Tranny Hard to go into Reverse ?
Old Feb 23, 2009 | 03:29 PM
Hmm, my tranny "seems" to have a problem.
Sometimes, ESPECIALLY when its cold, its "impossible" to get it to go into ANY gear. ok, let it run and sit for maybe a minute or 2. I can shift it into any gear EXCEPT first and Reverse. Fine I can go on with Gear 2 and maybe after 10-15 minutes of driving, I can go into first but still "kinda hard" to get it into Reverse.
Is my shift fork or tranny "finally" going? I had a "2nd gear" shift problem about 2 years ago, complained to dealer at that time(great neck mazda) they said its fine, and after that it seems to be ok.
but now, its really almost impossible to shift it into Reverse 90% of the time when cold. and 50/50 when its warmed up.
No good. Anybody got this "problem" ? -_- It started around 2 weeks ago, I didn't really pay attention to it cuz it was really cold that time, but I parked it in my garage now, its nice and warm, Still wouldn't go into reverse easy. got me worried.
48.3K miles right now.
Old Feb 23, 2009 | 04:40 PM
Nubo's Avatar
Lubricious
Doesn't sound good. My Reverse gear has always been picky, but I can usually get it on the first try if I'm very deliberate with the shift. I always assumed Reverse didn't have a synchro, but if temperature is affecting you, then maybe it does?
Old Feb 24, 2009 | 01:34 AM
lets hope so, its getting cold again in NYC. when it gets warmer ... then we'll see
Old Mar 1, 2009 | 01:08 PM
jujo's Avatar
I'm Old Greeeeeg
I get that...
Mine does that too, but maybe not as severe as yours? It's just difficult to put in, and sometimes I'll have to put it back into neutral 3-4 times until I can really feel it go in. Mostly only with reverse. 1st you have to be close to a dead stop to get it in gear.
Old Mar 1, 2009 | 01:54 PM
slimjimrx8's Avatar
im in ny also and its also harder to get into those gears if its cold out and the car isnt fully warmed up... now im hoping that it ny messin us up or we both have a problem
Old Mar 1, 2009 | 02:00 PM
HeavyMetal699's Avatar
Don't forget, no synchros for reverse.
But I think you already knew that. If its under warranty let the dealership take a look. Sounds like you might get a new transmission.
Old Mar 1, 2009 | 10:22 PM
if you cant get into rev, put it in first and move the car an inch or two forward.
then try reverse again, has always worked for me no matter what the weather..
Old Mar 1, 2009 | 10:36 PM
G3tR3DDY2GR3DDY's Avatar
or just get it halfway in reverse, slowly let out the clutch while still pulling gently into reverse and it will go in before the clutch lets all the way out.
Old Mar 1, 2009 | 11:19 PM
05shinka's Avatar
Bad Company, Till I Die
true^^ i do this sometimes..
Old Mar 1, 2009 | 11:21 PM
+1 to what swoope said. I've done that is multiple cars before, usually does the trick
How long have you had the tranny fluid in there? What kind you using?
Old Mar 2, 2009 | 12:11 AM
nope
Even if I could put it into 1st and move it a bit(even a block of distance), I still couldn't get it into reverse. one time I was trying to do a broken U-turn I was like wow ... I got stuck in the middle of the road cuz I can't reverse. took me about a minute before I can "finally" got it into gear (Lucky no car at that time, sheesh)
Im using my FIT now and the 8 is inside my heated garage. Will take it out probably next or next next week to dealership.
Old Mar 2, 2009 | 12:23 AM
Originally Posted by nycgps
nope
after 9 years as a professional skier, my motto is cold is bad..
subaru.. ftw! it never failed me.. 85 4wd wagon. red and rust. gave it away to a needy family with 350k miles on it.. it did cold well.
Old Mar 2, 2009 | 02:31 PM
Thinking of selling the FIT for something with 4WD.
but times are hard right now () so ... hehe ... will see.
Old Mar 6, 2009 | 01:41 AM
Its getting worst. I cant even shift it into reverse most of the time
Im going to check and see if theres any leaks anywhere ... -_- damn snow outside ...
Old Mar 6, 2009 | 11:50 PM
@)!#*$!)@*$!Q@#$)*
Damn, very hard to go into reverse #)$*!)@*$@!)#*$
I see if I can change the Tranny fluids tomorrow with the thermostat. )#*$)@Q!#$* (last tranny fluid change was about a year something ago *shurgs*)
if that doesnt "fix" it ... *shurgs* ... Dealership here I come (well Im going anywayz so ...)
Old Mar 6, 2009 | 11:54 PM
shaunv74's Avatar
Power!!
Redline MT-90.
Old Mar 7, 2009 | 12:18 AM
I have MT-90 in the tranny ... -_-
Old Mar 15, 2009 | 12:42 PM
PRX8's Avatar
I had the same problem and got the syncros replaced on all gears almost 2 years ago, my car had 41k when I experienced this issue, now I have 63k and havent had any problems so far.
Old Mar 15, 2009 | 01:08 PM
I changed and bleed the brake fluid, and I changed the tranny and rear diff fluid couple days ago. after change, it seems to be better, but its still there (still can't go into reverse easy, at least not when its cold)
Im going to have dealership to look at it. see what they say.
Old Mar 18, 2009 | 08:43 PM
PRX8's Avatar
Did you get your reverse fixed...
Old Mar 19, 2009 | 01:15 AM
Not yet. Dont have the time to visit dealership.
The reverse thing gets better now, but still wouldnt go if the car is cold.
gay ...
Old Mar 19, 2009 | 01:21 AM
mac11's Avatar
Rotary , eh?
1st & reverse in tandem is clutch.
Old Mar 19, 2009 | 01:24 AM
shazy's Avatar
Just double clutch the **** out of reverse, Im sure it'll help the cause.
Old Mar 19, 2009 | 01:42 AM
Silver06's Avatar
Zoom Zoom....
NYCGPS,
Is your clutch disengaging fully? (I haven't searched to see if you've had to deal with the broken clutch bracket problem).
Reverse isn't a synchromesh gear.
Old Mar 19, 2009 | 09:04 AM
Clutch again ? ... grrr ... but I just changed my clutch like last year ... grr ....
Originally Posted by Silver06
NYCGPS,
I think so ... dealership replaced my clutch bracket 2 yrs ago.
maybe its "coming back" again ?
the pedal used to have this soft feeling, After the brake fluid swap, the pedal feels more "firm" and it seems that its "easier" to go into gear.
Reverse still hard -_- when the car is completely cold, it almost impossible to go in. 1st is better.
