oil leak please help
Old Mar 25, 2009 | 04:18 PM
Hesselrode's Avatar
US Navy Rotary Enthusiast
okay i thought it might be the omp from where it was coming from but it isn't.. it is on the passenger side of usa.. and there is a fork next to the oil pan.. when redlining it almost pours from that fork.. i think it might be squirting from the oil pan on to the fork and then dripping off is this possible and what is right above the fork i will post pictures next post
Old Mar 25, 2009 | 05:54 PM
teknics's Avatar
Certified Mazda Tech
if you have a fork in your oil pan you should definitely replace it....
but seriously i have no idea what youre trying to describe, maybe the engine mount bracket?
kevin.
Old Mar 25, 2009 | 06:14 PM
Hesselrode's Avatar
here r some pix
it is dripping off of the y bracket next to the oil pan any ideas? matbe squirting on the bracket and dripping down?
Attached Thumbnails oil leak please help-img_0068%5B1%5D.jpg   oil leak please help-img_0065%5B1%5D.jpg
Old Mar 25, 2009 | 06:35 PM
Hesselrode's Avatar
here it is circled, that is exactly where it is dripping from
Old Mar 25, 2009 | 10:52 PM
teknics's Avatar
could be just the oil pan but im thinking it looks like its coming from higher up, towards the OMP area, but it could be other things. hard to tell without getting under the hood.
generally oil wont squirt out of the oil pan, it doesnt have enough pressure pushing on it, oil pan leaks are generally more of a seepage situation. so if it is in fact squirting id look elsewhere.
kevin.
Old Mar 26, 2009 | 08:02 AM
Hesselrode's Avatar
it isnt the omp i removed battery and battery box and it isnt that it is further back..
Old Mar 26, 2009 | 04:54 PM
Hesselrode's Avatar
problem solved leaky oil pan gasket, btw is your guys oil pan gaskets the liquid goopy stuff? this one is... going to the cardboard gasket yay!!!
Old Mar 26, 2009 | 07:19 PM
teknics's Avatar
stick with just silicone, the gasket will make it leak easier believe it or not, theres a few old rotary tricks too but just use normal silicone.
kevin.
Old Mar 26, 2009 | 07:27 PM
StealthTL's Avatar
Metatron
Be careful not to get ANY goop in the bolt holes - it can crack the block.
Old school trick.....
S
Old Mar 26, 2009 | 07:39 PM
philipchan's Avatar
I think it should be the oil pan seal
mine is leaking too, after my engine changed by Mazda
but have no time to go back and fix it...
not a real big problem
many cars are leaking oil, but better check your oil level more frequently
Old Mar 31, 2009 | 02:51 PM
Hesselrode's Avatar
n/m on the gasket there is no such thing as a oil pan gasket from m azda on these cars... i used something called the right stuff works great!!... fixed it....
JimmyBlack
273
Feb 10, 2020 10:23 PM
Azki23
Jun 27, 2018 03:48 PM
WranglerFan
Nov 5, 2017 09:35 AM
Tsurugi
Sep 7, 2015 08:27 PM
