Anyone running or any impressions of the new splined mazdaspeed frt sway bar
Old Mar 24, 2009 | 06:00 PM
conekiller2's Avatar
Dont know if its been mentioned, but for those running the mazdaspeed bar, is this the one you are running. Any thoughts on stiffness versus the stock bar. This is the bar im refering to
http://http://www.mazdaspeeddevelopm...ront-sway-bar/
Attached Thumbnails Anyone running or any impressions of the new splined mazdaspeed frt sway bar-0000-04-8302-ad11.jpg   Anyone running or any impressions of the new splined mazdaspeed frt sway bar-0000-04-8302-ad21.jpg
Old Mar 24, 2009 | 06:08 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
No. I seem to recall that one is off the charts for stiffness. Just buy the Hotckis MX-5 bar, near the Mazdaspeed rate, adjustable, and I think less money.
Old Mar 25, 2009 | 08:40 PM
it's not new, it's the Speedsource bar and they only finally got around to posting anything about it after being available for 3 or more years
1.25" OD x 1/4" wall will never work in Stock, you'll need 1/8" or less wall thickness for that diameter
Old Mar 25, 2009 | 10:02 PM
mwood's Avatar
Do they sell it only as a complete bar/lever/end link type deal, or can you just buy the levers and links? The splined torsion bar is easy enough to source...
Old Mar 27, 2009 | 12:34 AM
They sell the Tripoint arm/endlink setup separate from the bar for the 3rd gen RX7TT and it will work on the RX-8 with the proper length splined bar, but that kit costs over $500 + the bar cost
Old Mar 27, 2009 | 08:54 PM
MotoGeno's Avatar
Is there a benefit to running a stiffer front sway bar without changing the rear? Wouldn't this promote understeer?
Old May 24, 2009 | 02:22 AM
it depends on how stiff and also on the other adjustment settings such as alignment, air pressure, etc.
Old May 24, 2009 | 11:55 PM
always.anthony's Avatar
is looking for his torque
i think you can only get the front swapped for b stock. mazdaspeed one is good i hear, not too stiff, others like progress tech bars i have been told are too stiff to run with the stock endlinks safely.
Billy Marcial
Mar 1, 2018 06:50 AM
Modified Dave
Sep 19, 2015 08:58 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
MolecularConcept
Jul 26, 2015 09:09 PM
AussieGray
Jul 16, 2015 03:58 AM
