rx8 AC problem
Old Mar 23, 2009 | 07:12 PM
kenshow2003's Avatar
UK rx8 AC problem
hi there
I tried to use ac 2 days ago because it was very hot.but heard that the compressor keeps engage and disengage about every 5 seconds.(cold air-warm air-cold air-warm air^^^^)I thought the gas was low so I just regassed the car. but the compressor is still doing that.
any one know whats wrong with it?
Old Mar 24, 2009 | 03:01 AM
Nubo's Avatar
Lubricious
Originally Posted by kenshow2003
hi there
If yours is a 2004 within certain build dates, it's possible that you need to "reprogram the amplifier". The notice pretends that it's all about recirculation but it appears to make a major difference in the duty cycle as well, if you have one of the applicable amplifiers.
AC NOT COOL (AFTER 9/11/03 PRODUCTION)
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 40118171 ********
Some customers may complain of lack of AC cooling from the vents. This may be caused by the intake air selector (recirculate / fresh) in the "FRESH" mode. Cooling the interior of the vehicle may take longerif the air intake selector is in the "FRESH" mode. Maximum cooling is acheived when the intake air selector mode is in the "RECIRC" position. The AC amplifier can be programmed to automatically default to "RECIRC" mode when the following conditions are met: 1. Ambient air temperature is 68 deg. F or higher. 2. HVAC control mode is in "FACE" mode. 3. HVAC temperature is in maximum cool setting. Customers with this concern should have their vehicle repaired using the repair procedure. NOTE: Vehicles produced before 9/11/2003 are not programmable N should have the AC amp replaced per Service Bulletin # 07-002/04 1. Verify concern. 2. Verify ignition switch is in OFF position. 3. Press and hold the front defrost and air intake selector buttons simultaneously. 4. Turn the ignition key to the "ACCY" position for 3 seconds. (Continue to hold the buttons down from step #3.) 5. Turn the ignition key to the "ON" position for 3 seconds. (Continue to hold the buttons down from step #4.) 6. Successful programming will be confirmed by the rear defrost indicator light flashing 3 times. NOTE: If vehicle's battery dies or cables are removed, the programming will not be retained and must be performed again.
Old Mar 24, 2009 | 02:16 PM
EDZRIDE's Avatar
2005 White GT
What are your gauges reading??
Old Mar 24, 2009 | 02:37 PM
troutfisher73's Avatar
The cycling that you described can be a symptom of low refrigerant charge (which would indicate a leak somewhere in your AC system). I'm afraid you're going to have to take it to a automotive AC shop to get it properly tested though.
Old Mar 24, 2009 | 10:31 PM
I just regassed the car.unluckly no different at all
Old Mar 25, 2009 | 07:35 AM
The gauges seem ok.
Old Mar 25, 2009 | 11:56 AM
Nubo's Avatar
Lubricious
Did you try the reprogramming?
Old Mar 25, 2009 | 04:57 PM
EDZRIDE's Avatar
2005 White GT
The gauges seem ok.
What pressures are they showing?
Old Mar 25, 2009 | 05:32 PM
It recycles between cold and warm all the time its normal.
You should take the car out and drive it. I bet it works just fine.
Old Mar 25, 2009 | 08:04 PM
i tried but it seems not working with that methord on my car
Old Mar 25, 2009 | 08:08 PM
Smile
came back from AC automotive shop.they check the system and regassed again.thay said it was a bit low(should be 41 but only got 29 in my car.i dont know that 41 and 29 mean)
they said nothing wrong.no leaking.all the rx8 is like this
I may just leave it
thaanks all you guys for the help
Old Mar 26, 2009 | 09:15 AM
EDZRIDE's Avatar
2005 White GT
I may just leave it
Sounds like the low pressure saftey switch was doing it's job; glad it turned out well.
ladnarf1
Apr 29, 2021 11:53 PM
Skyl3r
Dec 2, 2019 04:51 PM
SIllver
Aug 1, 2015 07:34 PM
Belalnabi
Jul 22, 2015 04:50 PM
Belalnabi
Jul 17, 2015 07:48 PM
