FS: Enkei RPF1 18x9.5 +45 with 275/35R18 Falken RT615's
I had my fender lips rolled just to be safe, but I believe others have run this combination without rubbing. I would take a look at "The Will It Fit Thread" or the "Calling all Enkei Owners" thread for advice.
Doing a quick search, I found these posts:
https://www.rx8club.com/showthread.p...75#post2682407
https://www.rx8club.com/showthread.p...75#post2460018
I also found this warning on Good-Win-Racing.com:
"NOTE the Falken Azenis Sport runs wider than most tires with the same size specs and fitting this big combo will take a little rear lip fender roll if your are lowered or not running much camber." -LINK: http://www.good-win-racing.com/Mazda...-1051RX8w.html
Hope that info helps.
lol you definitely will. Maybe we can roll up together, I like to go pretty early with Astral. Let me know. :D As for the wheels, that sounds cool. Need some time to think it over..but I'll let you know asap.
They're not R comps..they're street tires. CLOSE to r comps, but still street tires. Essentially, given what he said, sounds like 25% left? Not bad in my opinion..maybe a event or two before you need to swap.
25% tread remaining is probably about right, also.
Enkei RPO3 in an 18x9 +40 (http://www.enkei.com/rp03.html). The RPF1's are lighter, wider, and better looking (imho), but I need a 9" wheel to compete in STX autocross.
How much is shipping to Houston, TX 77003?
Edit: did a quick quote of one of the Enkei RPF1 packages 18x9.5 with Toyos from Good-Win-Racing and shipping is about $110 UPS ground shipping.
If this is close to the shipping from where you are, then I'm very interested. Going to PM you too.
thats what i get for just seeing "wear bars" and assuming r comps
