Eyelid removal
Old Mar 15, 2009 | 04:35 PM
getdamafiaonyou's Avatar
Eyelid removal
I searched but couldnt find any answer. i need to take off my eyelids and have them professionally painted, but they said that they might break, being the way they are. So i figured since i cant buy them any more i dont want that to happen. it's only on with that 3m (i think that's what it's called) double sided tape. is there a easy way to get these off? maybe goo gone?
Old Mar 15, 2009 | 04:52 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
try to heat it up so the glue can melt a little
Old Mar 15, 2009 | 05:31 PM
mscamp02's Avatar
Blue Bullet?
Fishing line wire might be able to cut through it
Old Mar 15, 2009 | 05:34 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
^that too
Old Mar 15, 2009 | 05:52 PM
both good idea's. thanks guys. i was sitting here trying to figure it out, but my mind is mush right now. i'll try it in the next few days and let you know how it goes.
Old Mar 15, 2009 | 06:02 PM
Rotr8's Avatar
whines all the way home
Be careful with this method though the lense covers can easily melt too...
Old Mar 15, 2009 | 06:14 PM
i'll just heat it up a little and go to it with some fishing line and goo gone, hopefully it wont be to hard. any ideas on how to get the rest of it off though? cuz if i use fishing line it will just basically cut through it, so how would i get it off the car and back side of the eyelid?
Old Mar 15, 2009 | 06:43 PM
mscamp02's Avatar
Blue Bullet?
goo gone and alot of scrubbing
Old Mar 15, 2009 | 06:59 PM
Silver06's Avatar
Zoom Zoom....
Instead of fishing line, you can also use dental floss. Just tie a knot in it about every 1/2 centimetre to give it some teeth.
Test the Goo-Gone on the headlamp very carefully. It shouldn't hurt the lexan / plastic / whatever lens, but you can't be too careful (the headlight ain't cheap).
If you are concerned about Goo-Gone for anything, then WD40 and a 'scrunge' pad (plus a lot of additional time) should do the trick.
G'luck.
Old Mar 16, 2009 | 12:43 AM
Fortunate Few's Avatar
Irollerblade.
let us know how it goes.
Old Mar 16, 2009 | 08:37 AM
Juansito's Avatar
Redlined
Watch the scrubbing with goo-gone you could scratch your headlights pretty bad.
Old Mar 16, 2009 | 01:23 PM
mscamp02's Avatar
Blue Bullet?
^yup so just use WD40
mdl0209
May 23, 2019 05:46 PM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
