OEM front air dam as an add on?
Old Mar 11, 2009 | 08:16 PM
Alexb's Avatar
desperately needs a drop
Hey guys i have a pretty simple question.
My 8 does not have the front air dam that some of them come with. I was thinking about buying one and putting it on. But how difficult is it to attach? For someone who has no experience with body work like this could I do it?
I have done a ton of mods to the car, but nothing of this sort...
So how is it attached?
Old Mar 11, 2009 | 08:18 PM
HockeyRX-8's Avatar
TNC
with screws and double sided tape. it should be easy to put on.
Old Mar 11, 2009 | 08:31 PM
Alexb's Avatar
I take it you yourself did this?
Old Mar 11, 2009 | 08:33 PM
Icemark's Avatar
On a 04-08, It is a very simple add on. You will need to remove the bumper skin, and drill a couple of holes (that are already marked on th back side of the bumper).
If it takes an hour I would be surprised.
Old Mar 11, 2009 | 08:40 PM
Alexb's Avatar
the bumper skin? what is that....
Old Mar 11, 2009 | 08:49 PM
PSTNLSS's Avatar
The Former PSNTLSS
I believe Ice is refering to the skin as in the under side plastic... For accesibility I assume?
Old Mar 11, 2009 | 09:02 PM
Alexb's Avatar
as in the part that is visible right now?
Either way, has anyone actually done this and can attest to how easy/difficult it may be?
Old Mar 12, 2009 | 08:07 AM
Wargoose's Avatar
I've done this (on a Canadian bumper with headlight washers, so for me it was a tiny bit more work). It's quite simple and you don't require any major mechanical skill to accomplish this task.
It is easier with two people, though not impossible for one.
You can see photos of the bumper removal process here: http://www.racingbeat.com/PDF/RX8nose.PDF
You'll need to disconnect the corner lights and (if you have them) the fog lights. They both have simple connectors but they may be stiff to open.
Once the bumper is off you will need to remove the existing black plastic piece that is mounted to the bottom edge of the bumper and drill new holes for the new spoiler - the location for these holes is already molded into the existing bumper, so you can't go wrong. In the final photo of the above instruction, there are a bunch of arrows pointing to this black plastic chin piece that you remove.
You then attach the new spoiler, using the included fasteners and the double-sided tape that's already attached to the back of the spoiler, to the bumper. Then you reattach the bumper to the car.
To be safe, schedule two hours for this - though it will likely take you only one. Also, since you have the bumper off, I'd advise you to purchase the screens for the radiator and oil coolers from Racing Beat (seen here: http://www.racingbeat.com/resultset....ber=screen set). They're good protection for those coolers, which can easily be hit by rocks and such, and since the bumper is off they're a very quick install. But the screens are completely optional and not at all necessary for your spoiler.
Old Mar 12, 2009 | 09:03 AM
EDZRIDE's Avatar
2005 White GT
I installed mine and I can tell you this guy is right on the money; follow his instructions and you won't go wrong.
Old Mar 12, 2009 | 09:46 AM
SideOfBacon's Avatar
bumper skin is the plastic bumper itself. behind that is a mold.
Old Mar 12, 2009 | 10:22 AM
sobamaflyer's Avatar
Should be working
Just as a side note not much about a car is rocket science, if you have a set of metric sockets and a couple screwdrivers you can tinker w/ most rudimentary "mods". Don't be afraid to unscrew or unbolt something to learn something new the worst that will mostly likely happen is you have to bolt it back together.
If you have "a ton of mods" you should already have a knack. Assuming you can get the spoiler already painted the color of your car this is a bolt on mod, not actual "body work" so go wild .
Old Mar 12, 2009 | 12:13 PM
Alexb's Avatar
Ya I do actually have a lot of experience. But this is a very expensive piece and I haven't had experience with removing the bumper or anything...
But I believe I can pick my color.
If I do this mod I will update yall. thanks for the help!
Old Mar 13, 2009 | 10:08 AM
Icemark's Avatar
Yep, I have done it. I don't think it took an hour. It is very easy.
You need a drill, a 8mm and 10mm sockets or nut drivers a Philips screw driver and a little windex or similar cleaner.
That is about it.
If you get the factory kit, it even comes with instructions.
Old Mar 13, 2009 | 12:53 PM
kersh4w's Avatar
Hit & Run Magnet
i've done it. it was easy. but i did not use the screws because i did not want to drill into my bumper. it's fine.
bumper skin = the plastic painted cover.
the bumper is the metal bar with the foam thing across it. you'll see the actual bumper if you remove the "bumper skin."
its also referred to as front fascia. referring to the plastic painted cover as the bumper, is slang, and is not technically correct.
MsKingRotary
Apr 23, 2016 05:45 PM
k4thomas
Aug 5, 2015 03:03 AM
ripigs
Aug 2, 2015 10:44 PM
cushing75
Jul 22, 2015 09:37 AM
