Hand Brake Help...
Old Mar 4, 2009 | 12:09 AM
rotary boy's Avatar
myspace.com/kustal
Post Hand Brake Help...
does anybody have any advice for tightening an e-brake... my 8 rolled out of my driveway and into the street yesterday, the parking brake was as tight as possible. thanks for your help!
Old Mar 4, 2009 | 12:16 AM
risky business's Avatar
IRC Founder
1. Depress the brake pedal several times.
2. Remove the service hole cover of the rear console.
3. Turn the adjusting nut and adjust the parking brake lever.
4. After adjustment, pull the parking brake lever one notch and verify that the parking brake warning light illuminates.
5. Verify that the rear brakes do not drag.
http://foxed.ca/rx7manual/2003mazdarx8/
Old Mar 4, 2009 | 12:53 AM
DarkLord7854's Avatar
Software Engineer
Also.. get into the habit of putting it into first
Old Mar 4, 2009 | 01:24 AM
YaXMaNGTO's Avatar
It's a Cavalier
No kidding...
Old Mar 4, 2009 | 12:56 PM
jones75254's Avatar
And put some old, stacked tires in the nose of the garage so in the beginning, when you start it up and forget its in first (and you WILL), when the car hops forward n stalls, you have cushion instead of smashing up the front end
Old Mar 4, 2009 | 01:06 PM
kersh4w's Avatar
Hit & Run Magnet
tires?
what about an old foam mattress. lolol.
Old Mar 4, 2009 | 01:13 PM
IRC Founder
yeah, i do both since the rx8 doesn't really have a lot of static compression like a piston car would.
Old Mar 4, 2009 | 01:51 PM
Software Engineer
Also may wanna trim the signature... >.>
Old Mar 19, 2009 | 02:59 PM
rotary boy's Avatar
myspace.com/kustal
Question
anybody know where i would be able to get pics of this process...
i don't exactly know where all of this stuff is
Old Mar 19, 2009 | 03:07 PM
Silver06's Avatar
Zoom Zoom....
Hate to quote myself....
Originally Posted by Silver06
^yup.
From the SVC manual...
PARKING BRAKE LEVER INSPECTION
Stroke Inspection
2. Pull the parking brake lever 2-3 times .
3. Inspect the parking brake stroke by slowly pulling at point A 50 m {1.97 in} from the end of the parking brake lever with a force of 98 N {10 kgf, 22 lbf} and counting the number of notches (clicking sound).
• If not within the specification, adjust the parking brake lever.
Standard: 1-3 notches
PARKING BRAKE LEVER ADJUSTMENT
...also check your rear pads for thickness remaining.
Old Mar 19, 2009 | 03:27 PM
Silver06's Avatar
Zoom Zoom....
Here's a picky (credit to GOMEZ in this thread):
Old Mar 22, 2009 | 10:12 PM
Renesis07's Avatar
Vtak just kicked in yo!!
total thread jack but I lost my service cover dammit! Does anyone know how much that little **** costs?
Old Mar 22, 2009 | 10:31 PM
always.anthony's Avatar
is looking for his torque
leaving in first is just a back up right?
Old Mar 22, 2009 | 10:34 PM
shazy's Avatar
Wait, if you stall in first, won't your car flood?
Old Mar 23, 2009 | 12:05 AM
if you stall then you decided you got scare and want to leave the car for another 10 hours. maybe
if you stall and restart your car right away. nope.
the reason why rotary flood is because air fuel mixture "eventually" spread apart, gas turns back into liquid, Air stays. and due to earth's gravity and engine's shape. Liquid will sit at the bottom of the camber. too much fuel there will prevent sealing so compression = not starting
Old Mar 23, 2009 | 12:10 AM
Alexb's Avatar
desperately needs a drop
I just bought one, like $12 shipped from here:Online Mazda Parts
However, I couldn't find it on the site. I ordered the wrong part initially, and talked with him and he is sending me the correct part. Just message him through the site.
Old Mar 23, 2009 | 12:34 AM
rotary boy's Avatar
myspace.com/kustal
Thumbs up
thank you so much!!!
hufflepuff
May 30, 2016 10:45 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
Digitz0070
Sep 25, 2015 10:58 PM
