most powerful 13b-msp
Old Mar 24, 2009 | 07:35 PM
Hesselrode's Avatar
US Navy Rotary Enthusiast
does anyone know what the most powerful 13b-msp is? how much power does it have and what is done to it to get that?
Old Mar 24, 2009 | 07:44 PM
kersh4w's Avatar
Hit & Run Magnet
414whp
esmeril turbo kit
Old Mar 25, 2009 | 02:15 AM
AJ's Shinka's Avatar
Enthusiast
He is right Esmeril has the baddest turbo set up for your Renesis.
Old Mar 25, 2009 | 02:19 AM
m4f1050's Avatar
How reliable does your engine become at 414rwhp?
Old Mar 26, 2009 | 01:29 AM
less.
Old Mar 26, 2009 | 02:01 AM
Brettus's Avatar
Boosted Kiwi
Originally Posted by swoope
less.
Old Mar 26, 2009 | 09:53 PM
notorque's Avatar
I bid thee farewell
according to them they have more power than that now
Old Mar 26, 2009 | 10:33 PM
PhillipM's Avatar
less.
Old Mar 26, 2009 | 10:36 PM
shazy's Avatar
500whp? Now im guessing they can just burn 3rd gear with 275's in the back.
Old Mar 27, 2009 | 11:38 AM
lepichichi's Avatar
I LuV mY Rotary....
500????? wow i want one!
Old Mar 27, 2009 | 06:12 PM
Hesselrode's Avatar
is that all you can do is charge it and that is it? anything special you can do to it like higher compression rotars or maybe lower so we can do more psi? i know you can do weight reduction and stuff but i just want raw power and then i will lighten it if necessary... thanks
Old Mar 27, 2009 | 06:36 PM
kersh4w's Avatar
Hit & Run Magnet
higher compression rotors?
do you even know what the static compression is in our engine?
Old Mar 27, 2009 | 06:44 PM
zoom44's Avatar
ack.. nevermind thats just a can of worms i dont feel like discussing. suffice to say what you think is correct is not in regards to compression, power and PSI of FI
greg985's Avatar
The 337
yea I remeber when they hit 414 the guys said the tuning at top end wasnt 100%
Old Mar 28, 2009 | 09:15 AM
Hesselrode's Avatar
i just figured it would be like a piston engine in regards to lowering compression to dump more air into the engine without detonation...
Old Mar 28, 2009 | 09:19 AM
Hesselrode's Avatar
does anyone know what speed the 8 goes when having power like this? i know right now drafting off another car it goes 152 and without draft 148 stock but i don't know any other numbers.
Old Mar 28, 2009 | 09:21 PM
kersh4w's Avatar
Hit & Run Magnet
256mph!
Old Mar 28, 2009 | 09:56 PM
faster.
Old Mar 29, 2009 | 12:06 PM
Crimson's Avatar
registered noob
Hesselrode- do the math:
Air resistance ~= bV^2, where b is the combination of factors based on the air and the shape and size of the object.
Force from the engine's power output ~= power/velocity.
Top speed occurs when the force of the engine = force of the air resistance.
Assuming you're driving where they were when those top speed numbers were recorded, then you should get about the same top speed you calculated using these equations. If you can't do the math and figure out the new top speed at 414 hp, then you probably shouldn't be driving that fast(much less boosting that hard) until you get more familiar with the physics associated with cars.
Regards, Crimson.
Old Mar 30, 2009 | 04:50 AM
EinHeisserSchrei's Avatar
10,000 Revs in the Air!
Is the RX8 not limited to 160mph due to gearing?????
Old Mar 30, 2009 | 10:48 AM
greg985's Avatar
The 337
88mph
Old Mar 30, 2009 | 12:14 PM
PaPaBear's Avatar
PaPa Bear
http://www.youtube.com/watch?v=NqGhIftKrno
Old Mar 30, 2009 | 12:28 PM
Red Devil's Avatar
Lower compression is just as important to a rotary as to a piston engine in regards to FI. But you cannot use RX-7 low compression rotors in the MSP. And at the present there are no low compression Renesis rotors.
Old Mar 30, 2009 | 04:18 PM
Originally Posted by PaPaBear
haha thanks for that, brought back some great memories
Old Mar 30, 2009 | 04:22 PM
636's Avatar
636
Rice Police
Yup , and there probably never will be , now or in the future .
