Courtesy Light Removal
Old Mar 24, 2009 | 04:42 AM
sw-ontarioguy's Avatar
Ok guys, I've searched and searched, and can't find how to remove this little buggers! I bought red led replacement bulbs for the courtesy lights in the doors, and the trunk light. I don't understand the round plastic holder they are in. If I use a screwdriver, I can push them in, but then how do you get at the bulbs?
If someone could shed some light on this, you'd be my hero
Old Mar 24, 2009 | 10:53 AM
L337fpc's Avatar
ლ(ಠ益ಠლ)
Umm, use a flathead, and depress the plastic clips. Its a 30 second job per light. The only PIA is the Map LEDs.
I got mine from RX8Strakes...and they had instructions. But it was quite easy.
Old Mar 24, 2009 | 11:24 AM
Socket7's Avatar
ಠ_ಠ
I removed the door panel to change mine, but I was back there for other reasons too (installing speakers). you should just be able to pull the old bulb out and push the new one in. Theres no trick, but the bulb holders have a habit of falling into the inside of the door and need to be fished out.
Old Mar 24, 2009 | 11:52 AM
I must be handicapped because I can't get either of them out. I guess I'll just wait til sunday when I put my sound system in and have the panels off.
Old Mar 24, 2009 | 12:08 PM
J8635621's Avatar
Pew Pew Pew
Look on the bottom of the clear light cover and you will see a little indention. Just put the screwdriver in there and pry the cover off. It takes 30 seconds and little to no effort.
Old May 7, 2010 | 01:53 AM
DJAlexJaramillo's Avatar
MY **** FELL IN!!!!!! how do i get that damn thing out without takin out the door panels?
Old May 7, 2010 | 02:20 AM
BG-8's Avatar
it will be very hard without taking the door panel off. your best bet would be to crack open only the lower left corner of the door panel (only two clips hold that corner), and if you have small hands rich in it and put it back into place. Otherwise you have to take off the hole door panel.
While back I needed to see what color cables were going into the light, so I just open that corner by the light and looked in. But there was enough room to work on it too, if I needed to.
Let us know how it goes...
RevMeHarder
Jun 1, 2026 02:30 PM
Azki23
Jun 27, 2018 03:48 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
wayloco
Sep 1, 2015 09:03 PM
