How many missfires are normal in a drive cycle?
An RX ate my baby
I've got an '06 GT 6MT, I bought it new and it now has 30k on the clock. I changed the spark plugs about 6 months ago, and I have kept up with the flash updates.
I run 89 octane 76 gasoline, I get better gas mileage with that than 91 super and it doesn't knock.
I got an OBDScan-Apex for my birthday with the RX8 specific software and I've been playing with it. I've never had a CEL and the car runs fine.
I've got an average of 11 missfires for rotor 1 and 4 missfires for rotor 2 over the last 10 drive cycles. Is this normal?
An RX ate my baby
Note that my CEL has not blinked, either. I think you have to have multiple missfires in a row to make the CEL blink. Monitoring the OBDII port while driving only gives me a single missfire when I romp on it really hard.
avg of 11 misfires and 4 misfires over 10 cycles?
What about on the 1 previous drive cycle?
The rx8 requires a LOT of misfires to trigger the CEL light and a 0300-0302 misfire code.
11 and 4 is about normal really, your car will always misfire on startup and turn off, misfires happen all the time really. a major/dead misfire is different then a regular misfire. Minor misfires are quickly and easily adjusted for by the pcm, and fully expected.
I think you need to be in the 100's to trigger a CEL, i've seen cars come in with close to and over 100 misses on the previous drive cycle and they dont even notice and the light doesnt go on. I generally check coils and replace plugs when i see that. That's one of the specs that gets widen with the PCM flashes on these cars, it used to be a close tolerance but mazda realized that was a bad idea. On piston cars the misfire light is trigger with only a few misfires, on the speed6 all you need is 1 single misfire to set a light lol.
kevin.
kevin.
Touge
Canada Forum
Aug 19, 2015 11:00 PM
RotaryRider
Jul 20, 2015 07:05 AM
i dont think so...ive only had like 1 misfire in 2 years...my CEL blinked then turned off...never had misfire since then
