Which fuel sending unit is acting up?
Old Mar 26, 2009 | 07:10 AM
Paradox_Racing's Avatar
I've just got a quick question. I've searched but can find out how the dual fuel sending unit system works. Does one read high and the other low fuel levels, or are they averaged? The reason I ask is that on my 04 the fuel gauge stops reading at just below half a tank. It stops there and stays no matter how low the fuel level gets up to the point where I run out of gas. (Found out the hard way) Above that level it reads just fine (ie. from full all the way down to where it stops moving) I am trying to figure out where to start troubleshooting, but I don't know which side (driver or passenger) to pull first, or if I need to pull them both.
Old Mar 28, 2009 | 09:44 AM
Nobody??
Old Mar 28, 2009 | 09:49 AM
Correction - I was talking about something else.
Old Mar 28, 2009 | 07:55 PM
They are both averaged I think...you will likely find that one is stuck up
Best to pull them both and check. You want to have minimal fuel in the tank......about 1/8th ank or less so you don't have to play in all the gas
Old Mar 28, 2009 | 11:20 PM
Originally Posted by nycgps
replace ur fuel pump
the level sensor is on the pump itself
nope.
Old Mar 28, 2009 | 11:21 PM
^ I quit arguing a long time ago
Old Mar 28, 2009 | 11:27 PM
Originally Posted by swoope
nope.
hmm?
One of them is not working. So yeah, replace it? wrong ?
Old Mar 28, 2009 | 11:35 PM
I think he was pointing out that the sensor isn't on the pump
Old Mar 28, 2009 | 11:36 PM
hmm ... ok
Old Mar 28, 2009 | 11:55 PM
yep.
and note. if you dont connect the plug on the exhaust side of the tank. you get no fuel reading.
dee, dee, dee.
my observations. you have two fuel sensors. they are both inboard. tucked next to the hump in the tank.. i would guess that dan has it right. they average..
Old Mar 29, 2009 | 10:25 AM
Thanks for the replies. I wasn't planning on just replacing parts blindly, but I don't have the tool, so I didn't want to spend all day trying to get one ring off just to find out it was the other. Hopefully it's just stuck up, but I'll test them both. Thanks again! Oh, and BTW you can order the sensors separate from the fuel pump. They both have their own part numbers.
Old Mar 29, 2009 | 11:37 PM
When the tank is below 1/4 the fuel will be all in the drivers half of the tank in normal street driving. You can check the level sensor resistances from the pin outs on the top of the pump on one side..and the cover on the other. You should be able to tell what is happening if you add fuel...
Problem is...once the tank is filled..you will know which one isn't working....but you also will need to empty out the tank again to fix it
OnebaddRx8
Aug 25, 2019 11:34 PM
05rx8mazda
Nov 28, 2015 09:42 AM
GARCIAC951
Sep 10, 2015 07:17 PM
