View Full Version : Oil cooler thermostat?
ayrton012 02-26-2009, 06:42 AM Maybe it's already answered, but I found the next sentence in a German RX-8 (SE) service manual. I did not find this info in any other english serv. man.
Ein integriertes Thermostatventil führt Öl mit einer Temperatur von über 90C (194F) durch den Ölkühler.
If it means that there is a 194F opening temp thermostat valve in the oil coolers, maybe it could be the reason for some of the overheated engine, and the high oil temps.
Some thoughts:
There is no cell when this thermo valve goes wrong.
If the thermo valve open later (went wrong), the oil temp will be too high and the oil will be too thin (bearing wear).
Who knows when the thermo valve goes wrong, does it stay opened or closed mode?
In winter (europe) my oil coolers are only warm when the engine is on idle for a while and the car is standing. If the car was moving before, the coolers are cold immediate after stopping. I could check it with my hand after stopping. Even in summer my cooler's thermostats are closed a lot of times (checked after stopping), when the engine warm.
DOMINION 02-26-2009, 07:00 AM Oh good find. However Rotarys run hot anyway. Always have.
You know Jeff (MM) can read that stuff (German) really good. PM him.
But why would it be in that book and not the US book???
Keep us posted!
ayrton012 02-26-2009, 09:10 AM MM's post box exceeded the limit, so I sent a mail to him.
Just for confidence, the information comes from the German Mazda RX-8 (SE) Trainingshandbuch 11/2003.
It's a book in my hands, but I don't speak German.
MazdaManiac 02-26-2009, 12:54 PM Well, German is not my primary language, but this is what it says:
"An integrated thermostat allows oil with a temperature over 90°C (194°F) through the oil cooler."
Razz1 02-26-2009, 01:08 PM So where is this thermostat or valve?
Has Paul at Mazmart seen a valve on the oil cooler?
MazdaManiac 02-26-2009, 01:21 PM All RX-8s have them. Its in the oil cooler itself.
IIRC, all of the contemporary rotary Mazdas had thermostats in their oil coolers.
90°C is troubling, though.
Razz1 02-26-2009, 01:25 PM Then there is Easy answer to running hot.
Correct?
MazdaManiac 02-26-2009, 01:38 PM Then there is Easy answer to running hot.
Correct?
No, probably not.
His oil temps are never as high as his water temps when he begins to overheat.
I'm in the same boat. (Though my issues are due to the intercooler blocking airflow to the rad.)
Thermostats in the oil coolers is a good thing in most places, I would just like to see it open at 175°F.
ayrton012 02-27-2009, 06:21 AM Is it true, that all of the RX-7 FC-FD oil coolers's thermostat opens at 149F ?
Why the Renesis has so much higher (194F) temp thermostat?
olddragger 02-27-2009, 11:40 AM dont concern yourself with oil temps---not an issue. the oil temps will follow the coolant temps more or less. address coolant temps. Mazda does not want oil flowing through the coolers at too cool of a temp due to possible plugging.
OD
MazdaManiac 02-27-2009, 11:52 AM dont concern yourself with oil temps---not an issue.
Huh?
Where do you think the water gets half of its heat from?
Oil doesn't follow water - water follows oil!
Razz1 02-27-2009, 02:22 PM umm... nice 69 avitar!
9krpmrx8 02-27-2009, 02:32 PM Hmmm, subscribing. Can the oil cooler be upgraded?
olddragger 02-27-2009, 04:10 PM thats why you should pay more attention to the coolant temps---and if you get it down the oil temp will follow!
Oil doesnt play a part in cooling a large part of the engine whereas the coolant does---concentrate on the coolant. If you concentrate on just the oil---well ok go ahead.
olddragger
MazdaManiac 02-27-2009, 04:46 PM thats why you should pay more attention to the coolant temps---and if you get it down the oil temp will follow!
As I said - other way around.
Icemark 02-27-2009, 04:47 PM Is it true, that all of the RX-7 FC-FD oil coolers's thermostat opens at 149F ?
FC oil cooler thermostats started opening at between 140F and 149F (60-65C), the same temp that the E-shaft thermo pellet opened on a FC.
Icemark 02-27-2009, 04:49 PM thats why you should pay more attention to the coolant temps---and if you get it down the oil temp will follow!
olddragger
On the FC, 30% of the cooling was by the oil... is the FE water cooling system that much better that number is reduced?
nycgps 02-27-2009, 07:05 PM Hmmm, subscribing. Can the oil cooler be upgraded?
In Japan, some shop has them.
you can always go get universial kit and fit it your self.
olddragger 02-27-2009, 07:52 PM if the oil is doing 30 % of the cooling then the coolant is doing 70%. which do you think will respond to upgrades better? which will have the most influence on the other?
to see one difference between the engines look at the housings on the earlier models versus the renasis and you will see that the areas around the sparkplugs has a much bigger area for coolant to pass through for example.
the twin oil coolers on the rx8 are pretty good--the oil system has the capacity to cool the oil if it is not asked to cool more than its share. The inadequate coolant system does just that. The coolant temps on a 90+ day on an oem car at low speed can get to 230F easily. the oil will be at around 210F. To get the oil temps down from that you are going to have to create enough cooling capacity to influence the coolant temps--that will be a pretty big job. Now if you add just a little coolant cooling capacity to bring that temp down to 200--then the oil will drop down to 180 easily.
would you rather work on the system that has the lesser impact on the result you are seeking?
And dont forget--the oil will do its job at 250F+ coolant will not!
It does have to be a balance--you dont want much difference between the two.
enough said.
olddragger
Icemark 02-28-2009, 01:05 AM if the oil is doing 30 % of the cooling then the coolant is doing 70%. which do you think will respond to upgrades better? which will have the most influence on the other?
enough said.
olddragger
Think you are missing the point. Modifying the cooling on the car is not a one thing or the other. On a rotary engine it only makes sense that if you are upgrading one, that you also at least look at upgrading the other.
However it makes no sense what so ever to say, "I only want to upgrade the radiator" if you are having temp issues. If you are having temp issues you should look at every thing you can, to help.
Its not like changing the oil cooler thermostat and eshaft thermo valve is going to solve anything, but in conjunction with other modifications it may lead to better coolant, oil and engine life. Now with a piston engine, the oil does not provide even 5% of the cooling, so your comments fit that idea perfect. Why waste the time even looking at oil cooling if you are not affecting anything. On piston engines that use an oil cooler, it is more for oil life than cooling of the engine.
But on a rotary, its not, and this is not a one thing or another issue. Sure if you can solve the issue with a bigger 3 row radiator, then you are done. But if not, if you run the oil temp back down at 180 instead of 210, that might be the extra kick that helps.
Now again, don't get me wrong. If you are having overheating issues, just changing the oil cooler thermostat is not going to solve anything...But how much less viscosity and oil break down.. how much would be reduced by dropping that oil 10 or 20 degrees?
swoope 02-28-2009, 01:49 AM and if you are running a h20 thermostat that works right at 180 deg. the with some extra water cooling. both the problems are solved..
that is how olddragger fixed the problem..
beers :beer:
DOMINION 02-28-2009, 04:09 AM Hey guys, I asked this before but no one really gave me an answer, What about using a water or oil pool? will that help with cooling? I know some GT and other race cars use them.
-Gil
olddragger 02-28-2009, 01:39 PM icemark--you are absolutely correct--everything should be looked at. And the full range balance (warm up, wot applications etc) between the oil temps and the coolant temps have to be considered.
In looking at all --i found my solution by simply adding a small secondary radiator placed below the front support member directly in the air flow
http://www.rx8club.com/attachment.php?attachmentid=134359&stc=1&d=1235846259
see pic--this little thing with a couple of other mods will fix the cooling problem(except for the desert guys with no humidity in the air.
olddragger
DOMINION 03-01-2009, 04:50 AM OD can you post a larger pic? or pm it to me and I will post it. I cant see shat in that small attachment.
-Gil
Spin9k 03-01-2009, 07:43 AM --i found my solution by simply adding a small secondary radiator placed below the front support member directly in the air flow
You don't say, so are you talking oil or water rad you added? Your pic is not much bigger than an avatar, can you post one a bit larger so we can see what you added?
....see pic--this little thing with a couple of other mods will fix the cooling problem(except for the desert guys with no humidity in the air.
olddragger
a couple little other things? Can you pls be a bit more specific?
olddragger 03-01-2009, 11:19 AM ok here goes guys
http://www.rx8club.com/attachment.php?attachmentid=134381&stc=1&d=1235924191
if this doesnt work i will take some new ones
od
olddragger 03-01-2009, 11:42 AM try again--yall know my rep with pics now
http://www.rx8club.com/attachment.php?attachmentid=134383&stc=1&d=12359256http://www.rx8club.com/attachment.php?attachmentid=134384&stc=1&d=123592569354http://www.rx8club.com/attachment.php?attachmentid=134385&stc=1&d=1235925720
hope this works
OD
olddragger 03-01-2009, 11:50 AM ok i have the pics up now--yall like those Hehe.
the small radiator from summit racing 21x7.5 inches 3/8 tubes
it is feed by the return heater hose--(it is a non thermostatically fed system) and it returns to the thermostat housing as the heater hose normally do.
homemade hangers from aluminum stock available at lowes/homedepo etc. mounts to the front bumper support.
upgraded water pump(mazmarts) and a 60/40 coolant blend in the summer months. Stock thermostat unless the temps are in the high 90's and i am headed to the track--i then have a custom 180 thermostat barrell type that i use. Mazmart is reportedly thinking about building a stock replacement thermostat that fully opens at 180F--but not yet.
removed the front rotory symbol for better airflow.
thats it
youre temps coolant and oil will be fine.
airflow is the key and this puts the cooler right where it is needed. for those that dont want to do the work etc--Pettit is going to sell a kit almost like this but it is mounted in the airdam belly pan.
olddragger
MazdaManiac 03-01-2009, 11:54 AM ^ This is a great idea - if you want the car to run even hotter.
You take a smallish rad, saturate it with hot water and then us it to simultaneously reduce airflow to the main rad and heat that reduced airflow up to the temp of the coolant in the first place.
Brilliant.
The 70/30 cooling comment is still missing the point.
The oil cooling system is responsible for shedding a smaller amount of heat than the rad because of the thermal properties of oil versus water.
Oil is slow to give up its heat.
And therein lies the problem.
If the oil temps rise to coolant overheat temps, you will have an impossible chore before you in getting the water temps under control.
However, if you get the oil temps down to as close as possible to minimum operating temperature, keeping coolant temps under control is a breeze.
olddragger 03-01-2009, 12:14 PM MM dude --give me a break. Wait a minute--no dont give me a break--dont want one, dont expect one. I dont even expect any objectivity.
Bottom line--this works for me. My data proves this.
Not only do I put this small cooler in front but the pettit a/w intercoolers are behind it--then the a/c condenser is behind that---then the radiator.
Essentially --i have been just called a liar. That dude has crossed the line with me
So I have had enough. If anyone wants any additional info--data etc just pm me please. If not that's ok --just trying to share what I have done and what has worked for me
best wish's MM. no more
olddragger
MazdaManiac 03-01-2009, 12:19 PM Your datapoints are understood.
Unfortunately, they contradict quite a few other datapoints gathered by other vehicles in the field.
No one is calling you a liar. You are just misguided.
Icemark 03-01-2009, 06:20 PM The 70/30 cooling comment is still missing the point.
Exactly! Thanks for explaining it better than I even approached.
9krpmrx8 03-01-2009, 06:33 PM :banghead:
Spin9k 03-01-2009, 06:53 PM I'd like to ask a couple questions...and I'm asking for arguements one way or the other.
In our car, which system dissapates more heat (BTUs)? The oil system or water system? I've never seen any data, and it would be helpful.
We have a nice radiator, but more expense was taken cooling oil with dual oil coolers. Does that mean more benefit would be gained from more oil cooling 1st over water?
Let's say yes. Would simply improving the air flow provide more improvement than trying to add yet more radiator? How about removing the inside fender well plastic piece in the front. It's a separate piece, just takes a small screwdriver and 5 minutes. Would that freeflow matter enough on track events?
What happens when you say use a Mazdaspeed style bumper? Does that increase airflow - both water and oil significantly enough to matter. Could that be the easiest 1st cooling mod?
It would be ideal to once and for all determine some system of improvement, hopefully passive and easy not requiring additional plumbing $$$.
So I'm thinking, MS bumper, remove/redesign the rear fender well air outlet panel would do the trick? Is that crazy easy or simplistic?
ayrton012 03-02-2009, 04:15 AM What happens when you say use a Mazdaspeed style bumper? Does that increase airflow - both water and oil significantly enough to matter. Could that be the easiest 1st cooling mod?
I think yes, but the bigger openings increase the drag of the car, which of course don't relate so much to the overheating problem.
More question:
What are the average oil temps in an FC, FD, when the engine hot? Is there a huge difference between the Renesis, and them?
DOMINION 03-02-2009, 05:47 AM Exactly! Thanks for explaining it better than I even approached.
explaining what? its what everyone is dealing with when they buy a Rotary. Think of it like this; when you cock with oil it will hold a temp of oh lets just say 400F. Reuse that oil and it will hold a temp of oh 200F. This is just a example. But you get the point. Ok now that same gos for brake fluid. People that dont know this will just say uhh I never heard of that. But know you have and know you should start thinking about it and how all things liquid brake down over time with heat and dont block heat like they use to the first time they where used. Thats why I stay ontop of my oil changes and flush it.
More question:
The drag will be so minimal at rule road speeds its no big deal. However at high speeds the charged air is will find a way out of the engine bay. Just look into how the NASCAR's front, hood, and fenders are set up. Also open wheel race cars engines are closed in. All Rotarys run hot and drink oil and gas lol but think of it like this; Oil temps: If 30c=86f when moded FD's sit in traffic in 86f they get up to 194f. Now depending on your driving freeway driving will be about 140f to 194f.
I think water temps will be about 18 degrees more. Keep in mind all this is give or take and based on location and mods. But you get a good idea.
1. In our car, which system dissapates more heat (BTUs)? The oil system or water system? I've never seen any data, and it would be helpful.
2.We have a nice radiator, but more expense was taken cooling oil with dual oil coolers. Does that mean more benefit would be gained from more oil cooling 1st over water?
3.Let's say yes. Would simply improving the air flow provide more improvement than trying to add yet more radiator? How about removing the inside fender well plastic piece in the front. It's a separate piece, just takes a small screwdriver and 5 minutes. Would that freeflow matter enough on track events?
4.What happens when you say use a Mazdaspeed style bumper? Does that increase airflow - both water and oil significantly enough to matter. Could that be the easiest 1st cooling mod?
6.So I'm thinking, MS bumper, remove/redesign the rear fender well air outlet panel would do the trick? Is that crazy easy or simplistic?
1. Oil.
2. No big deal. Lots of exotic cars have this set up IE: 911. Second part of this question ref back to question one.
3. Yes and no. See I removed that plastic's that are right behind my oil coolers. However that dont mean more air is going to flow better throgh the oil coolers. What to keep you stuff cool? buy and use a radiator comb to keep your fins straight.
4. Yes the MS front will increase air flow. Will it cool the water significantly? no and no.
6. Good luck but I can tell you this; I dont have the MS front, plan on gettong one soon, I did remove the plastic's behind the oil coolers, gaped my hood and did the TB by pass. All 3 will help you out a lot. Just doing one. I dont know.
MazdaManiac 03-02-2009, 05:54 AM Holy crap that was a lot of nonsense.
Flashwing 03-02-2009, 07:10 AM Holy crap that was a lot of nonsense.
Whoa, there's some seriously bad information going on in this thread.
Being in one of the hottest climates in the US, I've spent a lot of time looking into cooling so this is a subject, thankfully, I've had a lot of experience with.
Let's get some facts straight. Oil is NOT the primary heat reducing agent in the coolant system. If that was the case you'd be using oil and not water to cool the motor. The difference is that oil will absorb about 1/3 of the engine heat and thus needed to have coolers in order to keep oil temperatures under control.
Oil temperature is the most important temperature of the two however. If you had 230 degree water temps with 260 degree oil temps you're motor is about to blow if it hasn't blown already.
If you have 230 degree oil temps but your water temps are 260 degrees you're still in a danger zone regarding detonation but your motor's chances of survival are greater than the previous situation.
One of the best methods I've seen employed is using an oil cooler from a 1st gen RX7 and placing it in line with the other 2 coolers. The oil lines simply link one cooler to the other which are placed in series. This would add extra cooling capacity as well as increasing the total amount of oil in the system.
I've also been running the Greddy oil pan for quite a while. It's cooling capability at idle is probably not very good being a foot off the ground but it increases the oil capacity of the RX8 by 1.5 quarts which does help.
Overall, my cooling setup consists of the following:
Greddy Oil Pan
Koyo Radiator
Mazmart water pump
Distilled water w/ 2 bottles of water wetter
SEIBON vented hood
I had a rare opportunity to race my RX8 on the track when it was about 105 degrees outside and about 140 degrees on the track itself. I was able to stay full throttle during the training session much longer than most vehicles including the other RX8's.
The problem was once the oil system became heat saturated my racing session was over. Oil doesn't give up heat easily and even after taking it easy for a couple laps the oil system didn't recover but a few degrees. The water system came right back into safe zones however.
Other problems involve sealing the area around the radiator. Too much cold air can escape around the sides since the resistance is less.
Frankly I find the notion of secondary radiators a waste of time. There are radiators on the market which are large enough to do the job of cooling the RX8 and using a secondary is totally unnecessary except maybe as a cost saving measure.
olddragger 03-02-2009, 01:08 PM I had to come back here. People who know me, know that i dont lie about this stuff and I freely share with others whatever I find out.
the radiator on our cars would probably be ok if it was directed more into the airflow in a more direct manner, but it is not. The rear of the radiator is also partially blocked by the battery box and aircleaner stuff. heck there is poor airflow through it in comparison with an upright rad directly in the airstream.
I will challange anyone that says this set up I have does not work in my area. The desert area folks have a totally differant enviroment and this mod may not do them much good--they dont have much humidity in the air to work with and humidity is a good thing when it comes to cooling. Their approach has to be different.
I have also ran on a 105F day and the pavement measured at 140F--alternator got so hot that the edges of the belt actually melted. engine coolant temps at MAX when i had to hold the car for a little over 7K was at 204---oil temps at 196. Once i was able to vary rpms again temps stabilized at 194-198--oil temps the same. If anyone has coolant temps of 260F with this engine then you have BIG probs.
Before I did this mod, on track, oil temps would get hotter than coolant--i have seen oil temps at 230F while coolant was at 220--before my mod. Most of the rx8's that have gauges that run track in my area will tell you the same--its not the usual case but on red flag times etc it does happen.
My street temps are in the 170-180F--traffic doesnt matter. if setting still with the a/c on and a hot high 90F day it will go to a low 190 and then cool off when you can move again.
I disagree that our oil temps are the most important in preventing damage to this engine.
I will also challange anyone to produce an oil temp of 250+ in our cars while the coolant temp is at less than 200F. Why?---because they work together--and the coolant has a much more profound affect on the overall temps of the engine. It will not allow that much of a difference between the too. If you coolant is already at 230 --again you have problems.
Airflow is a component of cooling that cannot be ignored. This was the easiest and the less expensive way that I could think off to fix my problem.
olddragger
olddragger 03-02-2009, 01:14 PM by the way--i do not want this to sound like the BHR radiator doesnt work. I know some people who have one and are vrey staitsfied with it. It is a much better design than oem and has a much better cooling capacity than the oem.
Some people would not like to do to their car what i have. The BHR rad is a great solution that appears oem in the install etc.
I would NOT endorse the Kyroso one.
Those are the only 2 rads that I know anything about. Their may be other good ones out there.
People get the wrong ideas easliy and I just wanted to clarify.
OD
MazdaManiac 03-02-2009, 01:29 PM I had to come back here. People who know me, know that i dont lie about this stuff and I freely share with others whatever I find out.
Why are you hung up on the idea that someone thinks you are lying?
All I'm saying is one data point doesn't make a sample.
No one is discrediting your findings.
Unfortunately, they run contrary to the larger body of data, that's all.
Icemark 03-02-2009, 01:50 PM explaining what? its what everyone is dealing with when they buy a Rotary. Think of it like this; when you cock with oil it will hold a temp of oh lets just say 400F. Reuse that oil and it will hold a temp of oh 200F. This is just a example. But you get the point.
I don't think anyone is going to confuse vegetable oil with motor oil. One, you want to you want to retain heat as much as possible and the other too reject heat as much as possible...
And with vegetable oils, the loss of temperature holding is due to contamination of the oil stock, with food stock.
Hmm, actually again, you seem to be missing that the only reason that brake fluids break down is again due to contamination usually by absorption of water. The boiling point lowering on brake fluid is not due to repeated heat cycles, but rather absorption of moisture which lowers the fluids capability to resist boiling.
Of course most DOT3,4 and 5.1 brake fluids are designed to absorb water to help reduce corrosion, so regular changes are required to maintain the anti-boil properties and remove the contamination from water, so that full brake compression is possible with limited to no fluid compression. This is why you change your brake fluid every 2 years. To remove the absorbed moisture from the system.
Oil viscosity break down on the other hand comes from contamination (blow by products) and shear and heat.
So not sure why you are bringing that up. Clearly every example you used, well they don't follow anything logical.
So getting back to the point, reduce the heat of the oil, and you reduce the temp battle in the engine between the oil and the water, and you reduce the possibility of viscosity break down from heat.
1. Oil.
Umm okay, then explain how you can run 100 miles without a oil cooler, but can't run 100 miles without a radiator.
MazdaManiac 03-02-2009, 02:20 PM Clearly every example you used, well they don't follow anything logical.
:arcadefre
DOMINION 03-02-2009, 06:21 PM So getting back to the point, reduce the heat of the oil, and you reduce the temp battle in the engine between the oil and the water, and you reduce the possibility of viscosity break down from heat.
Ok it was a bad example but you get my point. They breakdown over time with heat. You know as well as I do that oil dont last for ever so dont try to pull that bull shit on me.
No. Why dont you and Jeff tell me. You know thats bull shit. You can only run the quarter mile with out any oil coolers on a RX-7 and RX-8 has about the same heat issues as they do.
So I tell you what, I will by the by pass piping from home depot and send it to you all of it for free. You drive your car for 100 miles this summer and let me know how your temps are :rofl:
MazdaManiac 03-02-2009, 06:35 PM Gil - you are really out of your depth here. Just let it go.
r0tor 03-02-2009, 06:48 PM 70% of heat rejection is through the radiator... enough with the oil dissipating more BS
olddragger 03-02-2009, 07:16 PM ok-- my findings are contrary to a large body of data -- what data? I dont know of but one other car that has done this (by the way he had just as good as an affect as I)--so what data is being referred to?
I can answer myself-- because there is no other data than what we 2 have in evaluating this modification. You have to compare apples to apples.
It is what it is. Thats all.
I have to apologize to the originator of this thread--sorry it got turned around here. You had a good question and maybe we helped answering some of it?
I am so sure of this modification that this summer if there is anyone in the state of Georgia that does not believe me,--- do this modification--if it doesnt cool your engine temps (coolant and oil)
I will pay you back the money it cost you to do it. Now i will have to see the car and see the data--thats why i limit it to Georgia.
Someone come prove me wrong.
olddragger
MazdaManiac 03-02-2009, 07:24 PM Someone come prove me wrong.
You can't prove a negative.
The burden of proof always lies with the one asserting the claim.
Just sayin'.
olddragger 03-02-2009, 07:52 PM course you can prove a negative--if anyone doubts that this modification doesnt work, put it on your car, if it doesnt work then they have proved me wrong.
its a "negative" or a "positive" depending on which side of the belief you are. Quit trying to abstract away from the focus.
The proof is in the data. I have the data. The data is either believed or proved wrong. Call or fold?
olddragger
Icemark 03-02-2009, 07:54 PM Ok it was a bad example but you get my point. They breakdown over time with heat. You know as well as I do that oil dont last for ever so dont try to pull that bull shit on me.
Well actually if you could keep the oil clean and in normal operating temps, it would last forever (other than what is lost by seal seepage and use through the MOP).
Now you still would get the viscosity break down, but in that case typically the base stock would remain. For example if you had a 10W30, in most oils* you would end up with a 30W when the additive package got used up.
But the base stock pretty much would indeed last for ever, if you could keep the oil clean and in operating temps.
The problem of course is the same problem that happens in your cooking oil... contamination. The acids and gasoline and coolant that all seep into the oil through the combustion process contaminates the oil. Those are what the detergents in most oils are used for, but when they get used up, then it is your oil alone doing the work. If you could filter these out however, then you could use the oil pretty much forever. But the average car oil filter is just about useless for this part of cleaning/filtering.
This is what happens to your oil when you drop it off at your local auto parts store after an oil change and they recycle it. It sent to a refinery, gets cleaned, new additives are added and it is mixed up and sold back to you for use in your car all over again.
* Now Mobil 1 claims no additive package in their 10W30, so in theory using that oil you wouldn't even have to worry about the viscosity additives breaking down.
Icemark 03-02-2009, 07:56 PM :arcadefre
Are you calling me a Dork because you don't agree or just because I am getting sucked in to this lame argument?
MazdaManiac 03-02-2009, 08:03 PM course you can prove a negative--if anyone doubts that this modification doesnt work, put it on your car, if it doesnt work then they have proved me wrong.
olddragger
First of all, logically, I can't "prove you wrong".
As I said, "proof" doesn't work like that. Its a logical fallacy.
That said, I have data like yours.
Much more of it.
From multiple cars and multiple setups in a variety of climates and settings.
And the data runs contrary to yours.
I've already posted this stuff.
Your setup works for you. Good.
It just doesn't do so for the reasons you believe it does and, in like circumstances, it does NOT work elsewhere.
So, all you have done, is "prove" that you believe it works.
olddragger 03-02-2009, 08:14 PM MM should be a politician or investment banker.
OD
Razz1 03-02-2009, 08:21 PM MM for President!
DOMINION 03-02-2009, 08:51 PM Gil - you are really out of your depth here. Just let it go.
Not really. We all know how many coolers you put on your car. Did that cut your temps down to n/a Hondas? Geo's? or Corolla's?
Your right I will let it go. After all if Mazda wanted this car to run any cooler they would have done that from the get go. We all know we talk about how stuff works. But unless someone is willing to do and or try something different and it WORKS we will never know. Till then.
TTYL
Razz1 03-02-2009, 09:10 PM I have the RE front bumper and it runs cooler than other 8's on the track.
Especially since I know they don't Rev it as high.
My peak is at 9200, thanks to MM
Spin9k 03-02-2009, 09:30 PM Razz, do you run gauges for temp, how do you know for sure?
MazdaManiac 03-03-2009, 01:46 AM Not really.
Yes, really.
It has nothing to do with any data or anything.
You just aren't equipped to speak with any authority on anything.
You are just one endless non-sequitur after the next.
ayrton012 03-03-2009, 06:36 AM Now you still would get the viscosity break down, but in that case typically the base stock would remain. For example if you had a 10W30, in most oils* you would end up with a 30W when the additive package got used up.
It's true, if you speak about synthetics. A 10w-30 mineral oil will be 10w without the additives. It's one of the main advantage of the synthetics, that they don't thinning with the additives are wearing out.
You don't have to apologize! The answer is yes and no.
The Renesis oil cooler thermostat opening temp is 194F, the last FD's 149F.
I would like to know, without any modification, is the average oil temps of the Renesis are higher than the FD's?
If there is a huge difference between the RX-7, RX-8's data, maybe that is the reason for the lot of bearing weared engines. The Mazda raised the average oil temp for efficiency reasons (maybe), and in the same time lowered the preferred oil viscosity, and didn't increase the oil pressure.
I know it's already discussed that a xxw-20 oil is too thin for the Renesis, but there weren't real reasons why?
Why are there so high oil temps causing too thin oil?
Now the Mazda highly (!!!) raised the oil pressure in the Renesis II.
I'm just thinking, if I just know the things that are mentioned above, I have to say, maybe even a xxw-30 is too thin for the Renesis I. I know the 194F not a big matter for an xxw-20 oil too, but 194F at the cooler does not mean, that there aren't much higher oil temperatured point's in the engine.
So is the average oil temps are higher in the Renesis than in the FD?
olddragger 03-03-2009, 12:01 PM as for the comparison --- i have not see any of that data. In speaking with RIck I he recommends a 20W/50 wgt oil in the southeat and no thinner than a 10W/40 anywhere. That is with our engine and the previous ones.
In speaking with Rick he seems more concerned with side seals than anything else in the Renasis. That is with the right oil viscosity. The front bearing etc should not be a problem with the right oil viscosity and in keeping the temps in a sane range. He did say that the 5W/20 oil was crazy and was basically done for the overall "numbers" the manufactor needed.
Rick has talked with us/me for a long time about this engine.
olddragger
Spin9k 03-03-2009, 12:31 PM OD - doesn't the thicker base weight 10w or 20w change (lessen) how much the OMP injects for lub? or is that independent of viscosity?
olddragger 03-03-2009, 08:08 PM to the best of my knowledge the omp is a volume pump so viscosity will not matter
OD
ayrton012 03-04-2009, 03:49 AM as for the comparison --- i have not see any of that data. In speaking with RIck I he recommends a 20W/50 wgt oil in the southeat and no thinner than a 10W/40 anywhere. That is with our engine and the previous ones.
olddragger
I didn't want to make a new oil thread, but the 194F oil thermostat gives up the theme again from a new aspect. Mainly if I see that the Mazda raised the oil pump's performance in the Ren II., or I look at the FD,s oil thermostat data.
Otherwise I would like to find the best solution between the high rpm's oil flow, and the best protection (flow) at cold and hot.
I think in street use a xxw-50 oil highly decrease the oil flow at high rpm's, because the bypass valve opens at too low rpms. Of course it is true only if the oil temps are at normal. You will get higher oil temps with the thicker oil, so you made a step forward and backward in the same time.
At the cold side I'm only trust in a 0w or 5w oil. These are far from the ideal thickness (cold) , but the best solution we can find today. Don't forget, the most wear comes from cold startup. ..or too high temps.
Spin9k 03-04-2009, 08:43 AM ....I think in street use a xxw-50 oil highly decrease the oil flow at high rpm's, because the bypass valve opens at too low rpms. Of course it is true only if the oil temps are at normal. You will get higher oil temps with the thicker oil, so you made a step forward and backward in the same time....
...say what? ...why would xxx-50 oil decrease flow at high RPMs (vs low RPM)? what has RPM got to do with it?....if the bypass (in the filter?) opens how does that decrease oil flow?...forget RPM...it would increase it, yes? Also...Why would you get higher oil temps w/thicker oil?..heat transfers to whatever viscosity the same, yes? xxx-50 oil doesn't turn to sludge at high RPM or higer temps, it still flows and cools and lubricates.
robrecht 03-04-2009, 09:26 AM Also...Why would you get higher oil temps w/thicker oil?..heat transfers to whatever viscosity the same, yes? xxx-50 oil doesn't turn to sludge at high RPM or higer temps, it still flows and cools and lubricates.In general, thinner oils dissipate heat more efficiently than thicker oils, not sure if this is because of higher circulation speed or what other factors may come into play. That's one of the advantages of 5w-20 and 5w-30 oils, along with better cold start protection, especially for impatient Americans who tend to drive their cars hard without letting them warm up properly.
ayrton012 03-04-2009, 11:07 AM ...say what? ...why would xxx-50 oil decrease flow at high RPMs (vs low RPM)? what has RPM got to do with it?....if the bypass (in the filter?) opens how does that decrease oil flow?...forget RPM...it would increase it, yes? Also...Why would you get higher oil temps w/thicker oil?..heat transfers to whatever viscosity the same, yes? xxx-50 oil doesn't turn to sludge at high RPM or higer temps, it still flows and cools and lubricates.
There is a bypass valve in the oil line, which opens at a certain pressure to avoid over pressure in the system. If you have a thicker oil, you will reach earlier the opening pressure of this valve in the rpm range, so you can't increase the flow above this point, even if you raise the rpm. That is the problem.
For example at 194F with a xxw-30 you will reach the highest oil flow at 5000rpm and with a xxw-50 you have the biggest flow rate at 3000 rpm. These are not exact data just for show you the difference.
Spin9k 03-04-2009, 11:45 AM There is a bypass valve in the oil line, which opens at a certain pressure to avoid over pressure in the system. If you have a thicker oil, you will reach earlier the opening pressure of this valve in the rpm range, so you can't increase the flow above this point, even if you raise the rpm. That is the problem.
Ok...got it...but still...bypass open sooner sounds better, yes? IOW isn't it better to get max flow due to getting max pressure starting at 3K and on up the RPM range? and not have to wait to 5K? ..is the max flow not the same with both viscosities?
Sounds like the xx-50w oil gets the pressure up sooner, opens the bypass sooner, and gets max flow started at 3K RPM so sooner than w/thin oil. That sounds like a win-win-win no?
Razz1 03-04-2009, 11:53 AM Razz, do you run gauges for temp, how do you know for sure?
I use the AP.
Plus others have to pull off the track because the temp gage is at max.
ayrton012 03-05-2009, 03:50 AM Ok...got it...but still...bypass open sooner sounds better, yes? IOW isn't it better to get max flow due to getting max pressure starting at 3K and on up the RPM range? and not have to wait to 5K? ..is the max flow not the same with both viscosities?
Partly. You have higher pressure with the thicker oil, but you have less flow with it. The pressure itself is not everything. Lubricating is the main aim. One of the most important part of the lubicating is to cool down the internal parts of the engine.
You can improve the lubricating by raising the oil flow. The engine internal part's temps and load are raising with the higher rpm's, so you need more flow in this situation, but you can get it because of the thick oil. Much part of the pumped oil goes back immadeitaly to the oil pan, instead of circulating in the engine.
9krpmrx8 03-05-2009, 11:09 AM Hmmm. Some ineteresting info here. I guess I'll have to get some track data. During some hard running through many miles of mountain roads with steep up and down grades yeiled me and average temp of 204 during weather in teh 60's. This worries me because when I make the same run in the summer it will likely be in the high 90's.
Does anyone know what the temp range is for the RX-8? I got as high as 211 degrees during the last run and I'm afraid on a track my temps will be higher even in this weather because of the lack of high speed straights to cool the car down.
Interesting info here, Thread revival, yes..
Flash directed me here on the subject of Oil Cooler Thermostats...interesting.
Do they exist?..maybe, possibly on Series I RX-8's, on Series II, not so sure.
Why, Australia is in winter, from a cold engine and within 90 seconds mine are hot to touch, warm at about 20 seconds, IMO can't be a thermostat here...or can there?
I always go by Part Numbers, they never lie and tell the truth.
Is there a "Special" cooler for Germany or Europe?...I doubt it..
England has the same Oil Coolers as the USA and Australia, so why would Germany be special.
USA, UK and Australia..Series I RX-8..
N3H1-14-700D
N3H6-14-700D
Series II RX-8..
N3R1-14-700
N3R2-14-700
olddragger 08-05-2009, 01:47 PM is the thermostat in the primary or second cooler?
I have never seen a oil cooler thermostat--even when looking down into a cooler--guess it could be internal?
I can see them wanting to heat up the oil asap to at least 160F--thats probably more important than getting the coolant warm. I cant imagine a situation in which the oil WONT warm up pretty quickly in an oem car?
My oil coolers too- are warm after just a few minutes and the oil temp is only 160F (at the filter)when checked .
puzzle---that?
i found that the 1989 --91 rx7 does have a thermostat--that opens at 140F?
http://www.teamfc3s.org/main/factory_service_manual/1989_1991/02_lubrication_system.pdf
olddragger
puzzle---that?
olddragger
Yeah, I am still yet to be convinced there are any thermostats IN the Coolers themselves..
Yes there is the Eccentric Shaft pellet thermostat....that is all..exact same unit for all rotaries since 1985. FC,FD,FE.
http://www.rx8club.com/attachment.php?attachmentid=143409&d=1249492135
"Run for cover"
Mazmart 08-05-2009, 02:16 PM Yeah, I am still yet to be convinced there are any thermostats IN the Coolers themselves..
"Run for cover"
The coolers that we cannot remove a bolt and see the themostat we have cut open and seen the thermostat. I tried taking pics this morning but my light was bad.
Paul, what Mazda is that off again, and location, I am just trying to visualize , the second pic looks like a separate attachment bracket with two bolt holes. Line in, line out.
Mazmart 08-05-2009, 02:22 PM My pics are of various coolers from differing years.
Paul
Mazmart 08-05-2009, 02:25 PM Paul, what Mazda is that off again, and location, I am just trying to visualize , the second pic looks like a separate attachment bracket with two bolt holes. Line in, line out.
The second one is 2nd gen FC.
Paul.
The FC is the long single skinny cooler N326-14-700A ...yes?
Same oil cooler for all FC's.
Would like to see an RX-8 one cracked open Paul.
Mazmart 08-05-2009, 02:41 PM Here's the EPC diagram for the FC showing the thermo pellet.
Paul.
Mazmart 08-05-2009, 02:45 PM The FC is the long single skinny cooler N326-14-700A ...yes?
I'm sure I have a damaged one we can do. I'll also check my 09 stuff as well.
Paul.
Paul.
Great, Thanks Paul, yes I agree on the FC having a Thermo Pellet in it's oil cooler, would be great to see an RX-8 one, BUT the EPC does not show any separate parts breakdown like the FC has.
Here is the FC Part Numbers
8871-14-810 Thermo Pellet
1757-14-821 Spring
I can tell you that from the parts model codes (front 4 numbers) the pellet
8871 is from Series I RX-7, and the 1757 spring is from the original 1974 13B RX-4.
I guess the RX-8 OC thermostat is in this location..
http://www.rx8club.com/attachment.php?attachmentid=143419&stc=1&d=1249501525
olddragger 08-05-2009, 09:50 PM maybe that could be used for a drain plug too?
OD
Great to use as a cooler drain spot, but I am pretty sure the RX-8's don't have this removable bolt, the parts pic above does not show one and I don't recall seeing one on mine, you could always undo the oil cooler hose OD to drain mate.??
Correction, gee I am an old stupid BASTARD at times, yes there plainly is a bolt head there??? Derrr DUMB aren't I, a senior moment.
So yes, OD perhaps this is a drain point...MMMmm will have to investigate...
Sorry Dudes..
WOW...
$87.03 US for the 8871 Pellet and $2.81 for the 1757 Spring, is it GOLD Plated or something.
1757-14-821 Spring
Mazmart 08-06-2009, 08:33 AM This is the access point to the thermostat as Mr Engman reminded me last night. That's how we modify them on the FD and FE (SE3P). The design is a bit different as the bolt head will not separate from the thermostat.
Paul.
Mazmart 08-06-2009, 09:04 AM Here's what it looks like inside boys and girls:
Paul.
Flashwing 08-06-2009, 09:44 AM Paul is that thermostat unit able to be replaced without buying a whole new cooler? That would certainly be a cake install!
olddragger 08-06-2009, 09:59 AM well looks like a good drain spot and it appears to be on the passenger side?
Good info guys--great job--Paul you are the man! Ash you aint bad yourself mate.:)
olddragger
Mazmart 08-06-2009, 10:10 AM Paul is that thermostat unit able to be replaced without buying a whole new cooler? That would certainly be a cake install!
Or modified as we do. The problem is Mazda does not sell the thermostat by itself so no part number exists just as Ash pointed out.
Paul.
Mazmart 08-06-2009, 10:11 AM well looks like a good drain spot and it appears to be on the passenger side?
olddragger
Thanks Denny.
Paul.
9krpmrx8 08-06-2009, 11:09 AM So that is on the passenger side right? Is there a downside to constantly removing and reinstalling that bolt/thermostat?
dannobre 08-06-2009, 11:33 AM You will be surprised at how little oil you will get out by draining the coolers.
I opened both and cleaned out the lines with an air nozzle...and got maybe an extra 1/2 - 3/4 quart for about 1/2 hours work......
Just not worth it in the big picture :)
9krpmrx8 08-06-2009, 12:02 PM Oh, well scratch that then.
9krpmrx8 08-06-2009, 03:10 PM Okay, does anyone know what size the oil cooler line fittings are? Does anyone have a full diagram of the stock oil cooler system?
dannobre 08-06-2009, 03:14 PM I used -10AN lines for all my oil lines...Not sure if that helps :)
9krpmrx8 08-07-2009, 10:18 AM So you ditched the factory lines for an fittings and aftermarket lines?
dannobre 08-07-2009, 11:13 AM It's kinda in progress..I did it with stock coolers and new lines...but now I'm redoing the front with the new nose..and will put in larger cooler with fans when I do that
9krpmrx8 08-07-2009, 11:21 AM Are you going with one large single cooler?
dannobre 08-07-2009, 11:35 AM Nope...2 approx. 11X10" with fans :) Just have to find the right units
9krpmrx8 08-07-2009, 12:07 PM Sweet. Do you know what the BTU/hr ratings are for the stock units or are you just going with bigger units to assure they cool better?
dannobre 08-07-2009, 01:00 PM The stock units are small...they are quite thin in cross section The replacement units are much thicker as well as being larger in size
I want to be able to beat on it with no heat problems :) I have already done the cooling system..and other than ducting in the front for brakes and the inflow to the rad and coolers most of the mods to the cooling system are done
For Summer coming, I am actually going to open up my rear cooler splash shields even more, going to cut a hole of 11 x 10" and fit a one piece screen in the hole....probably rivet the screens through the plastic shields.
I have an original set of Black Splash shields I will just put back for next winter (water).
I just don't like the idea of restricting extracted air through tiny slits.
Frankly IMO you are waisting your time putting larger coolers on if you can't extract the air volume = heat.
dannobre 08-07-2009, 05:40 PM Don't worry...there will be much more flow ;)
There will be 9-10" high flow fans and screen on the wheel wells....plus a much more open front with ducting to direct airflow
If this thing overheats after I'm done there is no hope :lol:
9krpmrx8 08-07-2009, 05:47 PM Riveting screens is a good idea, I just worry about water too. It rarely rains here but when it does, it rains like crazy. Have you fabbed up the screens yet? I wonder if there is anything pre-made small enough to rivet on?
If you mounted one larger single oil cooler the same way ODragger did his secondary radiator do you think air flow would be sufficient? Do you think it would block air flow to the radiator too much?
Sounds Good..Dan..
9krpm ,No I haven't sourced the screen material yet, I am thinking of using the "Fly" or Bug screen mesh you get on home security doors it is strong and has holes in it about the size of a match head....I am hoping this will give more air flow, I guess the mesh is about a 45-50% air flow rate which has to be better than the original.
I could go to a larger mesh...any thoughts??
Not sure about the oil cooler in front on the radiator, that means there is an oil cooler, air con condenser and radiator....
9krpmrx8 08-07-2009, 06:41 PM Powdercoated flat black?
http://www.customcargrills.com/prodimages/scan_Diamond_XXLFlat_FlatBlack.jpg
Or I really think this will flow better
http://www.customcargrills.com/prodimages/scan_Diamond_XXL_Black.jpg
This may flow less but keep bigger stuff from the tires out.
http://www.customcargrills.com/prodimages/scan_Diamond_Small_Black.jpg
9krpmrx8 08-07-2009, 06:46 PM Okay last one.
http://www.customcargrills.com/prodimages/scan_Hex_Small_Black.jpg
Your 3rd one is probably what I would go for...now to find it.....here in oz
or maybe your last one...gee i hope i can find all this variety here, i really only need 2 x 12" square pieces
9krpmrx8 08-07-2009, 06:49 PM Would you make a frame for it or just rivet straight through it?
Na, no frame, just rivet mesh on the oil cooler side of the black plastic...thinking about 10 rivets per side would be more than enough.
mac11 08-07-2009, 08:19 PM I know there is a thermostat in the coolers. I've played with it. But I would be surprised if it were a 194 open temp, unless it starts opening MUCH MUCH sooner than that. In the winter I was seeing 140-150*F temps consistently until I would cover the heat exchangers, which would bring the temps up ~20*F.
This is all around 25*F.
But never below ~140 after startup no matter how cold it got. So that is where I would throw my hat in the ring for opening temp.
ayrton012 08-08-2009, 04:36 AM I know there is a thermostat in the coolers. I've played with it. But I would be surprised if it were a 194 open temp, unless it starts opening MUCH MUCH sooner than that. In the winter I was seeing 140-150*F temps consistently until I would cover the heat exchangers, which would bring the temps up ~20*F.
It's similar to that Ash experienced on his second gen RX-8. His coolers get warm short after cold starting.
I have an oil temp gauge, and it shows that the 194F is right data.
Usually the oil temp at the filter is between 176-194F, rarely at high speed I got about 203F. (now it's hot summer here)
hoss -05 08-12-2009, 01:19 PM Is there thermostats on both oil coolers? Danbobre what coolers did you end up going with? Dose the 8 use standard AN oil line fittings?
hoss -05 08-12-2009, 01:23 PM As I understand it the oil coolers are set up in series what side is feed and what side is return. Or another way to put it is dose the oil flow from drivers side to passenger side or passenger side to drivers side?
Mazmart 08-12-2009, 02:09 PM As I understand it the oil coolers are set up in series what side is feed and what side is return. Or another way to put it is dose the oil flow from drivers side to passenger side or passenger side to drivers side?
It leaves the pump and goes to the L cooler before heading to the R cooler which both have thermostats prior to entering the rear of the motor.
Paul.
9krpmrx8 08-12-2009, 02:13 PM left as in drivers side right as in passenger side?
Mazmart 08-12-2009, 07:59 PM left as in drivers side right as in passenger side?
That is correct (In the US but not in Japan)!
Paul.
Mazurfer 08-12-2009, 08:29 PM Glad we got at least that cleared up! :rofl:
left as in passengers side right as in drivers side?
Japan, Australia, England, New Zealand, Hong Kong, Brunei, Singapore, India, ETC :mdrmed:
BTW: This is Internationally known..
When one talks of Right Hand Side or Left Hand Side on any motor car in any country, you view the side you may be discussing as if you are sitting in the car.
NOT LOOKING AT THE CAR OUTSIDE FROM THE FRONT.. ;)
Groundbreaking Hey!!
hoss -05 08-13-2009, 09:53 AM This is Great info guys! Anyone know what type of fitting this is:
http://www.rx8club.com/picture.php?albumid=887&pictureid=9866
kokats8 07-29-2010, 03:55 AM in the models with 2 oil coolers the thermostats open both in the same temperature?which opens first?
9krpmrx8 07-30-2010, 04:29 PM The stock "thermostats" always allow oil to flow through, they are not true oil thermostats like the unit i run on my Fluidyne unit.
ayrton012 08-02-2010, 06:23 AM in the models with 2 oil coolers the thermostats open both in the same temperature?which opens first?
They get fully opened at the same temp.
9krpmrx8 08-02-2010, 10:54 AM Mazmart actual detailed how they operate and they are "open" at all times. they just open more as heat increases. Mine restricts flow and routes the oil back into the engine until the oil temp reaches 180F.
ayrton012 08-03-2010, 08:15 AM Mazmart actual detailed how they operate and they are "open" at all times. they just open more as heat increases. Mine restricts flow and routes the oil back into the engine until the oil temp reaches 180F.
Yes, it is better to say that they close fully the cooler bypass way at the same temp.
9krpmrx8 08-03-2010, 10:27 AM Yes, it is better to say that they close fully the cooler bypass way at the same temp.
This is a better explanation of how mine works.
http://farm5.static.flickr.com/4116/4856513985_1f108d4010_z.jpg
ayrton012 08-04-2010, 05:42 AM This is a better explanation of how mine works.
Like mine:
http://www.rx8club.com/showthread.php?p=3660482#post3660482
olddragger 08-04-2010, 09:46 AM Heck--why not just do a water/oil cooler? Oil is cooled by the engines coolant not air.
OD
9krpmrx8 08-04-2010, 11:03 AM Heck--why not just do a water/oil cooler? Oil is cooled by the engines coolant not air.
OD
I looked seriously into this OD and I found some cool units but they are expensive. I was looking at this one and some others.
http://www.aaperf.com/images/oil-cooler/oil-cooler2.jpg
9krpmrx8 08-04-2010, 11:05 AM This is a nice kit as well.
http://www.elise-shop.com/images/large/WOCLOW_LRG.jpg
ayrton012 08-05-2010, 02:53 AM Heck--why not just do a water/oil cooler? Oil is cooled by the engines coolant not air.
OD
Yes, I was thinking about it too, smaller dimensions, less weight, more possibility where to place it (a little better weight distribution of the car against front mount coolers).
olddragger 08-05-2010, 05:32 PM and with that you would have a place for some little secondary coolant radiators.
I have a friend that has one on a fi s2000--sweet setup.
OD
9krpmrx8 08-05-2010, 05:41 PM and with that you would have a place for some little secondary coolant radiators.
OD
Does he have the Mocal setup? I just wonder how efficient the liquid coolers are compared to air/air. I found a huge high dollar fluidyne liquid oil cooler on ebay for like $100.00 a while back. I regret not getting it.
