AT & neutral
Old Mar 7, 2009 | 12:02 PM
mlfarrell's Avatar
AT & neutral
So the owners manual says you shouldn't ever shift into neutral when driving. Which makes sense to me, I don't know why I'd ever need it. But then why do they have it so easily accessible from the drive position? The other day, I forgot I wasn't in manual mode (to the left) and I went to drop into 3rd and I felt a forward force realizing that I shifted into neutral by accident! Do you guys think I hurt anything? Ugh, I'm just glad it wasn't reverse
Old Mar 7, 2009 | 12:16 PM
Silver06's Avatar
Zoom Zoom....
Neutral for a short time at speed will not hurt anything.
Old Mar 7, 2009 | 12:20 PM
mlfarrell's Avatar
thanks, and dude you better post again, your post count just hit an evil number
Old Mar 7, 2009 | 12:21 PM
Silver06's Avatar
Zoom Zoom....
Hahaha. This post will fix it.
Old Mar 7, 2009 | 01:11 PM
AAChaoshand's Avatar
Rotary Powered
Get a manual my man, neutral solved.
Old Mar 7, 2009 | 04:02 PM
exsequor's Avatar
wipe me down
lol
Old Mar 8, 2009 | 07:11 PM
always.anthony's Avatar
is looking for his torque
i don't see how it would hurt anything in the first place.
i've heard that our trannies are very strong.
Old Mar 8, 2009 | 07:40 PM
Easy_E1's Avatar
No problem for the trans for a short period of time.
Old Mar 8, 2009 | 08:47 PM
Georgia8er's Avatar
The part about not shifting into neutral when driving is about people "coasting" in neutral (which is illegal in a lot of states) and not about damaging something, well, unless you had it under load it would hit the rev limiter. Also, neutral is easy to get to so if something happened and your throttle got locked up, you just bump it into neutral to remove power from the drivetrain.
Old Mar 8, 2009 | 11:10 PM
ken-x8's Avatar
Whether you can damage the transmission by coasting in neutral depends on whether the transmission's pump is pumping enough in that mode - sort of like the question of whether you can push start a car with an automatic. I also suspect that putting it back into gear at speed is not going to be very good for it unless you rev match.
In the US, neutral is required by law to be next to drive, separating it from reverse. The PRNDL rule, which was one of the dozen or so items GSA specified back in 1965 or 1966. Those specs were the birth of federal government safety rules for cars.
Before that, some cars had PNDLR shift patterns. That led to some amusing accidental reverse accidents. PRNDL puts a buffer between forward and reverse. If you think accidentally shifting into neutral is annoying, try accidentally shifting into reverse at highway speeds.
Ken
Old Mar 8, 2009 | 11:14 PM
shazy's Avatar
I bet you nothing happened
Some people posted that they did that by accident on the mazda6 forum and nothing happened...
Old Mar 8, 2009 | 11:21 PM
tubingchamp's Avatar
What mawd bug?
Also, on the reverse thing.
They did a MythBusters about that. It basically does no damage to the car (this was tested on a 90 something Taurus, which has a fraction of the sophistaction of our 8). I think he said the "engine light" came on, but it went away after he restarted.
By no means is it GOOD for your tranny, but I don't think it would be cataclysmic to your car.
Old Mar 8, 2009 | 11:44 PM
ken-x8's Avatar
If they damaged a Taurus, how could they tell that something was wrong?
Ken
Old Mar 8, 2009 | 11:47 PM
What mawd bug?
Good point.
It probably just made the power steering whine abit louder.. Gya ha ha
Old Mar 9, 2009 | 01:08 AM
mlfarrell's Avatar
Ken
nice.. thanks for the info. I wasn't aware of that. Yea I had it out of gear for no more than 500 ms. I immediately put it into third and it did just fine. I was just concerned about the manual but you guys have explained all that now
Old Mar 9, 2009 | 03:08 PM
btw, or for ford atleast, on automatics, reverse won't go in unless doing about 15 mph or less, other wise car will treat it as in drive, untill slowed down, then it will be forced into reverse
WranglerFan
Nov 5, 2017 09:35 AM
Kanthinar
Dec 21, 2015 01:24 PM
nowakm99
Oct 9, 2015 07:10 AM
rotorsnsaabs
Aug 26, 2015 08:21 PM
ShadowGryphon
Aug 23, 2015 02:46 PM
