Traction Control Light
Old Mar 21, 2009 | 12:05 PM
two zero two's Avatar
Unregistered User
the past two days i've had a warning light come three times on while driving, the yellow triangle with the car swerving.
i'm not doing anything to set off the error, it's all been under normal driving conditions, however it doesn't seem like drivability is affected.
the second time this happened the tach blipped down to zero right as the light came on then shot right back up and the light came on.
does anyone know what might be causing this, sensor? fuse? thanks
Old Mar 21, 2009 | 12:16 PM
StealthTL's Avatar
Metatron
Sounds like a loose battery post connection - the steering is very sensitive to loss of power.
Old Mar 21, 2009 | 12:45 PM
Unregistered User
Thanks Stealth, just scraped away a few layers of corrosion from the terminal, most likely the cause
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
garethleeds
Europe For Sale/Wanted
Nov 19, 2015 06:32 AM
yankeepicker
Sep 11, 2015 05:42 PM
