What power source to power a cup holder light from
Old Feb 23, 2009 | 05:26 PM
Alexb's Avatar
desperately needs a drop
I am going to install a little automotive LED in my cup-holders somewhere and add a switch in the cup-holder as well.
I am not sure where to tap into power though. I want either always on, or with parking/headlights, don't really care.
I want the closest power source, as to avoid messy wiring going all around the car.
Old Feb 23, 2009 | 06:01 PM
Charles R. Hill's Avatar
Owner of BHR
What will the switch be for?
Old Feb 23, 2009 | 06:28 PM
Alexb's Avatar
To turn the cup holder lights I am going to put in on.
To further clarify. I want either always hot power or when the lights are on power, going into a switch, which controls the lights. Because I won't need them unless it is dark, in which case my lights will be on.
The switch will be something like this one:
Attached Thumbnails What power source to power a cup holder light from-rx8_custom_1.jpg
Old Feb 23, 2009 | 06:33 PM
Owner of BHR
Try tapping into the power supply for the cigarette lighter illumination bulb. Although you won't be able to dim you probably don't dim the dash lights anyway.
Old Feb 23, 2009 | 06:36 PM
Alexb's Avatar
dim? like I would dim lights in a house?
This is strictly on off. So I am not worried about dimming.
Ya, that was my first thought for power, Might also do cigarette lighter right next to it.
Old Feb 23, 2009 | 06:44 PM
Owner of BHR
Cigarette lighter would be a better choice as it can handle the current except that it is key-on power and not light-on power. On the other hand, if you are good with wire-tracing you could run a line to the power supply side of the foglights before the foglight switch.
Old Feb 23, 2009 | 06:47 PM
laythor's Avatar
I zoom therefore I am.
i'd ask why you're putting a light in the cup holder but i'm too high on vicodin atm to car
Old Feb 23, 2009 | 06:51 PM
Owner of BHR
So he doesn't spill his drink trying to put it back in the cup holder!
Old Feb 23, 2009 | 06:52 PM
laythor's Avatar
this would fall under the illuminated shift **** in terms of usefullness. do you really look at the cup holder as your putting a cup in it or just feel it with your hand?
Old Feb 23, 2009 | 06:54 PM
Alexb's Avatar
no I put things like my wallet, phone and other stuff in there and and at night it is sometimes difficult to find my phone when it rings, when driving.
also because...
I can.
Old Feb 23, 2009 | 06:55 PM
laythor's Avatar
might run a strand of E.L. wire then... comes in a bunch of colors and takes up no space.
Owner of BHR
1) I had the illuminated shift **** and it was a rare "bling" item I put on my car.
2) Me, I know where the cup holder is so I can slide the cup right on in without seeing it or feeling around for it. That comes with maturity.
Old Feb 23, 2009 | 06:58 PM
Alexb's Avatar
well I know where the cup holder is, I also know where the road is, yet there are still lights there. Why bother have map lights? or an illuminated stereo.
Does it really matter why I want to do it?
anyways, thanks for the suggestion on the wire.
Old Feb 23, 2009 | 07:02 PM
Owner of BHR
Alex, we are just messing with you a bit since the point has been made and laythor is on Vicodin while I am just getting started with Jack.
Seriously, all I/we care is that you do whatever mods you want in a safe and proper manner.
Old Feb 23, 2009 | 07:06 PM
Doctorr's Avatar
Ricer is Nicer.....
Take power from the red/yellow wire at the ashtray illumination lamp. Ground it to the other wire at the ashtray, the one with a green stripe, no other wires will let you dim with the dash lights.
You probably know that the system uses a dimmer on the ground line, not on the power line.
S
Alexb's Avatar
Well good, no hard feelings then.
drebbrnator
Dec 27, 2018 07:02 PM
Billy Marcial
Mar 1, 2018 06:50 AM
Silver_Excalibur
Aug 25, 2015 09:09 PM
IB Cristina
West RX-8 Forum
Aug 20, 2015 08:52 PM
MarkX
Jul 31, 2015 07:50 AM
