Race Roots
03-11-2009, 11:52 PM
Tanabe Racing Springs! Coilovers! Exhausts! Stabilizers!
Best of all it is Free shipping!!!
Sustec Pro FIVE [/B] MSRP: $1,550
Race Roots Price : $1,495
http://i118.photobucket.com/albums/o113/BluMonstrRX8/501_img1.jpg
Sustec Pro FIVE is an all new adjustable coilover suspension that features a wide array of all new circuit developed technology that is similar to Tanabe's Sustec Pro SEVENS.
Sustec Pro FIVE delivers broad performance for the track to the streets. Featuring 12-way(16-way with TEAS) front & rear adjustment, FIVE allows drivers to fine tune height, dampening and rebound based on street conditions and driver preference.
The new slide valve technology allows a great range of adjust ability and function for street and track use.
Spring Rate F/R: 8.0/6.0
When used with the new TEAS electronic active suspension controller (http://www.tanabe-usa.com/coilovers/teas.asp), the wide range of dampening force is accessible through the touch of a button, and is fully programmable to automatically adjust dampening rates according to the speed you drive.
TEAS MSRP: $648
Race Roots Price: $595
http://i118.photobucket.com/albums/o113/BluMonstrRX8/SusTEAS.jpg
TEAS stands for "Tanabe Electric Active Suspension" and is the counterpart of the Sustec Pro FIVE (http://www.tanabe-usa.com/coilovers/five.asp) & Sustec Pro SEVEN (http://www.tanabe-usa.com/coilovers/seven.asp) suspensions. This compact unit is the 'brain' behind the highly sophisticated new Tanabe suspensions. TEAS is a fully programmable dampener controller that allows for dampening force to be automatically adjusted while driving. TEAS accomplishes this by connecting and using the signal from the vehicle's Speed Sensor.
Remote dampening control from within the vehicle is not a new concept by any means. In fact, many Japanese vehicles from the 1980's including the FC3S RX-7 and MA70 Supra had buttons to change dampening from "Normal" to "Sport." Unlike other controllers that are simply an update of this older 'analog' technology, TEAS is a much larger step towards highly digital advanced suspension control and tuning through it's speed sensing "Active Mode" (http://www.tanabe-usa.com/coilovers/teas.asp#active)
TEAS active dampening control is uniquely possible due to the use of the specialized valving of the FIVE (http://www.tanabe-usa.com/coilovers/five.asp) & SEVEN (http://www.tanabe-usa.com/coilovers/seven.asp), in conjunction with TEAS' slim, high speed actuators. These actuators change dampener settings in 1/100ths of a second, which is necessary as TEAS can continuously change settings at different speeds.
SUSTEC PRO S-0C MSRP: $990
Race Roots Price: $925
http://i118.photobucket.com/albums/o113/BluMonstrRX8/521_img1.jpg
SUSTEC PRO S-0C is for those who desire both high performance and maximum comfort from a suspension system. S-0C is ideal for performance or street applications.
Dispelling a popular belief that a firm or harsh ride is a sign of a performance suspension, the short stroke, shortened case dampener of the S-0C is extremely unique in that it’s internal construction allows it to deliver superior handling without sacrificing strength or ride comfort.
Unique double-cylinder design allows for full suspension stroke within the shortened shock body while Low-pressure gasses ensure smooth rebound characteristics for additional ride comfort.
Spring Rate F/R: 8.0 / 8.0
Front Height Adjustment +1/4~-2 1/4in
Rear Height Adjustment: +1/4~-2 1/4in
Sustec GF210 Springs MSRP: $260
Race Roots Price: $220
http://i118.photobucket.com/albums/o113/BluMonstrRX8/1-2.jpg
The GF210 coil spring is geared towards maximum performance, without compromising daily drive ability. A subtle drop provides an aggressive stance, while the higher spring rates (+20% - 30% over stock) provide excellent handling and vehicle stability characteristics. These springs provide a very noticeable gain in performance when installed.
The GF210 is well mated with a performance shock upgrade to extract the full potential of the coil spring, but will also work with factory equipment.
Each coil spring application is tested for fitment and optimal weight distribution for sportier handling.
Spring Rate F/R: 3.2 / 2.6
Ride Height Drop F/R: 1.4 / 1.2
Sustec NF210 Springs MSRP $260
http://i118.photobucket.com/albums/o113/BluMonstrRX8/nf210.jpg
The NF210 coil spring features a tasteful drop, and produces the best overall ride quality and comfort for a performance lowering spring. The lowered stance of the NF210 gives the car an elegant pose, while the spring rates, which are only slightly raised (up to 5% over stock) retain factory ride quality settings.
This coil spring is extremely popular with luxury tuned vehicles, as well as those with larger diameter wheels that want to eliminate fender gap, but maintain excellent drive ability while reducing the risk of damage to wheels that is associated with stiffer suspensions.
Comfort especially important on daily driven vehicles, and their passengers. The NF210 provides the best driving experience for all types of roads.
Spring Rates F/R: 2.9 / 2.0
Ride Height Look for both springs:
http://i118.photobucket.com/albums/o113/BluMonstrRX8/gf210.jpg
Sustec Stabilizer bars MSRP: $215
Race Roots Price: $195 each
http://i118.photobucket.com/albums/o113/BluMonstrRX8/stabilizer.jpg
Built for the driving enthusiast, the Sustec Stabilizer eliminates roll for exceptional stability and maximum tire contact patch and grip. Unique to the Sustec Stabilizer is it's FULL CHROMEMOLY steel alloy construction. Chromemoly's strength is such that a small diameter chromemoly anti-swaybar is significantly stronger than the standard steel anti-sway bars that are larger in diameter.
The Sustec Stabilizer has a carefully calculated OUTER and INNER diameter, for the proper amount of rigidity. The diameter and strength cannot be compared to other commonly available anti-sway bars due to the vast difference in material construction.
Chromemoly anti-sway bars have typically only been readily available to race users. The Sustec Stabilizer makes this lightweight, extremely functional race material technology available to all motorsport enthusiasts for a reasonable price!
Front Sway Bar Size: 30.4mm
Rear [B]Sway Bar Size: 20.4mm
Medalion Touring Exhaust System MSRP: [/SIZE]$990
[B]Race Roots Price: $895
http://i118.photobucket.com/albums/o113/BluMonstrRX8/217_img1.jpg
The elegant, well defined appearance of MEDALION TOURING is mature, and matches the artistry of a tastefully built, highly tuned machine.
Using the all new 'continuous strand' ADVANTEX packing material technology, MEDALION TOURING achieves extremely high levels of exhaust system efficiency, while maintaining a street drivable, extremely low frequency and deep tone that is well under 93db for discreet sports driving.
This system requires no removable silencer for under 93db operation. The extremely deep, low frequency tone keeps in-cabin noise to a minimum.
The full SUS304 stainless MEDALION TOURING features a slim-line oval canister, and a special dual wall, angle-cut tip.
Pipe Size: 70-60mm
Tip Diameter: 90mm
TEAS MSRP: $648
Pipe Size: 70-60mm
Tip Diameter: 90mm
