Adjusting Camber
Old Mar 16, 2009 | 10:24 PM
VS8's Avatar
VS8
4 Cylinder Rotary
Adjusting Camber
I am gettin an alignment in next couple days and I was wondering how I should adjust the camber i mainly do road course and HPDE and a little autocross
i have tein s tech springs
bilstein shocks
progress sway bars
please dont tell me to search because i have seen the other thread but i want some personalized answers
Old Mar 16, 2009 | 10:29 PM
TopGear8's Avatar
mkuhnracing.com
-1.8 in front, and -2 in the rear.
VS8's Avatar
VS8
4 Cylinder Rotary
what about for the toe...or that all around
Old Mar 16, 2009 | 10:40 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I have my toe set to 0.1 front 0.15 rear.
Camber is -1.5 front, 2.0 rear.
castor 6.8 front (no rear adjustment.
Old Mar 16, 2009 | 10:50 PM
myriadshalaks's Avatar
rot8ing
i'm neg 3 on the camber all the way round. woohoo.
Old Mar 16, 2009 | 10:51 PM
VS8's Avatar
VS8
4 Cylinder Rotary
how does that work out for u
Old Mar 16, 2009 | 10:59 PM
rot8ing
i don't have trouble cornering. i can beat you.
TopGear8's Avatar
mkuhnracing.com
^Makes him go through tires pretty fast..
Old Mar 16, 2009 | 11:01 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
camber doesnt kill tires as much as toe.
Old Mar 16, 2009 | 11:54 PM
G3tR3DDY2GR3DDY's Avatar
um.. i disagree lol
anything more than -2 is unecessary unless you are tracking or racing on a regular basis and have the money to replace tires twice as often.
Old Mar 17, 2009 | 12:07 AM
rot8ing
i dunno, the stock 225s lasted 14k with light tracking on 8.5s. only towards the end did they start to feel wrong, and they were only mildly lopsided. i could have probably flipped em around at 10k and gotten another 5k (so 19 in total).
and you never know when you might need that extra bit of cornering ability.
Old Mar 17, 2009 | 12:12 AM
the stock tires are really high treadwear rating though.. get ANY other tire and see how bad -3 messes with you... i have -2.5 on the rear and after 3 months (2k miles) i have slicks on one side and half tread on the other side of the tire
Old Mar 17, 2009 | 12:17 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
I think that might be indicative of another issue.
I have a good number of miles on my tires with no noticable outside-inside differences in tread.
Now, on my subie, I had the toe at 0.45 inward (I am not sure why. Came to me that way) In under 2k miles, the outside had worn almost slick. THis is with nearly zero camber.
Old Mar 17, 2009 | 12:26 AM
i need to go find my allignment sheet..
i copied one of the preferred allignment specs off here... and it was pretty close but my camber couldnt get quite as much in the front (-1.8 instead of -2.0)
the fronts are wearing ok but the rear (-2.5) is horrible...
Old Mar 17, 2009 | 06:48 AM
I8U's Avatar
I8U
I'm running -1.7 up front and -1.9 in the rear.
Old Mar 17, 2009 | 07:09 AM
rot8ing
don't these different cambers cause understeer?
Old Mar 17, 2009 | 07:20 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Uh...huh. What?
Please; outline the mechanism behind your hypothesis.
Old Mar 17, 2009 | 07:27 AM
rot8ing
staggered wheels cause understeer, therefore staggered camber causes understeer???
Old Mar 17, 2009 | 08:03 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Oh. Ok, I see your point. My 'pologies. I suppose if you had pos or zero camber on the front and -2 on the rear that you would get understeer. I dont think the differences that you are seeing here will translate to EXCESSIVE understeer. Such and effect should be small enough that you could dial it out by stiffening the rear dampers (bandade, I know) or moving your rear sway in one hole. I dont think it would be noticable.
EDITED to ADD: I saw your edit. Weak sauce, man.
Old Mar 17, 2009 | 09:22 AM
tiltmode43's Avatar
OMGITM!
Interesting; I decided to run a relatively conservative -2.1R -1.7F and camber wear is nearly nonexistent in both the front and rear. There may be a slight bias but really really too much. I do know my toyo t1r's *seemed* to camber wear a bit more but it could have been for a number of other reasons, not necessarily the tire itself. Toe zero'd out, naturally, and tire pressures around 36psi cold - 275 rt615s.
I only managed 10k out of the stockers, and that was with factory suspension/alignment :D
Old Mar 19, 2009 | 09:19 PM
olddragger's Avatar
i got great track tire wear across the thread with a 1.2 and a 1.4! 0 toe. car is predictable and feels just as good as when i was running 1.7 and and 1.9 . I DID get inside street tire wear with the 1.7.
i am beginning to believe that the 0.5 really doesnt make any difference in my car except increased street tire wear.
olddragger
Old Mar 19, 2009 | 09:42 PM
NotAPreppie's Avatar
What am I doing here?
I thought my OE Bridgestones were like 140. How is that really high? Unless you're comparing them to the 30 or 40 of Kumho V710's...
Old Mar 19, 2009 | 10:44 PM
dmak_el's Avatar
i have almost -2.0 front camber, and only -1.5 at the rear.
Old Mar 20, 2009 | 02:48 AM
olddragger
yep.
i am running 1.4 front and rear.. i might back that down..
denny. did you get some extra front right wear at little talladega? i was a bit surprised!
btw, op. lots of really good info in that other sticky thread. dont be lazy.
Old Mar 20, 2009 | 03:10 AM
cjkim's Avatar
^noob
olddragger
0 toe when you were -1.7/1.9?
