Bg 44k
Old Mar 17, 2009 | 05:23 PM
PSTNLSS's Avatar
The Former PSNTLSS
Thumbs up Bg 44k
Well, my 8 has almost 39,000 miles on it. Before I put my agency power pulley on, and exhaust I decided to try to gain power back and/or go to the dealer to check compression to see if I needed a new engine etc. I have long been a fan of picking up some Oil Filters from Rosenthal Mazda in Virginia. They are great people. Ordered and shipped and recieved within 3 days.
I went through there website. Picked up the Zoom Power Clean, to attempt a nice clean out before I do some more engine modifications. I came across this product BG 44K. It is $20.00 and figured I'm already ordering something, why not try it.
The product claims "BG 44K® Power Enhancer® safely, rapidly and thoroughly removes engine deposits in combustion chambers, intake manifolds, ports and on valves. It restores flow in fuel injectors and cleans the entire fuel system. BG 44K® Power Enhancer® improves fuel economy and reduces exhaust emissions. It restores that “like new” driveability to an engine’s performance and keeps it running better, longer and more efficiently. Add one can or bottle to fuel tank at fill up. Catalytic converter and oxygen sensor safe."
I added this to a FULL tank of gas, on saturday. I have only gotten about 40 miles, but I feel the car running very smooth. A bit more peep in my step.
I plan to finish off this tank of gas and probably another tank. To let the BG 44K get fully outta the tank. Then do Zoom Power Clean (backup, whats the harm?). Then do an oil change
Here is the item on Finish Line/Rosenthal Mazda's website
Under RX-8... Engine....BG 44K
http://finishlineperformance.com/sto...cat=338&page=1
-Scott
Old Mar 17, 2009 | 07:02 PM
Ceez76's Avatar
Ceez76
BG 44k is a very good cleaner but lacks lubricity, I use Lube Control FP plus. Its a very good cleaner and also provides lubricity.
Old Mar 17, 2009 | 07:11 PM
invasion08's Avatar
I like to use bg44k every 10-15k miles
Old Mar 17, 2009 | 07:15 PM
umm... then just add some pre-mix
Old Mar 17, 2009 | 07:17 PM
Ceez76's Avatar
Ceez76
yup that works too
Old Mar 17, 2009 | 07:33 PM
ZoomZoomH's Avatar
Mulligan User
i usually get about a 1mpg gain in mixed driving on the tank after the tank with BG44K added.
Old Mar 17, 2009 | 07:46 PM
PSTNLSS's Avatar
The Former PSNTLSS
I'm not saying it was a huge amount of gains. But I feel a bit of power gains. Fuel economy seems to be better by a mile or so. Nothing like OMGAGEOGJESOH!!!
Just spreading the recommendation for good product!
Old Mar 17, 2009 | 07:54 PM
HockeyRX-8's Avatar
TNC
Nice to see your satisfied. I may have to try this one day.
Old Apr 13, 2010 | 02:12 PM
learycd's Avatar
Hold DSC for 7 Sec
read up on this product, just added it to my tank today
i'll post on results soon. in the mean time, anyone else love this product?
Old Apr 13, 2010 | 03:16 PM
cornholio135's Avatar
SARX
BG44k is the stuff... I usually run it in a full tank after an oil change...so about every couple of months...
Old Apr 13, 2010 | 03:21 PM
learycd's Avatar
Hold DSC for 7 Sec
i saw a post of you seafoaming your 8 i believe. what are you thoughts on sea foam? how does it compare to BK 44k?
i am thinking about sea foaming before i tune up (plugs, ignitions fluids etc..)
Old Apr 13, 2010 | 03:26 PM
SARX
The Seafoaming did the trick for my rough idle and hesitation. I would recommend doing this before your tune up. I had never done it and I have 60K on my motor replacement and I plan to do it at least once a year. BG 44k is good for the fuel path but the decarb is the only way to truly clean the combustion chambers.
Old Apr 13, 2010 | 03:49 PM
Grungepup's Avatar
Oilfield trash
i use BG44K every other oil change...... i like it
Old Feb 13, 2012 | 03:13 PM
shadow_rx8_2006's Avatar
So just add Bg44k and don't hv to add anything else?
Old Feb 13, 2012 | 03:32 PM
paimon.soror's Avatar
get yourself a bottle of non-marine 2 stroke, 4oz per fill up. Start there. and while you are on that regimen do some searching.
Old Oct 12, 2013 | 07:37 PM
drifta's Avatar
I have a 2004 GT MT with 82,xxx miles. Is there a problem with using 44K at this point if the car has never had a cleaner in it before?
Old Oct 12, 2013 | 08:20 PM
Ojntsa
Old Oct 13, 2013 | 08:42 PM
What does that mean????
Old Oct 13, 2013 | 08:48 PM
Originally Posted by TeamRX8
Ojntsa
another internet slang
it means
oh jesus not this **** again
SoloMazda8
Oct 19, 2011 04:09 PM
rx25det
Mar 22, 2010 11:31 AM
Ceez76
9
Jan 9, 2009 07:56 PM
importshowoff84
Aug 17, 2008 05:43 PM
