Axel Boot Replacement....on a civic
Old Mar 18, 2009 | 10:26 AM
getdamafiaonyou's Avatar
Does anyone know where i can find a diy on how to change the axle boots on a 98 honda civic? ive searched google and every one i found didnt have pictures anymore, they had been removed. and i'd much rather not spend four to five hundered dollars when i could spend thirty.
Old Mar 18, 2009 | 10:29 AM
Just get new cv assemblies, don't bother just replacing the boots. Pull wheel, loosen axle bolt (impact required), loosen tie arms and pull hub assembly away so the axle comes out, then yank the axle assembly out of tranny. Reinstall in reverse order.
Old Mar 18, 2009 | 10:39 AM
i was just reading and ill just do the whole axel. and you sure i need an impact gun? i didnt read that anywhere.
Old Mar 18, 2009 | 10:41 AM
dozer's Avatar
on his 3rd rx8
makes the job easier
Old Mar 18, 2009 | 10:54 AM
I have seen axle bolts so tight the wheel will turn while the car is on the ground when using a breaker bar. It may come off easy, it may not.
Old Mar 18, 2009 | 12:29 PM
alright i'll rent one form autozone...lol.
urbanvoodoo
Sep 30, 2015 12:41 AM
WingleBeast
Sep 9, 2015 10:10 AM
Red line envy
Aug 22, 2015 06:07 AM
