya a second right there.
Old Mar 29, 2009 | 12:18 PM
YaXMaNGTO's Avatar
It's a Cavalier
Go by feel, but measure it at the drag racing track by your 60 ft.
Old Oct 10, 2009 | 07:48 PM
damn guys so i took my baby to the dragstrip for the first time and bombed really badly... car is stock except for size 40 tires in rear, and intake.. but i need to replace my filter its very dirty i realized too late
i think since i was nervous i couldnt think straight and dropped the clutch every time... wheels kept spinning all through first gear... and my reaction time sucked.. but here are the 3 runs i had, my best was 16.14 how bad is this???
run:-----1------2--------3 ( note first run i launched at 6krpm second run at 3krpm and third at 2krpm)
rt-------.84----.57-----.61
60'-----2.8----2.6------2.5
330----7.1----7.0-----6.9
1/8----10.7---10.6---10.5
mph---68.8---69.1---76.7
1/4----16.4---16.2---16.1
mph---85.3---85.9---88.2
Old Oct 10, 2009 | 09:50 PM
Bigbacon's Avatar
2006 WB AT
I see you live in reston, where did you go to do this?
Also, it was your first attempt so it's probably not that bad.
Old Oct 11, 2009 | 12:28 AM
shazy's Avatar
So you launched at 2k rpm and got 16.14 seconds....
wtf, why would you even do that? Note, 5.5k rpm is max torque. I would launch around that area. If you are getting too much wheelspin, dont drop the clutch. Ride it out a bit.
