shift knob stuck
Old Feb 8, 2009 | 05:39 PM
chancejat's Avatar
Drive it like u stole it!
shift **** stuck
i put a aftermarket **** on a while ago, well i recently took my car to the dealer to get the e-brake handle replaced and i guess he reinstalled the **** on too tight bc now i cant get it off and my whole shifter assy is rotating(the whole shaft moves and the **** moves with it).....its still shifts fine though.....any ideas how to get it off without hurting anything or is it already to late what could be broken on the shifter for it to just spin like that? thanks
Old Feb 8, 2009 | 07:27 PM
staticlag's Avatar
The Professor
Is it the universal type?
Old Feb 8, 2009 | 07:29 PM
chancejat's Avatar
no.....no adapter nut, fits right on....
Old Feb 8, 2009 | 07:42 PM
staticlag's Avatar
The Professor
sounds like they stripped the threads. have you tried pulling straight up?
Old Feb 8, 2009 | 07:48 PM
chancejat's Avatar
no.....let me check...
Old Feb 8, 2009 | 07:53 PM
chancejat's Avatar
ok....so it moves up and down about half an inch....and im not talking about moving it down like you get in reverse. its like it goes up stops stays in like a indent then all the gears work even reverse will go in when i push down(while its still in the up indent) then i can move it in the down detent and all the gears work also....
Old Feb 8, 2009 | 08:32 PM
laythor's Avatar
I zoom therefore I am.
i'd start with a dremel and a cut off wheel... the **** is stripped out and you'll spend days trying to get it off.
theblinkof
Oct 4, 2023 05:24 PM
WranglerFan
Nov 5, 2017 09:35 AM
RX8mzda
Oct 1, 2015 10:17 PM
XianUnix
Sep 29, 2015 03:48 PM
