HID low beam, fog light... also white parking light and side marker light
Old Feb 12, 2009 | 05:48 PM
sthio's Avatar
Hi,
I am planning to change HID for my low beam and fog light.. Also, I wanna change my parking light and side marker light to white, so that I have everything in white..
I understand that the bulb that I need to replace is D2S 35W bulbs for the low beam...
My questions is, can I use D2S 35W HID conversion kit for my fog light?
Also, what brands are good for my low beam and fog light?
do you guys have the link that I can buy from?
how about the parking light and the side marker?
thanks
Old Feb 12, 2009 | 05:53 PM
invasion08's Avatar
go to www.rx8strakes.com
Old Feb 12, 2009 | 06:44 PM
Aipex8's Avatar
X e p i A
Originally Posted by sthio
Hi,
thanks
If you have stock HIDs, why are you going to change your headlight bulbs? The stock 4300K is as white as you can get. If you are trying to add more color (blue) then I understand.
The foglight use an H11 halogen bulb, so you'll need an H11 HID conversion kit.
You can get Apexcone D2S bulbs and H11 kits at http://www.therpmstore.com/
I recomend http://www.v-leds.com/ for LEDs, they have the best selection and you can't really beat the quality. Most white LEDs are between 6000K - 8000K, so if you are planning on matching your HID color keep that in mind (I've got 6000K headlights). Check my thread for the brightest 194 LEDs for the parking and corner lights (4x.5watt=BRIGHT!!):
https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/new-leds-wow-bright-158590/
Old Feb 12, 2009 | 07:35 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
You should do your footwell lights while you're at it.
dmengel
Feb 16, 2016 09:47 PM
MatthewRJ
Aug 5, 2015 09:24 AM
Stubbs
Jul 28, 2015 09:23 PM
He||hammer
Jul 24, 2015 10:56 AM
