Headlight moisture.
Old Mar 21, 2009 | 10:10 PM
MazdaEight's Avatar
Headlight moisture.
OK, so I went ahead and got the moisture out of my tailight, but my drivers side headlight gets moisture collected into it also. I can't use the method I used for my tailight because the headlight doesn't have a gasket like the tailight. Does anyone know a way to fix this problem? I found this thread here:
https://www.rx8club.com/forum/showth...light+moisture
Has anyone else tried this?
Old Mar 21, 2009 | 11:03 PM
Old Rotor's Avatar
Have you seen this "TSB"......sorry this is for tail lights...
http://www.finishlineperformance.com...05-09-2055.pdf
Old Mar 22, 2009 | 12:38 AM
lilring's Avatar
Finally a MT
Hey i have that same problem. but mine is very little.. but I have a quick stuiped question.. I have the 04 and my B2B warranty is out.. Can i still go have that TSB done without payin anything?
Old Mar 22, 2009 | 01:33 AM
MazdaEight's Avatar
Originally Posted by Old Rotor
That TSB is for tailights....I need help solving the moisture buildup in my headlight.
Probally not.
Old Mar 22, 2009 | 09:43 AM
SilverHokie's Avatar
I'm Delaware Fast
If your car still has the bumper to bumper warranty, and you show the service tech that, they will replace that headlight. I had mine replaced for corrosion...now they are nice and shiny!
Old Mar 22, 2009 | 06:40 PM
MazdaEight's Avatar
No bumber to bumper left. I went to the dealership and they wanted $1200 for a new headlight...INSANE!
Old Mar 25, 2009 | 06:51 PM
MazdaEight's Avatar
Man....nobody knows how to get the moisture out of a headlight, or if the thread in the OP works??? It sucks...that moisture makes my nice car look like junk.
Old Apr 19, 2009 | 12:10 PM
MazdaEight's Avatar
Well I spent a few hours the other day removing my front bumper and trying the method used from the thread in my original post, but had no luck. The moisture is still there. I was gonna try baking the headlights to reseal them, but there are so many wires and removing the HID ballast and all that I didn't want to risk damaging my headlight at the cost of $1200 for a new one. So what I am getting at is...No one knows anyway to fix this problem???
Old Apr 19, 2009 | 12:40 PM
RX-8.40's Avatar
Drive the Revolution!
I'm not a mechanic, but I saw a guy drill two tiny holes in the back taillights of an rx8, then use a $5 can of compresed air with the tiny tube to dry out the inside of the tail light. This same technique might work on the front lights. The only thing is that you probably need to find something to plug the wholes with after so no additiional moisture gets in. no guarantees it will work so be careful.
Old Apr 19, 2009 | 12:49 PM
Renesis07's Avatar
Vtak just kicked in yo!!
ebay headlight FTW!!!!
or
drill a little hole...
Mine collects a little moisture here and there but everytime it just evaporates with no traces that it was ever there. Give it a day or two and see what happens.
Shankapotamus3
Mar 14, 2021 03:53 PM
drlubell
Sep 26, 2015 11:58 PM
vapor2
NW RX-8 Forum
Sep 17, 2015 07:43 AM
yankeepicker
Sep 11, 2015 05:42 PM
