Rattling exhaust @ idle.
Old Mar 24, 2009 | 05:08 PM
GeoffJ's Avatar
Hi there,
Anyone have any clues why my exhaust rattles when stopped at traffic lights. It makes a pop sound, or sometimes a tick,tick,tick......vibrating sound OR sometimes it doesnt happen at all. Could it possibly be a clogged cat? Any help would be great.
Thanks,
Geoff
Old Mar 24, 2009 | 05:13 PM
dozer's Avatar
on his 3rd rx8
can you be more specific...does the sound come from the back? under the car? engine bay?
Old Mar 24, 2009 | 05:20 PM
GeoffJ's Avatar
The back, thanks for fast reply.
Old Mar 24, 2009 | 05:30 PM
swiftnet's Avatar
Cat is breaking up.....
Old Mar 24, 2009 | 05:37 PM
GeoffJ's Avatar
Meaning its most likely clogged?
Old Mar 24, 2009 | 06:16 PM
Put it up on a lifit and check it out.
Heat shield, bad exhaust gasket, etc...........
Old Mar 24, 2009 | 06:19 PM
swiftnet's Avatar
No, I mean literally breaking up. The cat is a ceramic honeycomb. The ceramic is broken. Little pieces knock around in the connector pipe causing random noise. If you can get it up on a lift, disconnect the pipe between the cat and muffler, tap it with a rubber mallot and pieces of your cat will fall out...The cat is under warranty for like 80 or 100k. The problem with a broken up cat is that little pieces are going to lodge in the muffler. Mazda replaced both the muffler and cat on my 8.
Old Mar 24, 2009 | 06:32 PM
GeoffJ's Avatar
Thanks alot guys, will explain to mazda and hopefully get a quick fix.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
Jb4ker96
Sep 27, 2015 10:06 PM
