Electrical problem.. HELP PLEASE!
Old Mar 22, 2009 | 02:58 PM
lilring's Avatar
Finally a MT
I had trouble starting my 04 auto today.
I got in turned the key to start it and al my lights just flickered and the starter would not turn the engine over.
So i chilled listened to some music and tapped the brake a few times and my dash lisghts started to get brighter.
So i tried starting it again. this time starter turned the engine over but my lights were still flickering. As the starter was turning the engine over it would seem to get faster. /then fianlly the engine started.
It seems i had a little electrical grmlin. Any ideas what it could be? maybe a grounding issue?
Old Mar 22, 2009 | 03:00 PM
laythor's Avatar
I zoom therefore I am.
hmmm.. an object that requires a battery seems to have problems starting.... what could that be.......?
i'll give you a hint...
expo1's Avatar
He's as bad as Can
Battery on the way out.
Old Mar 22, 2009 | 03:03 PM
Easy_E1's Avatar
3 out of 3 RX8 nuts suggest the "Battery".
Old Mar 22, 2009 | 03:04 PM
StealthTL's Avatar
Metatron
Might be a loose terminal,
but most likely.......battery.
'04, never had it replaced? Almost certain.
Old Mar 22, 2009 | 03:39 PM
lilring's Avatar
Finally a MT
The battery was replaced one year ago and Terminals where cleaned with a steal brush.
So you guys a saying a weak battery gets stronger the more you use it when the car is not running? That does not make sense to me.
After the cAR started i shut it off and tried starting it agin and it started right back up.
Old Mar 22, 2009 | 03:42 PM
laythor's Avatar
take the battery out and test it. if you don't have a tester then take it to a car parts shop that can test it for you. I'll bet you a donut that it's bad.
Old Mar 22, 2009 | 04:07 PM
lilring's Avatar
Finally a MT
Tested it. After i put load to it, the voltage seemed to fluctuate. So I'm thinking its got a bad cell.
I wounder what caused that to happen.
Old Mar 22, 2009 | 04:17 PM
laythor's Avatar
what kind of battery, stock?
Old Mar 22, 2009 | 04:19 PM
^^ Life Batteries are fickle...the cheaper the battery the more fickle they tend to be
That doesn't mean the most expensive are better either ........Some of the more expensive batteries out there are crap!
Old Mar 22, 2009 | 04:34 PM
lilring's Avatar
Finally a MT
It is a stock battery but they replaced it in april of last year when they did my engine.
What kind of battery should I look into?
Old Mar 22, 2009 | 04:39 PM
laythor's Avatar
lots of people have gone with the optima yellow and red tops. search for battery and you'll find a bunch of threads about it.
yurcivicsux
192
Sep 12, 2017 10:54 PM
Evan Gray
Nov 24, 2015 01:00 AM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
