engine ticks
Old Mar 17, 2009 | 01:56 PM
Hesselrode's Avatar
US Navy Rotary Enthusiast
engine ticks
okay the engine ticks, duh
when you lift the hood it is coming from the left side (usa passenger side)
it gets faster or slower due to rpms
comes from the engine, right where intake manifold is, where the black plastic meets the cast iron housing, or right at entry of cold air.
very close to the altenator
what is it?
Old Mar 17, 2009 | 01:58 PM
dozer's Avatar
on his 3rd rx8
check the spark plug wires ...make sure theyre on tight
Old Mar 17, 2009 | 02:02 PM
Check the hoses. Look for a leak.
It has been reported that sometimes its a problem and sometimes it just makes noise in that area.
Old Mar 17, 2009 | 02:32 PM
Brettus's Avatar
Boosted Kiwi
+1 when you get the "tick" give your leads the flick ....
Old Mar 17, 2009 | 02:45 PM
Hesselrode's Avatar
on the opposite side of the car?
Hesselrode's Avatar
Old Mar 17, 2009 | 03:02 PM
Brettus's Avatar
Boosted Kiwi
the coils are close to the alternator ....
Old Mar 17, 2009 | 03:05 PM
dozer's Avatar
on his 3rd rx8
the spark plugs are on the drivers side of the car... right next to wheel
Old Mar 17, 2009 | 04:42 PM
Hesselrode's Avatar
lets try this again
okay lets try this again... the sound it coming from the passenger side or left if you are looking at the car from the front... the coils spark plugs and everything to do with the ignition is on the drivers side or right... the altenator is on the left side right next to where the black plastic meets the intake manifold... with that said, what would make noise, the engine has nothing to tick, but there are valves right there where the ticking is coming from.. could one of those valves being stuck cause it to tick?
Old Mar 17, 2009 | 05:18 PM
Brettus's Avatar
Boosted Kiwi
how can you tell it is coming from there ?
Old Mar 17, 2009 | 05:23 PM
dozer's Avatar
on his 3rd rx8
the only thing could be your spark plug wires as they are not covering the spark plug completely....this happened to me, i went into an ally and revved the engine a lil more, as i revved the tick go faster, then i thought to myself what could it be? it could only be the the spark plugs igniting...i let the car cool down, looked down at my spark plugs and saw the white part of it sticking out, i reach in wiggle it and noticed it was loose, so i pushed it in more and tighten it. got back into the car and started it and heard nothing
Old Mar 17, 2009 | 06:36 PM
Hesselrode's Avatar
it isn't the spark plugs i know it is coming from that side casue i have ears and i use them. I stuck my head into the engine bay and followd the sound it is coming from where the ssv valve is and tuff if you follow the air flow it is coming from where the air enters the engine.. it isn't spark plugs.. the spark plugs are new i am getting wires and coils next week or sometime in the near future but i know for a fact it isn't spark plugs...
Old Mar 17, 2009 | 08:20 PM
Brettus's Avatar
Boosted Kiwi
have you tried the ole long handle screw driver to the ear trick ?
Basically you put the head of the screwdriver to your ear and place the tip where you think the noise is coming from then move it around till it is at it's loudest .
That should narrow it down quite a bit .
Old Mar 17, 2009 | 09:38 PM
DOMINION's Avatar
I don't buy Kool-Aid
To the OG poster.
Search SSV or ticking on this site. You will find what your looking for.
b
Yup. Thats what it is.
-Gil
Old Mar 22, 2009 | 06:15 AM
DOMINION's Avatar
Any update on your ticking issue???
Old Mar 23, 2009 | 06:06 PM
Hesselrode's Avatar
no update yet i attempted to take the air intake off and everything to get to ssv valve but i need a swivel adapter and i don't have one will be sure to post though.. i did fix my idle issue though... it wouldn't idle right.. now idles better than ever, took apart and cleaned air intake hose and throttle body... yay!!!
vapor2
Nov 3, 2020 03:38 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
RayBarron
Oct 19, 2015 08:08 PM
Fister_Roboto
General Automotive
Aug 13, 2015 03:15 PM
Belalnabi
Jul 17, 2015 07:48 PM
