someone came on my headlights
Old Mar 20, 2009 | 01:32 PM
kersh4w's Avatar
Hit & Run Magnet
it looks like that anyway...
when i put my clearbra on i stupidly did not wash the baby shampoo off the headlights immediately. i let it dry on overnight. afterwards, i couldnt get it off... -_-
yesterday i removed a sticker from my rear window and put a new sticker on there. USMC. i removed the old gunk with goo gone.
as i was passing my headlights i thought hey, lets try this goo gone on the headlights. instead of trying it on a corner i sprayed it over the whole headlight.
it got really foggy and the paper towel got all yellow. which i assume was the baby shampoo. but.. the headlight is now all foggy. my brilliant idea was to spray more goo gone on it.
flabbergasted i got the wd-40 and a bit came off. but in the center where i really layered the stuff, it's not coming off.
any ideas on how to clean the headlights?
Old Mar 20, 2009 | 01:47 PM
dillsrotary's Avatar
jersey fresh
Old Mar 20, 2009 | 02:08 PM
RK's Avatar
RK
It's Not Easy Being Green
I'd try rubbing alcohol and a toothbrush. Stronger than WD-40.
You might also try to wash it with dishwash soap (ie. Dawn). That usually works at getting other soaps/protectants off.
Just be careful not to get dawn or alcohol anywhere other than your headlight.
Old Mar 20, 2009 | 02:14 PM
Alexb's Avatar
desperately needs a drop
There is headlight cleaner stuff... but I don't know if it will help get the stuff that you put on off...
Old Mar 20, 2009 | 02:20 PM
2tone's Avatar
The RX-8 is missed
not sure if it would work but seems to work pretty well on grime/oxidation. a bit expensive but cheaper than a new headlight if the home remedies don't work...
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/headlight-restoration-great-product-169039/
Old Mar 20, 2009 | 03:16 PM
robrecht's Avatar
I would take a look at this 3M stuff also:
https://www.rx8club.com/rx-8-show-shine-26/3m-headlight-lens-restoration-system-169320/
Old Mar 20, 2009 | 03:25 PM
myriadshalaks's Avatar
rot8ing
sorry about that. i thought it would wash off. i couldn't help myself. the car is hot. .
Old Mar 20, 2009 | 06:04 PM
cjkim's Avatar
^noob
wet sand/compound/polish?
Old May 2, 2009 | 05:02 PM
Kyanbi's Avatar
Just so you know, author of this forum, I laughed at seeing your thread title. It's my birthday and I really appreciate that extra humor; thanks!
Old May 2, 2009 | 06:40 PM
ferg's Avatar
sand them down and get some auto clear coat and spray them
Old May 3, 2009 | 03:39 PM
rled's Avatar
5Picker
If the lens was partially dissolved causing a real foggy look, locate you some Micro Mesh . It goes from 1000 grit to 6000 grit. Sand it with the micro mesh . Try the 6000 grit first and see if it is smoothing the surface. Add a little of liquid soap for lubricant for the micro mesh. Once it is smooth, polish it with the liquid polishing stuff that comes in the kit. I would try Meguires liquid PLASTX first. It works great on my headlight lenses.
Old May 3, 2009 | 05:50 PM
ferg's Avatar
when i read this post, it sure sounds like someone came all over your headlights, nasty
Old May 4, 2009 | 02:59 AM
White_Shadows's Avatar
Use the Mequires PlastX just rub and rub and rub, it took brakefluid damage off my motorcycle guage I'm sure it'll pull that off as well.
Old May 4, 2009 | 06:32 AM
REsuperD's Avatar
zoom zoom
+1
any other similar mild abrasive should work also
Old May 4, 2009 | 04:36 PM
UrbanOcho's Avatar
Stick Specialist
Smile
have to admit to that as well LOL even though it is a ****-uation for the author....
Old May 4, 2009 | 04:41 PM
Atilla's Avatar
I am THAT guy
Kersh..................wtf have you been doing with your car??
I understand you love your car...but come on man....the headlight???
...maybe the gas tank.....maybe
Old May 4, 2009 | 04:55 PM
Grungepup's Avatar
Oilfield trash
you post *****
Old May 4, 2009 | 08:55 PM
warren(silver-roxy-8)'s Avatar
no sleep til it spools
break cleaner cleans off anything....after you use that, take some windex too it to get the break cleaner **** off..and voila, it's clean again
Old May 5, 2009 | 09:06 AM
YeahYeahYouWere's Avatar
Call me ROTO BAGGINS
Meguiar's PlastX is basically like a liquid sandpaper with diminishing abrasiveness - it should work to de-spooge your lights, and a bottle of it is only like $8 or so. But, be prepared to rub the hell out of it (sounds like you already did, zing!), because you've really gotta put some elbow grease into it.
Old May 12, 2009 | 03:52 PM
Nubo's Avatar
Lubricious
[EMBED]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/oRLbPg22gWw&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/oRLbPg22gWw&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/EMBED]
Old May 12, 2009 | 04:21 PM
hollistar_4's Avatar
Hollistar_4
i would just take it to a good body shop, and they should be able to buff out your headlights, i have done this on other plastic headlights, works great
Old May 12, 2009 | 05:30 PM
Alucard's Avatar
RX8 Club OG
if you want to go out and buy some products... i recommend the stuff below... use a drill with the power ball to buff... it will get your headlights looking like new...
step 1:
http://www.meguiarsdirect.com/produc...p?T1=MEG+M1708
step 2:
http://www.meguiarsdirect.com/produc...p?T1=MEG+M1008
Old Aug 5, 2009 | 02:42 PM
FrankTome89's Avatar
engine degreaser
Old Aug 5, 2009 | 07:50 PM
DarkLord7854's Avatar
Software Engineer
New headlight.
Old Aug 5, 2009 | 09:55 PM
shakeyourbrakes's Avatar
wow some of these answers are horrible, dont use rubbing alcohol, and dont use some crazy rubbing compound (it wont be enough to resurface the lens), theres a good chance youll just damage them more. Ive had a lot of experience cleaning our headlights, start with 600 grit sandpaper (wet) and run it across the headlight in one direction, not back and forth. Repeat the steps with soaking wet 800 grit, then 1000, then 1500, then 2000 (if you can find it) on a wet headlight lens in one direction everytime, then use some plastic polishing compound (autozone) and rub back and forth in small sections. Use the plastic polish about 4 times, and you should be looking at clear headlights. Dont get discouraged if after the 1500 or 2000 its still foggy, the compound will clear them. You need to resurface the headlight basically it sounds like, but you dont need a new one from fogging from goobeegone. good luck, take your time, it works like a charm
