View Full Version : shaking under 2000 rpms
chrizknot 03-23-2009, 07:19 PM car shakes slightly when starting to accelerate ( up to 2000 rpm). it almost feels like less power. sometimes i feel it, sometimes i dont. there is no check engine light. it feels like it looses power all together when driving, but that could be inmy head. any suggestions?
Jedi54 03-23-2009, 07:29 PM does it shake a bit when you're at idle?
My first thought was a bad motor mount but you say you feel a loss of power?
shazy 03-23-2009, 07:32 PM Check Coils and plugs. It's probably time to change it, but you didn't mention any of that.
Jedi54 03-23-2009, 07:33 PM yeah, if the car feels like it's shuddering while accelerating its' probably bad coils / plugs.
can you give us a bit more details?
what year is the car?
how long have you had the plugs, coils?
OEM cat?
original engine?'
chrizknot 03-23-2009, 09:14 PM i have under 40000 on it , 2004. the only problem is it sometimes doesnt do it. it idles fine. the most recent think i have done to the car was add the new greddy se exhaust in december. it the orig engine, orig cat, last summer i got new plugs (there was a recall).
the first time i felt it was after driving it on a really wet day, rainy and humid, but i have done that before and no problems. if it were the plugs, wouldnt a check engine light come on?
warren(silver-roxy-8) 03-23-2009, 10:13 PM i have the exact same problem!
Alexb 03-23-2009, 10:26 PM does it shake a bit when you're at idle?
Mine does this!
I have no loss of power, but sometimes while at a stoplight and in neutral, the seats shake like they do when you have a bad start in 1st. Like that feeling/shake you get when about to stall.... I've had the car for 6 months, I have just ignored it... figured it was regular... so far no problems.
chrizknot 03-24-2009, 05:08 PM well i took the car into mazda today. the vibrations were from my after market exhaut they said, due to the fact it fits on tighter than the stock exhaust. I also had a ""loss of power recall"". strange.
warren(silver-roxy-8) 03-24-2009, 05:10 PM is ur car an '05?
Jedi54 03-24-2009, 05:16 PM Mine does this!
It's probably a combination of the a/c condensor kicking on (normal) and a cracked motor mount.
you still under warranty? If so, you could get the dealership to look at / replace the mount for free (I did)
Jedi54 03-24-2009, 05:17 PM well i took the car into mazda today. the vibrations were from my after market exhaut they said, due to the fact it fits on tighter than the stock exhaust. I also had a ""loss of power recall"". strange.
exhaust causing vibrations?! WOW, can't believe they fed you that line...
which exhaust do you have? "fits tighter"?
chrizknot 03-24-2009, 05:30 PM greddy se
Razz1 03-24-2009, 07:22 PM Its the motor mounts. Check that first, worry about your head issues later.
swiftnet 03-24-2009, 07:27 PM Sounds like motor mounts to me, although at 40K stock coils are living on borrowed time.
