still rattles
Old Mar 14, 2009 | 11:16 PM
Originally Posted by sfsoldier14
ok so here is the deal. my car sounds like a tin can full of marbles when i hit high rpms. I was told this was a common occurrence by you good people on this forum that it is most likely my cat. Had that checked out and my cat is fine, heat sheild is not cracked. So if anyone can take a stab at what direction i should go with this then please let me know
not common.
you give little info to help solve the problem..
maybe search marbles in a can. or just marbles.
Old Mar 14, 2009 | 11:42 PM
Old Rotor's Avatar
Here is another one with same prob......check it out
https://www.rx8club.com/showthread.p...20#post2908120
Old Mar 14, 2009 | 11:59 PM
I8U's Avatar
I8U
Marbles in a can=new motor.
Old Mar 15, 2009 | 12:52 AM
YaXMaNGTO's Avatar
It's a Cavalier
I remember mine used to do it. This is when they first coined the term "marbles in a can".
The dealership, not knowing how to diagnose the problem, changed out the heat sheilds, entire catback, cats, intake, motor mounts... and it would throw lean codes all the time.
Old Mar 15, 2009 | 02:57 AM
ASH8's Avatar
Super Moderator
Can be High Carbon Build UP..
Spark Plugs OK?
Coils OK?
Leads OK?
Use Premium Gas ONLY?
Throttle Body Coolant By Pass Can Help.
Last thing Seafoam Carbon Clean Out...
Old Mar 15, 2009 | 02:59 AM
ASH8's Avatar
Super Moderator
Failing all that Possibly new recon motor required..there is an 8 Year Warranty for US and Canada Owners.
Old Mar 15, 2009 | 02:52 PM
ASH8's Avatar
Super Moderator
spark plugs are new. less then 5000 miles on them. all the others i am not sure. I use 85 grade gas. is there a diy for the throttle body coolant by pass? i only found mod ones
I am sure you guys there are supposed to be using a min 91 grade gas, so you have a issue there. Don't use the lower grade, some say they have here with no problems....that may be true...issues /problems occur after a few years.
The RENESIS is a high Compression engine that requires the premium gas.
Some say the low grade gas adds to carbon build up.
Yes. look in the DIY section for the TB BY Pass.
Old Mar 15, 2009 | 05:55 PM
Old Rotor's Avatar
I had 20K on mine when my first MIAC(Detonation) showed up. I was using reg gas so I went to mid or prem and the problem went away. Then there was the(one minute) Throttle Body By Pass that was said to fix it. I did it, ran reg again and no MIAC, but it was winter. Summer came and it would come back on days over seventy degrees. I then put plugs, coils, wires in and had compression checked. One rotor was low so the dealer did there own test and said there was no problem with compression. It felt Stronger now and I could run reg again? They did not tell me so but I feel I just got the free de-carbon done. I enjoyed it and wondered why they did not tell me they cleaned it out. After a few thousand miles it was back so I'm on mid or prem no problem.
Old Mar 15, 2009 | 05:59 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Run two tanks of at least 91(if not 93) and then tell us how is doing. Seriously, why are you even trying to run 85??????
Old Mar 15, 2009 | 06:12 PM
Mazurfer's Avatar
the highest they got out here in butt **** no where Montana is 91. I will give that a try and see how it runs. I was told that the 85 grade would not make a difference on my car. 91 was just better for gas mileage on road trips. I guess not all of us can be perfect. haha
Have heard of quite a few people that have had to even go up from 87 to at least 91. I really think you should try it before we have to go to other things. It may just cure it. Go as high as you can and wait at least two tanks.
RevMeHarder
Jun 1, 2026 02:30 PM
extreme_rotary
Jan 22, 2019 11:53 AM
Mane
Nov 20, 2015 12:16 PM
Emmanyei
Sep 19, 2015 11:12 AM
tgaffner
Aug 20, 2015 10:55 AM
