Hot start problem and lose of power.
Old Mar 16, 2009 | 09:52 PM
am22's Avatar
Ok, I have a problem starting my car when the car is warmed up. It cranks just fine but it take a really long time for it to start, and also I have no power in low rpms and have a hard time getting to high rpms. When I drive I have to keep my rpms really high to get up hills. Any ideas?
The cars got 32000 miles MT. I have mazdaspeed intake and exhaust; also I have new plugs, bhr coils and new fuel pump.
I was wandering could the catalytic converter or the o2 sensors cause this problem?
thanks
Old Mar 16, 2009 | 10:52 PM
Old Rotor's Avatar
thanks
Look at the third and fourth "TSB"
http://www.finishlineperformance.com....php?pageid=11
Old Mar 17, 2009 | 01:45 PM
umm... there were two threads in the last few months with hot start problem.
I can't remember what the cause was for their problem.
Try a search.
Back in the old days it was a bad starter.
Old Mar 17, 2009 | 01:48 PM
cjkim's Avatar
^noob
cold crank is fine?
Old Mar 17, 2009 | 01:49 PM
Silver06's Avatar
Zoom Zoom....
Cat converter test.
Test ignition system.
Compression test.
Old Mar 17, 2009 | 01:54 PM
Easy_E1's Avatar
Check the cat.
Old Mar 17, 2009 | 02:23 PM
Yes, now that I recall.. I think that was the answer on at least one of the hot start cars.
Old Mar 17, 2009 | 04:01 PM
alnielsen's Avatar
My car had a warm start problem. When I stopped for gas, the car wouldn't restart. It had to sit for 15 min. before it would start again.
Engine was replaced under warranty.
Old Mar 17, 2009 | 04:28 PM
DeViLbOi's Avatar
The devil made me do it
A local had a hot start problem and fixed it with replacing the starter switch. However that won't bog you down while driving. Not lookin good for you.
Old Mar 17, 2009 | 04:29 PM
ferg's Avatar
i had that, i try to start it after fill up and it took an extra second
Old Mar 17, 2009 | 06:20 PM
am22's Avatar
Thanks for all the reply you guys.
Ok, I had a Compression test done and it was ok, so I guess the engine is fine.
Next I’m checking the cat tomorrow.
Oh and also I think I replaced my starter last year around this time.
Old Mar 17, 2009 | 06:41 PM
am22's Avatar
Originally Posted by cjkim
cold crank is fine?
Cold start's ok but still kinda off
It takes longer than it used to
Old Mar 17, 2009 | 06:46 PM
am22's Avatar
Originally Posted by Silver06
Cat converter test.
Compression test.
Compression test was ok
I have the BHR coil system. Installed it 3 weeks ago.
I'm ganna try to check the cat tomorrow
Jaco Greyling
Jan 6, 2019 08:39 AM
SUKIEE
Oct 9, 2017 09:41 PM
RayBarron
Oct 19, 2015 08:08 PM
robd1337
Jul 31, 2015 09:35 PM
dbarber
Jul 25, 2015 01:34 PM
