Anyone ever experience this!!!!!!!!!!!
Old Mar 13, 2009 | 11:55 PM
ohmzx's Avatar
I had my 07 RX-8 for less than a month now. Everyone says it has the best handling. I agree. However, when I make a turn and gas it at the same time. The rear wheels slid really bad, like a snake. I tried it couple times. It still happens. It was even worse when I tried it with DSC off. SO Anyone have ever experience this. I'm thinking maybe I should change the tires but this car has been used only like a year and a half. I don't know what happens here.
Thanks in advance. Please let me know what should I do.
If I should change my tires, can I get lower profile tires. Thanks.
Old Mar 14, 2009 | 12:07 AM
Welcome to RWD...
What brand/model tire are you running?
Old Mar 14, 2009 | 12:19 AM
shaunv74's Avatar
Power!!
Could be your alignment is off. But yes that is how RWD works.
Old Mar 14, 2009 | 12:59 AM
GaMEChld's Avatar
Registered Noob
Make a turn and gas it at the same time? And wondering what is going on?
This site should have all the information you need:
http://hyperphysics.phy-astr.gsu.edu/Hbase/hph.html
Very educational :-P
Old Mar 14, 2009 | 01:08 AM
Fortunate Few's Avatar
Irollerblade.
used to happen to me all the time lol. i went from awd to rwd you'll get used to it and learn to control it better as time goes on.
Old Mar 14, 2009 | 01:36 AM
Also go to a local auto-x event or track day and play around with the car; learn it's limits OFF the street
Old Mar 14, 2009 | 02:20 AM
VS8's Avatar
VS8
4 Cylinder Rotary
but learning on the street is so muc more fun
Old Mar 14, 2009 | 02:48 PM
cLLcLe's Avatar
Just call me Circle
HAHAHA
Sorry... but this sounds really really.... newb for a lack of a better word.
You ARE supposed to accelerated out of turns, in racing anyways.
It just sounds like you're stomping on the gas expecting it to just pull into the turn. Well, it doesn't do that. It takes a little self-control, skill and timing.
In racing, you accelerate out of the apex of the turn, and if done correctly, you can feel your car pulling into the turn. It feels good when you do :]
And don't just stomp on the gas, ease into it. Feel for the car and the limit of it's grip.
And changing to lower profile tires give worse traction if what I'm seeing is correct.
Isn't that why everyone that races or autocrosses generally get 17"s and a higher profile?
Old Mar 14, 2009 | 02:53 PM
I've had it happen but never with so many exclamation points !!!!!!!!!!!
slow in, fast out. Don't accelerate in the middle of the turn unless you want the rear end completely coming out.
Trust me on this next piece of advice: do not drive with the DSC /TC turned off. It's there to help, you have NO IDEA how many times members here have crashed their cars because they drove with it off.
Old Mar 14, 2009 | 02:56 PM
Spin9k's Avatar
Momentum Keeps Me Going
...also some tires can be crap....the oems are ok but suspect esp. doing what you did..
Old Mar 14, 2009 | 03:08 PM
TopGear8's Avatar
mkuhnracing.com
Originally Posted by cLLcLe
HAHAHA
True, but when people get 17's it's usually because they are lighter, cheaper, and tires are cheaper as well.
Old Mar 14, 2009 | 03:51 PM
ohmzx's Avatar
Thanks you guys. Yeah! I changed from FWD to RWD. haha. My tires are dunlop 225/45 18R. I think maybe I should get a new set. ahha. Thanks for all the posts.
Old Mar 14, 2009 | 04:42 PM
fstfwd's Avatar
Unregistered Non-User
So now instead of losing your steering, you're oversteering. As others before me have said, practice with it on the track. Then when you get a good controlled oversteer going you'll have entered the world of drifting. Welcome to RWD.
Old Mar 14, 2009 | 05:31 PM
DOMINION's Avatar
I don't buy Kool-Aid
Yea Welcome to rwd man. Get some good tires
Old Mar 14, 2009 | 06:49 PM
kersh4w's Avatar
Hit & Run Magnet
Old Mar 14, 2009 | 07:07 PM
DOMINION's Avatar
^Dam boy Girl got ***!
Old Mar 14, 2009 | 10:23 PM
justjim's Avatar
justjim
Well the obvious has been stated above. Spend some time and learn the car, more finesse and less lurching makes for more control. But lets say your technique is no worse than the average Joe, what else? First check your tire pressures, when one end breaks loose unexpectedly that should be the first thing you do in any car, you may be low in one or both rear wheels. Second, you may need an alignment. There's a Sticky https://www.rx8club.com/rx-8-racing-25/alignment-settings-street-track-use-43308/ about track alignments, read it, maybe you need more camber in the rear, it will certainly help. Maybe now would be a good time to get a book on car control and handling dynamics and read it.
Old Mar 14, 2009 | 11:08 PM
if you are getting you rear wheels / tires to slid badly with the dsc on you have some really big issues..
Old Mar 14, 2009 | 11:16 PM
AJ's Shinka's Avatar
Enthusiast
Hmm Dom, I see what you did there. lol
OP: Yeah also it depends on the location, I was in Cali on stock tires and never slid out, but out here in Nevada the roads are lined in sand and I got some stickier tires. It helped give more grip and better take off.
Old Mar 14, 2009 | 11:57 PM
I8U's Avatar
I8U
Aww Jedi this disappoints me. My car is a base model so no DSC/TC for me, never needed it and wouldn't use it if I had it. People depend way too much on that stuff...all ya need to do is learn to control the car better.
:p
Old Mar 15, 2009 | 12:02 AM
your driving skills > OP's
Old Mar 15, 2009 | 12:06 AM
I8U's Avatar
I8U
HAHA, just making a joke.
Old Mar 15, 2009 | 12:32 AM
GaMEChld's Avatar
Registered Noob
Originally Posted by jedi54
your driving skills > op's
incinerated!
Old Mar 15, 2009 | 03:20 AM
:p
this solved my slid problem!!
hope they seem familiar to you..
Attached Thumbnails Anyone ever experience this!!!!!!!!!!!-dscf3171-large-.jpg
Old Mar 15, 2009 | 11:17 AM
I8U's Avatar
I8U
Nothing like ROAR wheels and Hoosiers to stop wheel slid!
