View Full Version : HELP with Front Brakes AGAIN!
volcomx31
02-26-2009, 02:22 PM
First of all, thanks for the help on my previous thread. The clicking/clunk sound is gone! I still have an issue though. While my car is running at a regular speed (20 and above), I get this squeak sound from the brakes or it may be the suspension (a tick tick tick sound). I get the exact same sound when I apply the brakes gently. The sound does not occur when I am going at slower speed though(20 and lower). Also, the sound is coming from the front. I just got new rotors, pads, and hardware. Any thoughts of what may be causing this? Thanks
gregs
02-26-2009, 04:25 PM
glad the last issue was resolved, did you use oem mazda brake parts and hardware..if not what name brand? any aftermarket sway bars any other suspension mods to help with finding the problem?
Jedi54
02-26-2009, 05:52 PM
^^^ +1
Need more info
romycha1
02-26-2009, 07:22 PM
Did you reuse the shims, or just put the pads directly into the caliper?
justjim
02-26-2009, 08:21 PM
Yeah that^. Make sure they used the OEM shims, also they should have greased the backs, top, and bottom of the pads and shims with high temp synthetic brake grease. These two items almost always silence noisy brake pads, even track pads.
volcomx31
02-26-2009, 11:21 PM
I purchased new shims and clips. The pads are like brand new. Everything was installed the way it should be. Maybe I need some anti-squeak grease? I had the stock suspension and I was hearing the noise. Now, I installed springs and the noise sounds the same. I just don't understand why it squeaks when I am not stepping on the brakes.
romycha1
02-27-2009, 12:34 AM
When you put the shims on the pads, you didn't put the grease in between them?
justjim
02-27-2009, 07:35 AM
I think the first thing you have to do is figure out whether the noise is coming from your brakes or your suspension. From your desription is could be either. Does the noise only happen when you brake, when you turn the wheel, when the car is moving, etc.
Razz1
02-27-2009, 02:51 PM
Yep springs could be out of the perch, end links loose, maybe even a tie rod.
Examine all, then test drive and listen.
Best thing is to have an old dog like me ride with you.
We know what the sounds are from experience.
See if you can find an old dog like me that knows how to roll................
shaunv74
02-27-2009, 03:16 PM
did you bed the brakes properly? If not try that first and see if it helps.
volcomx31
03-06-2009, 03:31 AM
Everything was installed great! I will get this issue checked out as soon as I have some time to myself though. School and work is taking up all my time at the moment..
Spin9k
03-06-2009, 08:15 AM
People can't help much unless you explain things in detail. Posts asked specific details about the install you did (had done); you've not answered any one of them. It's not them being nosy, or for general interest, they have done this work before and these are important detail points, and details matter!
Saying, "Everything was installed great!" or "Everything was installed the way it should be." isn't the same as saying, for example, "Yes, I checked (I talked to the mechanic...) and there was anti-rattle grease put on the front and back of each shim.", or whatever the question was about.
Shortcuts are taken all the time, both in labor and materials used,, and are often the cause for complaints. Not beating you up, but some little things are important.
BTW: if you got new shims and clips, there should have been anti-rattle grease with them. Didn't you see that?
Nopstnz8
03-06-2009, 01:24 PM
So was the clicking/clunk sound due to loose endlinks? I have this problem when touching the brakes when the car is stationary and was wondering if this is the cause?
SiLVeRE8
03-06-2009, 02:31 PM
i am also interested in know what really caused the clunking noise too because also have that noise coming from the rear...
volcomx31
03-06-2009, 04:04 PM
Yes, I was watching while they installed the brakes. They also added grease to both sides of the shims and I made sure everything was fitted properly. For the clunk/click sound, it was actually the front shock bushings only, they were twisted a bit. When I installed my new springs, the pressure was released causing the same sound and they are straight again. I don't know if this could be the same problem for some of you.
shaunv74
03-06-2009, 04:34 PM
Well now. So it wasn't your front brakes. Hmm. Didn't I suggest that since you were positive everything was installed correctly?:) Glad you got it fixed but the lesson here is if don't assume you know what the problem is. You only know what it's not based on what you've checked.
yokohamaboi
04-23-2009, 12:35 AM
Yeah im having a squeaking squeal noise, it's coming from the passenger side, idk if it's the front or rear. but i think it might be coming from the wheels. kinda sounds like a Bent AXEL but with less noise, could it be bearings? or parts need to be regreased?
Jon316G
04-23-2009, 12:41 AM
I had squeaking problems up front.
Had good pad life on my Hawk Ceramics, so it wasn't that.
I ended up greasing not just the shims, but the area on the caliper the clips rest on and a couple other spots pointed out in this TSB:
http://www.finishlineperformance.com/pdf/rx8/bulletin/04-001-06-1568.pdf
After that, no more squeaking.
yokohamaboi
04-23-2009, 12:46 AM
Yeah but mine squeals with out having the brakes pressed in. It makes noise while free ballin :banghead:
swoope
04-23-2009, 04:01 AM
you need to remove and grease the sliders..
this is important..
if you dont know what i am talking about, pay someone to show you how to do it..
beers :beer:
yokohamaboi
04-25-2009, 12:54 AM
Are you talking to me? lol
swoope
04-25-2009, 01:02 AM
i am talking to anyone that wonders why the brake pads drag.
beers :beer:
yokohamaboi
04-25-2009, 01:11 AM
beers :beer:
LOL :lol: um can you help me out? my car has been making Squeaks when i drive. sounds like its coming from the passeger side wheel or rear if im wrong. would mazda fix it? as warrenty?
swoope
04-25-2009, 01:18 AM
not to be a dick,
but you need to read, learn, and help youself..
i would think searching brake noise on here or google would be a start..
i am not your mom..
beers :beer:
yokohamaboi
04-25-2009, 01:25 AM
not to be a dick,
i am not your mom..
beers :beer:
Ok.... and it's not when im braking, while im driving. ive looked around and people said grease the sway bar bushings.
swoope
04-25-2009, 01:37 AM
ok,
i am you mom.
google brake pads dragging..
wow, just wow.
beers :beer:
volcomx31
04-25-2009, 01:45 AM
do you have aftermarket wheels? if the hub rings are broken it causes squealing..
swoope
04-25-2009, 01:58 AM
really,
that would usually cause clicking..
beers :beer:
yokohamaboi
04-25-2009, 02:07 AM
ok,
i am you mom.
wow, just wow.
beers :beer:
Oh SHIT! he's having the same symptoms as me lol
http://www.rx8club.com/showthread.php?t=172039&highlight=brake+pads+dragging
So when i change my pads, i should get the rotors resurfaced and greased the back shims right? lol
swoope
04-25-2009, 02:51 AM
half of that is correct.
wow, and that search shit is cool, huh!
beers :beer:
yokohamaboi
04-25-2009, 02:57 AM
beers :beer:
whats the other half? lol
swoope
04-25-2009, 03:08 AM
does not involve the your link.
beers :beer:
