Need advice for fitting +25 offset wheels
Old Mar 21, 2009 | 05:53 AM
an82nv's Avatar
I need some advice from all you wheel/tire experts. I came across a great deal for some PIAA Super Rozza wheels. Only problem is they are 19x9 +25 & 19x10+25. Do you'all think this offset will work on the 8. I don't want ridiculous camber or rubbing, but I'm willing to adjust with tire sizes to make them fit. I already have rear fenders rolled, so that won't be an issue. I tried searching for similar setups, but couldn't find anything.
I'll greatly appreciate input from anyone with experience in this area. Thanks!!
Old Mar 21, 2009 | 06:00 AM
You are going to have to try them and see what happens
The rears are going to rub with 275's bad...but you might get away with 255's and a roll and camber. The outer rim is about 15mm further out than 9.5 35 offset that usually rub so not feeling that great about your chances
The fronts you might get away with.....but they will likely be a problem as well
Not the best offsets at that width...
Old Mar 21, 2009 | 09:39 AM
nuke0907's Avatar
Never Blend In
just FYI, me and dannobre are running 18x10.5 +43. thats about as extreme as you want to go without having some ridiculous camber and fender mods.
Old Mar 21, 2009 | 12:27 PM
type59's Avatar
mrjackwong
what is ridiculous camber to you? 3? with fenders rolled you could pull off 225 and 255 tire with maybe 2.3 and 2.6 camber.
Old Mar 21, 2009 | 01:50 PM
Ridiculous camber is more than you need for tire performance and that depends on tires...
So by default...any time you have to add more camber than necessary to make the incorrect offset wheels fit is ridiculous
Old Mar 21, 2009 | 02:05 PM
19x10 +25 is a no go.
nuke is right, with a wheel that size, you want something close to +42 or +43
Old Mar 21, 2009 | 03:56 PM
nuke0907's Avatar
Never Blend In
well if you like buying new tires go for it.
i have nearly stock alignment and no fender mods. but hey i dont know what i'm talking about.
Old Mar 21, 2009 | 11:00 PM
T-ReX-8's Avatar
Stormtrooper RX8??
17X10 +25s barely fit, and that is with decent work.
19s are a no go. Even at stock height.
Old Mar 23, 2009 | 07:25 PM
the_duke313's Avatar
https://www.rx8club.com/rx-8-parts-sale-wanted-44/fs-ssr-sp1-165583/
Old Mar 23, 2009 | 07:45 PM
type59's Avatar
mrjackwong
you just have to work for it. 10 +30 plus offset sounds sad...
Old Mar 30, 2009 | 02:22 AM
Rx8urZ's Avatar
If you do try it you should post up pics.
Old Apr 15, 2009 | 12:14 AM
DOMINION's Avatar
I don't buy Kool-Aid
Any update? I want to see
WingleBeast
22
May 23, 2016 09:22 PM
codesterb91
Nov 16, 2015 05:57 PM
R2D2X8
Aug 17, 2015 08:47 AM
Mr.Durden
Aug 12, 2015 02:21 PM
Brandonien
Jul 30, 2015 12:33 PM
