Series I Do It Yourself Forum Wanna save some coin or time/money in the shop? Read up on Do-It-Yourself custom mods and repairs & post your own here.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1
Old Feb 17, 2009 | 03:57 AM
ALKEESMOKER's Avatar
PART 1
Install is straightforward, but I ran into a few issues so I thought this would help.
Feel free to add steps or make corrections. Feel free to follow the steps in a different order if it is easier for you.
I'M A NEWB SO FOLLOW THESE DIRECTIONS AT YOUR OWN RISK
I figured these two mods should be done together since taking off the throttle body makes installing the coils much easier.
1. Per BHR instructions, there is no need to remove your battery connections as long as the key is turned to the "off" position.
2. Remove the stabilizer bar.
3. Remove the factory or aftermarket airbox, and the flexible intake duct or aftermarket intake pipe from the throttle body, then move all tubes out of the way (recirc, vacuum, jet-air, etc.).
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-1-start.jpg
4. Remove the throttle body by unscrewing the four 10mm bolts which secure it to the intake manifold.
5. Remove the engine hoist bracket located next to the alternator by removing the two bolts that connect it to the engine. Coolant might leak out, so the faster you remove the hoist and replace the bolts the better.
Save the hoist should you ever want an engine swap.
NOTE: I had to loosen the alternator retaining bolt and belt to get to one of the hoist bolts.
NOTE: My kit DID NOT FIT with the hoist installed. It was pushing against the 2nd ignition coil.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-2-tb-hoist.jpg
6. Remove the spark plug wires from the coils.
7. Using a 10mm deep-well socket and extension, remove the 4 nuts that secure the coils to the factory base plate.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-3-plugs-bolts.jpg
8. Remove the wiring harnesses from the coils and take out the coils.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-4-plug-bolts-gone.jpg
9. Jack up the car and remove the front driver side wheel. I blocked the back wheels to keep the car from rolling and used a second jack stand just in case.
10. Facing the wheel well, remove the upper right clip which will give you access to the plugs.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-5-wheel-removed.jpg
Old Feb 17, 2009 | 04:04 AM
DIY: BHR Ignition Coils; Throttle Body Spacer Part2
PART 2
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-6-plugs.jpg
11. Remove the plug wires. Notice the front and rear trailing and leading plugs are clearly marked by a "T" or "L".
12. Place the 4 nylon spacers provided with the BHR kit onto the 4 studs which hold the factory coils.
13. Place the pre-assembled BHR Kit, base plate down on top of the factory bracket and nylon spacers. Keep the ground wire accessible as you will bolt to the factory ground located at the upper right corner of the engine bay. It's a tight fit. The last coil will be really close to the bottom of the intake manifold.
NOTE: DO NOT remove the BHR spark plug wires from the BHR coils as the terminals are somewhat fragile and will break with repeated tension (pulling) placed on them.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-7-ignition-coils.jpg
NOTE: MY KIT DID NOT FIT. I ended up hitting the intake manifold and denting the last coil by trying to force it in.
I spoke with Charles and it was possible my coils got mounted on the wrong plate. It could also be possible that my 8 is just different, or that things shifted during my turbo install. Regardless, Charles offered to send me a new plate right away, but I hate waiting, so I drilled my own holes.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-8-new-holes.jpg
Everything fit, so I'm happy.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-9-coils-.jpg
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-10-coils-.jpg
Old Feb 17, 2009 | 04:28 AM
DIY: BHR Ignition Coils; Throttle Body Spacer Part3
14. Install the 4 factory nuts back onto the studs from which they were previously removed and torque to spec.
15. Install the plug-and-play harnesses from the BHR kit directly into the factory harness connectors, in order, front to rear (L1, T1, L2, T2. ).
16. Go back to the wheel and snap the plug wires onto the correct plugs tight.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-coil-diagram.jpg
http://i110.photobucket.com/albums/n...oilDiagram.jpg
NOTE: I did not place the new plug wires into the factory wire holder clip located to the right of the coils.
17. Replace the wheel well clip. Replace the tire. Bring the car down.
18. Grab the ground wire, strip the end, crimp onto the ring that came with the kit and bolt to the factory ground located at the upper right corner of the engine bay (when facing the car from the front) .
19. Take a nap.
19. Bring out the throttle body spacer and attach the provided o-ring to the back.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-12-tb-spacer.jpg
20. Take an allen wrench and make sure the small bolt on the bottom and the two on the side are tightened until your ready to install your nos or water/alcohol/meth injection kit.
21. Insert the four bolts and washer provided with the spacer through the throttle body.
22. While holding the throttle body, place the BHR spacer (logo on top and o-ring facing the front of the engine) behind the throttle body mounted on the new bolts.
23. Install the entire assembly onto the intake manifold and torque the bolts in the factory sequence and to the factory specs.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-13-tb-spacer-.jpg
24. Re-install the throttle body harness connector.
25. Re-install the intake duct and all of the parts previously removed for access and all tubes and YOU'RE DONE....
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-14-all-.jpg
...OR
Old Feb 17, 2009 | 04:33 AM
DIY: BHR Ignition Coils; Throttle Body Spacer Part4 FINAL
.....unless you're me as the greddy pipe no longer fits. Possibly because my blow off valve is a hybrid with an adjustable recirc, and the recirc tube did not reach to my blow off. Anyway, I cut the tube (probably too much on the bottom).
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-15-pipe-cut.jpg
25a. Cut the pipe that connects to the throttle body just enough.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-16-pipe-cut.jpg
NOTE: THE PIPE WILL NOT HOLD UNDER BOOST. By cutting it, you lose the lip or ridge that keeps the clamp from popping off. I noticed it but thought it might hold. On my test drive at WOT...POP...pipe came off and car died, I pulled to the side and reattached the pipe, drove home, pulled it out.
25b. Have a ridge TIG welded, or if metal MIG welded to the edge of pipe. My welder was worried the heat would harm my blow-off valve, so I just had 8 small beads welded around the pipe at an angle.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-17-beads.jpg
NOTE: Because of the bend in the pipe, the clamp is mounted further back on the top and on mine, is right on the edge on the bottom so that the ring is flat on the surface. I had the clamp on so that the shop knew where to weld the beads at an angle.
NOTE: Because the clamp is at an angle, I needed a longer silicone coupling so...
25c. Buy about a 3 1/2 in diameter, about 4 inch in length, silicone coupling. Cut as needed based on the ridge/bead placement and the angle of the pipe.
(My clamp is slightly off the edge of the coupling. Is that okay??? Anyone???)
26e. Re-install the pipe....and everything else. All done.
DIY: BHR Ignition Coils; Throttle Body Spacer PART1-done.jpg
IMPRESSIONS, Ignition Coils: Awesome! Throttle response is so much quicker. Backfires are a lot less and a lot lighter.
As for Idle, I was having "almost stalling" issues. After the cooling fan mod they got worse, then a little better after grounding to the negative terminal of the battery.
After this mod, back to where they were before the cooling fan mod. Why do I still have issues? I think my alternator is on it's last leg...yeh...more fkn money I need to spend. But I can't wait to see how these coils feel with a new alternator.
IMPRESSIONS, Throttle Body Spacer: Very pretty, but I don't have the meth injection kit installed yet. Seriously though, getting the spacer saves me more than $100, as I would have had to pay tri-point more to pull out pipes and drill new holes.
I really hope this helps! Again, a piece of the clamp holding the silicone coupling to my throttle body is slightly off the silicone. IS THIS OKAY??? It seems to be holding, but hearing a POP while driving is not fun.
THANKS EVERYONE.
Old Feb 17, 2009 | 04:42 AM
Flashwing's Avatar
3-wheeler
I've spoken to Charles and this seems to be a popular fix for any fittment issues. We've continuing to make changes as necessary to ensure proper fittment of the parts. Until then, be sure to address any problems with us so we can make sure you don't damage your kit and that it works/fits to your satisfaction.
Great DIY!!
Old Feb 17, 2009 | 02:06 PM
2) DO NOT remove the BHR spark plug wires from the BHR coils as the terminals are somewhat fragile and will break with repeated tension (pulling) placed on them.
I'll add this to my post. I actually tried taking one off during the install, then realized that it should not have been touched.
Old Jan 19, 2011 | 05:20 PM
c0ldf1ame's Avatar
just wanted to add that since the new kit comes with the wires detached, the correct order for the wires are L1, T1, L2, T2
Old Jan 20, 2011 | 06:11 PM
FungsterRacing's Avatar
Hibernating -.-
Thanks for the DIY, will definately come in handy once I get my BHR Ignition Kit... hopefully soon
Old Aug 17, 2011 | 02:30 AM
cophyor's Avatar
i have an aem cold air intake. Do i need to take that off to install the ignition system?
Old Jul 20, 2015 | 02:27 PM
ottocycle's Avatar
Great DIY, thank you. One note -- there's no need to take the wheel off. Just crank the steering wheel all the way to the right before jacking up the car. This will give you enough clearance to get to the plug wires.
ironj221
36
Jan 20, 2026 08:28 PM
rotorocks
47
May 11, 2016 03:23 PM
9krpmrx8
Nov 5, 2015 11:45 PM
PTQLam
Aug 16, 2015 05:40 PM
cschoeps
Aug 6, 2015 12:44 PM
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
