a/c mod?
Old Mar 24, 2009 | 04:24 PM
JohnnyFamous's Avatar
a/c mod?
Is there an A/C mod for this car? Like removing the belt from the ac compressor. My buddy was saying he did this on his z3 and improved performance .
Old Mar 24, 2009 | 04:40 PM
Juice's Avatar
I made some poos
You can easily remove the belt for the AC compressor. If I remember, the entire system weighs 18lbs so there is some weight loss if you want to go that route too.
Problem is that the AC won't kick in at WOT and high RPMs so there isn't much of a point. Also consider that turning the AC off is essentially removing any parasitic loss since the pulley for the compressor will just be free spinning.
Do it if you want, but there isn't much of a point unless you remove the entire system for the weight loss. Even then, do you want to go through that for 18 pounds??
Old Mar 24, 2009 | 04:43 PM
myriadshalaks's Avatar
rot8ing
there a couple. check the diy section. i think there is one where you can just hold a button for a while, and that makes it 10 degrees cooler.
Old Mar 24, 2009 | 06:19 PM
Don't do it!
You get a boost like nitrous.......... mu ha ha........
Old Mar 24, 2009 | 07:22 PM
kersh4w's Avatar
Hit & Run Magnet
i had my a/c on during an HPDE.
i was still passing people.
my driving skill (while allowing me to constantly pass people in the green group) just wasnt high enough to make a difference for the few seconds the a/c would be on. and as pointed out, the a/c shuts off above 65% throttle and 5500rpm.
Old Mar 24, 2009 | 07:37 PM
This power lost by the belt drag?
RevMeHarder
Jun 1, 2026 02:30 PM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
nadodave
Aug 28, 2019 05:55 AM
FubarI33t
Sep 28, 2015 08:45 PM
djp6783
Sep 19, 2015 12:12 PM
