View Full Version : Squeaky Alternator Pulley
RX8SaxMan
03-08-2009, 10:52 PM
Hey Guys,
My car has been making an annoying chirp/squeak at idle, and I deduced that it's coming from the alternator pulley. If I spray a little WD-40 right in the middle of the bearing the sound goes away, but comes back after a few minutes. Is there a better lube I can put on there to silence it, or do you think my bearing is going bad and should just replace it?
EDZRIDE
03-09-2009, 11:11 AM
Sounds like replacement time.
Atilla
03-09-2009, 11:33 AM
:banghead:
i'm having the same issue...
RX8SaxMan
03-09-2009, 03:09 PM
I suppose I'll look into replacing it. I'm not sure where I would get that part though...
In the meantime I tried rubbing a little white lithium grease in the center bearing of the pulley and that seems to be doing well. It's been a day now and the noise is still gone. I'll be keeping an eye on it to see how long that lasts.
EDZRIDE
03-09-2009, 03:19 PM
Once you get the alternator apart, any bearing supply company should be able to help you. here's a start: https://www.motionindustries.com/motion3/jsp/mi/index.jsp
Icemark
03-09-2009, 04:25 PM
double check belt tension too.. if the belt is too tight, it will wear out the bearing much faster than normal
