FS: Full Nitrous Kit - ZEX+BHR Accessories.
I'm selling my entire nitrous kit as it was installed in my car. You can view my entire nitrous install thread here: https://www.rx8club.com/series-i-major-horsepower-upgrades-93/als-nitrous-install-thread-163452/.
The kit itself is the Zex #82021 WET Efi kit, this cost me $550. I am also including all accessories that I bought with it. These include the Zex Bottle Pressure Gauge ($50 value), Zex 82006 Bottle Warmer with automatic thermostat ($130 value), and the BHR Throttle Body spacer ($100 value).
Also included is the fuel line that I used to replace the factory fuel line. This is required because this nitrous kit is a Wet kit, therefore it requires a fuel tap. The fuel line I used is rated for 100psi (the factory fuel pump can only push 60psi) so this is a more then adequate replacement. I tapped it using the Zex Tee fitting and sealed it with some gasket sealant. It -never- leaked on me in the 2 months it was installed. With that said I hereby REMOVE MYSELF FROM RESPONSIBILITY SHOULD YOU SCREW UP YOUR INSTALLATION AND SOMETHING GOES WRONG.
You will need to buy a switch. The switch I used (look at my build thread) was a lighted rocker switch. The light on mine burned out so I won't include it in the sale. You can buy a new one for $2 here. Any switch you use has to be rated for atleast 10amp at 12v. Also depending on your installation preference you may need some wiring. I will include any spare wire I have.
In total this kit ran me just under $950. I had it installed in my car for 2 months. I went through 5 nitrous refills. There is no real "wear" on a kit like this.
I am asking for $610 + ACTUAL shipping costs. I accept check or MO. If you want to pay via Paypal I can do that but that will be an additional 3%.
I will ONLY part this kit out if I find a buyer interested in the Zex Kit by itself. I will sell the kit and the gauge for $450 shipped.
I forgot to include the bag of jettings in the pics. You will receive the jettings for the 55, 65, and 75 hp shots.
To be honest .. at first I just got bored of it and I was refilling the tank every week... now I just really need the money for other things (not car related).
Pm me some reasonable offers pls!
In my area it's $4.50 per lb. Any speed shop will be able too or definetely will know where to go. Where are you located?
It will probably still be here... so check back whenever you are ready!
OKAY.. so I HAVE to sell this.
NEW PRICE: $610 FOR EVERYTHING + SHIPPING (MUST pay via check/mo or 3% paypal)
Shipping should AT MOST be $35-40.
